Modelism - RHC Forum: catamaran - Modelism - RHC Forum
catamaran prima barcuta
#1 Useril este offline   fefy
  • Postari: 15
  • Inregistrat: 17-May 09
Postat 15 November 2018 - 09:43 AM
buna tuturor si respect domnului vasia . Am inceput constructia barcutei dupa imaginile gasite aici pe forum . nu sunt cote, de cote se ocupa fiecare din cate am inteles nu am gasit planurile in format dwg si nu mi le-a trimis nimeni deaceea am inceput constructia dupa o poza care am gasito aici Fisier atasat  catamaran_pescuit_RHC_desfasurat_Model.jpg (90.94K)
#2 Useril este offline   fefy
  • Postari: 15
Postat 15 November 2018 - 09:47 AM
Fisier atasat  post-30-1189675536.gif (57.83K)
Fisier atasat  post-30-1189675833.gif (8.18K)
Fisier atasat  post-30-1189676121.gif (17.42K)
Fisier atasat  post-30-1189676386.gif (17.04K)
#3 Useril este offline   fefy
  • Postari: 15
Postat 15 November 2018 - 09:56 AM
barcuta o construiesc din forex Fisier atasat  IMG_20181110_161321.jpg (88.97K)
Fisier atasat  IMG_20181112_161031.jpg (158.33K)
Fisier atasat  IMG_20181112_161020.jpg (193.03K)
  • Postari: 3555
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 15 November 2018 - 10:55 AM
Cred ca ai o problema cu lungimea coastelor ,acele nervuri nu formeaza o linie continua.
Barcute intinse!
#5 Useril este offline   fefy
  • Postari: 15
Postat 15 November 2018 - 10:56 AM
Fisier atasat  IMG_20181113_175949.jpg (218.56K)
Fisier atasat  IMG_20181114_130939.jpg (127.18K)
Fisier atasat  IMG_20181114_131054.jpg (105.64K)
#6 Useril este offline   ahmoola
  • Postari: 409
  • Inregistrat: 14-February 13
Postat 19 November 2018 - 02:19 PM
Vezi postareafefy, la 15 November 2018 - 10:56 AM, a spus:
Si mai faci o greseala....nu ai dat jos autocolantul....Forex-ul e alb
Aceasta postare a fost editata de ahmoola: 19 November 2018 - 02:20 PM
#7 Useril este offline   fefy
  • Postari: 15
Postat 21 November 2018 - 02:05 PM
Vezi postareaahmoola, la 19 November 2018 - 02:19 PM, a spus:
nu este autocolant pe forex este tipatita o reclama constriesc barcuta doar din lucruri reciclate
Aceasta postare a fost editata de fefy: 21 November 2018 - 02:10 PM
#8 Useril este offline   fefy
  • Postari: 15
Postat 21 November 2018 - 08:18 PM
Fisier atasat  IMG_20181121_152306.jpg (79.79K)
Fisier atasat  IMG_20181121_180653.jpg (103.41K)
Fisier atasat  IMG_20181121_180724.jpg (141.34K)
Fisier atasat  IMG_20181121_180818.jpg (157.66K)
#9 Useril este offline   metrix4you
  • Postari: 306
  • Inregistrat: 04-May 10
  • Interests:calculatoare , electronica si mai nou navomodelism
Postat 03 January 2019 - 04:37 PM
Eu am facut modelul asta , prima mea barcuta
Nu am fost deloc multumit de modelul asta din doua motive:
- sistemul de cuva este destul de grru de facut pentru ca solicita foarte mult servomotorul
- este foarte lasata de spate in apa
Stiu ca MaianDMD a facut varianta asta cu sistem de cuve pe laterala
Poti sa te uiti la mine la poze sa vezi cum a iesit modelul meu , din comantex
A2a barca a mea , modelul alen este mult mai ok. Eu nu o mai am , i-am dat-o cuiva care chiar o foloseste
Spor la treaba
Toate filmuletele mele despre barcute:
http://www.youtube.c...ou?feature=mhee
#10 Useril este offline   marius35
  • Postari: 354
  • Inregistrat: 18-May 10
Postat 21 January 2019 - 08:14 PM
Salut , este o barcuta foarte stalila pe valuri singurul minus pot spune este sistemul de cuvare,, am copiat de la Marian Dmd si o sa fac cu cuvele pe lateral revin cu poze.Asta pentru hobby ca tot gonflabila de 3m cu chila si motor de 5cp ramane la suflet
#11 Useril este offline   fefy
  • Postari: 15
Postat 23 November 2021 - 05:43 PM
buna tuturor am revenit cu un filmulet complet despre ce am realizat https://www.youtube....h?v=AnxmCN8524U
