Modelism - RHC Forum: Vand Radiocomanda FlySky I6 - Modelism - RHC Forum
Vand Radiocomanda FlySky I6 nou nefolosita cu receptor
#1 Useril este offline   nen77
  • --tadadam--
  • Postari: 1567
  • Inregistrat: 08-March 06
Postat 14 September 2021 - 07:40 PM
Vand Flysky i6 noua, varianta cu receptor.
pret 200 ron
Tel 0722441822
Date tehnice:
Description:
Brand Name:FlySky
Item Name: FS-i6 transmitter
Type: Mode 1 with color box, Mode 2 with color box(optional)
Channels: 6 Channels
Model Type: Glider/Heli/Airplane
RF Range: 2.40-2.48GHz
Bandwidth: 500KHz
Band: 142
RF Power: Less Than 20dBm
2.4ghz System: AFHDS 2A and AFHDS
Code Type: GFSK
Sensitivity: 1024
Low Voltage Warning: Less than 4.2V
DSC Port: PS2
Output: PPM
Charger Port: No
ANT length: 26mm*2(dual antenna)
Transmitter Weight: 392g
Package Weight: 628g
Transmitter Size: 174x89x190mm
Package Size: 23.5x21.2x10.6cm
Power: 6V 1.5AA*4 (Not Included)
Display mode: Transflective STN positive type, 128*64 dot matrix VA73*39mm,white backlight.
On-line update: Yes
Color: Black
Certificate: CE0678,FCC
Model Memories: 20
Control Range: 500m
Features:
Works in the frequency range of 2.405 to 2.475GHz.This band has been divided into 142 independent channels,each radio system uses 16 different channels and 160 different types of hopping algorithm.
This radio system uses a high gain and high quality multi directional antenna,it covers the whole frequency band. Associated with a high sensitivity receiver,this radio system guarantees a jamming free long range radio transmission.
Each transmitter has a unique ID,when binding with a receiver,the receiver saves that unique ID and can accepts only data from the unique transmitter.this avoids picking another transmitter signal and dramatically increase interference immunity and safety.
This radio system uses low power electronic components and sensitive receiver chip.The RF modulation uses intermittent signal thus reducing even more power consumption.
AFHDS2A system has the automatic identification function,which can switch automatically current mode between single-way communication mode and two-way communication mode according to the customer needs.
AFHDS2A has built-in multiple channel coding and error-correction,which improve the stability of the communication,reduce the error ratio and extend the reliable transmission distance.
  • Fisier atasat  i6.jpg (171.5K)
West Hobby Team
#2 Useril este offline   ecu
  • Postari: 173
  • Inregistrat: 13-September 14
Postat 15 September 2021 - 07:00 AM
salut, esti din bucuresti?
  • --tadadam--
  • Postari: 1567
Postat 15 September 2021 - 07:59 AM
Vezi postareaecu, la 15 September 2021 - 07:00 AM, a spus:
Sunt din Timisoara.
West Hobby Team
#4 Useril este offline   ecu
  • Postari: 173
Postat 16 September 2021 - 10:19 AM
ofer 200 cu transport la bucuresti
#5 Useril este offline   nen77
  • --tadadam--
  • Postari: 1567
Postat 20 December 2021 - 09:49 AM
Vandute!
West Hobby Team
