Modelism - RHC Forum: Turnigy dlux 250A HV 14s 60v ESC NOU - Modelism - RHC Forum
Turnigy dlux 250A HV 14s 60v ESC NOU Turnigy dlux 250A HV 14s 60v ESC NOU
#1 Useril este offline   savagefan
  • Postari: 359
  • Inregistrat: 08-May 11
  • Interests:Aero
Postat 29 December 2019 - 11:35 AM
Specs:
Max Cont Current: 250A
Max Burst Current: 275A
BEC: N/A (OPTO)
LiPo: 6~14S
NiMH: 18~42cells
Weight: 456grams
Max RPM (2-pole): 200,000rpm
Size: 135 x 77 x 50mm
Motor Plug: Female 6mm bullet Connector
Battery Plug: Nil
Features:
Low Internal Resistance
Low Operating Temperature
Over Temperature Protection
Spark Eliminator
High Quality Hexfets (Mosfets)
Programming Options:
Battery Type: Lixx / Nimh
Forward/Reverse
Soft Start
LV Cut off Type (Ignore, Reduce Power, Stop Motor)
LV Cut off setting
Timing
Switching (8,16kHz)
Factory Restore
Default factory settings:
Brake: off
Battery: LiPo Auto Detect
Low Voltage Cut: 3.2v (power down motor)
Timing: Auto
Frequency: 8KHz
Pre 700 lei nou
0748776755
loading
