Modelism - RHC Forum: Vand 4buc EMAX LS2206 1700KV Noi - Modelism - RHC Forum
Vand 4buc EMAX LS2206 1700KV Noi EMAX LS2206 Lite Spec 2206 1700KV 5-7'' 4-6S
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 03 October 2018 - 09:39 AM
-Vand 4buc motoare EMAX Lite Spec LS2206 1700KV, noi la cutie cu toate acesoriile, sunt generatia noua de motoare dupa seria RS, sunt facute sa fie mult mai usoare si eficiente pentru drone de curse sau freestyle puternice. Sunt 1700KV perfecte pentru baterii 6S cu elici 5inch care sunt la moda acum si cresc eficienta si timpul de zbor, sau se pot folosi pe 4S si elici 5-7inch pentru long range si eficienta sporita.
Description:
Introducing the new LS (Lite Spec) 2206 line of motors. After countless amounts of research, EMAX set out to make a motor line that meets the demands of each pilot. From racing and freestyle, EMAX managed to combine such demands into a motor that can cover all fronts by reducing the weight while keeping the durability and performance in check.
Finding the balance of power and efficiency to keep you flying for longer, the LS series will give you the power you need.
Feature:
NSK high efficiency bearings
0.15mm silicon steel laminations
Aluminum shaft with hardened steel core
1.8mm N48SH ARC Magnets
Screw capture for bell. Easy to service
Stealth black anodized color, with silver beveled edges
Reduced base size. Lower the weight and easier to make sure not to short your wires with long screws.
16mm x 16mm mounting holes ( 19x16 is the past) future frames don’t need to have slotted mounting holes.
120mm 18AWG wire. Testing has shown a 5% increase in performance with thicker gauged wire. Compared from 20AWG wire.
New bell design with upper and lower beam support to reduce damage from collapse of impacts.
Package Included:
1x motor LS2206 1700KV
5x 3mm arm mounting screws
5x 4mm arm mounting screws
1x replacement bell housing screw
1x replacement bell housing washer
1x EMAX Stickers
Pret: 320lei
Tel: 0749 121 132
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 08 October 2018 - 09:30 AM
up 300lei+transport
Andrei
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 17 October 2018 - 07:47 AM
up 300lei.
Andrei
#4 Useril este offline   andrewbt
  • Postari: 1014
Postat 29 October 2018 - 09:45 AM
UP
Andrei
#5 Useril este offline   andrewbt
  • Postari: 1014
Postat 12 November 2018 - 10:48 AM
vandut
Andrei
