Modelism - RHC Forum: Decupare laser pentru modelisti - Modelism - RHC Forum
  • 5 Pagini +
Decupare laser pentru modelisti Vi, tai, pleci... sau bei o cafea
#1 Useril este offline   LaserCut
  • Postari: 289
  • Inregistrat: 08-November 12
Postat 09 November 2012 - 09:27 AM
In Bucuresti, preturi rezonabile pentru modelisti. Maxim 1300x900mm
Detalii PM
#2 Useril este offline   marian.dumitru74
  • ENID
  • Postari: 3965
  • Inregistrat: 13-December 09
  • Interests:RC-ul
Postat 09 November 2012 - 06:12 PM
Vezi postareaLaserCut, la 09 November 2012 - 09:27 AM, a spus:
Detalii PM
Salut,ce material poti taia/decupa?
#3 Useril este offline   ilie F1A
  • Postari: 1250
  • Inregistrat: 17-April 09
Postat 09 November 2012 - 07:31 PM
Un telefon sau adresa.
#4 Useril este offline   LaserCut
  • Postari: 289
Postat 10 November 2012 - 09:48 AM
@Marian: lemn de balsa, placaj, MDF, pal, carton, hartie, mase plastice, textile, piele, pizza :drinks: (nu taie metal)
@ilie F1A: vezi PM
#5 Useril este offline   Para
  • Postari: 462
  • Inregistrat: 20-December 11
Postat 11 November 2012 - 08:40 AM
Fibra de sticla, fibra de carbon, sticlotextolit, taie !? :D
#6 Useril este offline   LaserCut
  • Postari: 289
Postat 11 November 2012 - 08:52 AM
Am incercat pe fibra de sticla mai subtine. O taie dar o si arde, trebuie sa cureti marginile apoi. Fibra de carbon nu cred ca se poate. Sticlotextolit nu am incercat.
#7 Useril este offline   LaserCut
  • Postari: 289
Postat 19 November 2012 - 10:48 PM
O taiere curata fara scrum in placaj de 4mm.
Imagine atasata: exemplu.JPG
Aceasta postare a fost editata de LaserCut: 19 November 2012 - 10:53 PM
#8 Useril este offline   thebd
  • Postari: 21
  • Inregistrat: 16-September 12
Postat 20 November 2012 - 01:28 AM
Un nr de tel/adresa de contact?
  • Postari: 19177
Postat 20 November 2012 - 08:41 AM
Mase plastice, arde marginea? Sau, la cele cu structura poroasa, o topeste si inchide porii ?
Ma refer la Rohacell.
#10 Useril este offline   LaserCut
  • Postari: 289
Postat 20 November 2012 - 09:21 AM
Nu am taiat rohacel. Topeste putin marginea dar nu o arde. Nu taie ca un CNC daca asta doresti sa intrebi.
#11 Useril este offline   LaserCut
  • Postari: 289
Postat 05 December 2012 - 09:37 PM
Se poate si gravura laser nu doar taiere.
#12 Useril este offline   ANDUNG
  • Postari: 493
  • Inregistrat: 11-June 10
Postat 07 December 2012 - 02:33 PM
Placaj de mesteacan 2mm in 4 straturi merge taiat pe CNC?
#13 Useril este offline   LaserCut
  • Postari: 289
Postat 07 December 2012 - 04:40 PM
Am taiat si de 2mm 4 straturi pesteacan si de 3mm cu 5 straturi tot mesteacan. Trebuie doar sa cureti f putin dupa taiere, cam o zecime de mm
Aceasta postare a fost editata de LaserCut: 07 December 2012 - 04:41 PM
#14 Useril este offline   ANDUNG
  • Postari: 493
Postat 14 December 2012 - 05:13 PM
Amabil, operativ si servicii profi, recomand :rolleyes:
#15 Useril este offline   LaserCut
  • Postari: 289
Postat 22 December 2012 - 08:44 AM
Iata si balsa de 6mm:
  • Imagine atasata: taiat P47.jpg
#16 Useril este offline   LaserCut
  • Postari: 289
Postat 09 January 2013 - 10:31 PM
Velier 1m.
Material: MDF 6mm
  • Imagine atasata: velier-6mm-mdf.jpg
#17 Useril este offline   LaserCut
  • Postari: 289
Postat 21 January 2013 - 11:46 AM
Nervuri Nieuport 11
  • Imagine atasata: N11.jpg
#18 Useril este offline   LaserCut
  • Postari: 289
Postat 29 January 2013 - 12:15 PM
Suport servo standard din placaj usor 3mm.9RON
  • Imagine atasata: suport servo standard.JPG
#19 Useril este offline   LaserCut
  • Postari: 289
Postat 06 February 2013 - 10:14 PM
Suport motor:
Imagine atasata: suport motor.JPG
#20 Useril este offline   usulica
  • Postari: 417
  • Inregistrat: 13-April 09
  • Interests:modelism ( navo , auto ) , arte martiale , calatorii , colectii , carti , filme
Postat 09 February 2013 - 04:56 AM
Salut!
Crezi ca poate taia o placa din fibra de carbon de grosime 1 mm ???
Merci!
Aceasta postare a fost editata de usulica: 09 February 2013 - 04:59 AM
Only performance matters!!!
0722733067 / 0744977799 / 0768740960 / 0771661458
YM: cbanica1 , MSN: cbanica
#21 Useril este offline   LaserCut
  • Postari: 289
Postat 09 February 2013 - 07:25 AM
Nu pot taia fibra de carbon. Trebuie sa o faci la un CNC. Carbonul mai mult se arde decat se taie.
#22 Useril este offline   sectoristu
  • Postari: 387
  • Inregistrat: 23-November 10
Postat 11 February 2013 - 06:59 AM
Vezi postareaLaserCut, la 09 February 2013 - 07:25 AM, a spus:
Vreau sa ma apuc de un navomodel am planurile in format electronic (PDF) si as vrea sa stiu in ce format trebuie sa fie pentru debitare laser.
Multumesc
#23 Useril este offline   LaserCut
  • Postari: 289
Postat 11 February 2013 - 09:27 AM
Sunt ok PDF daca informatia cuprinsa in ele este vectoriala. Cel mai bine ar fi sa le trimiti pe taiculaser@gmail.com impreuna cu detaliile despre material.
#24 Useril este offline   C&RDINODINOWOODFAN
  • Postari: 534
  • Inregistrat: 30-September 12
  • Interests:Constructii de tot felul , Pescuit Sportiv ,Drift
Postat 18 February 2013 - 12:23 PM
Multumim pentru ajutor
#25 Useril este offline   gicosu
  • Postari: 1849
  • Inregistrat: 08-May 03
Postat 22 February 2013 - 11:33 PM
Calitate si profesionalism , mersi Bogdan !
  • Imagine atasata: m_DSCN3300.jpg
  • Imagine atasata: m_DSCN3301.jpg
  • Imagine atasata: m_DSCN3302.jpg
  • Imagine atasata: m_DSCN3303.jpg
#26 Useril este offline   gicosu
  • Postari: 1849
Postat 22 February 2013 - 11:36 PM
  • Imagine atasata: m_DSCN3305.jpg
  • Imagine atasata: m_DSCN3307.jpg
  • Imagine atasata: m_DSCN3312.jpg
#27 Useril este offline   LaserCut
  • Postari: 289
Postat 07 March 2013 - 02:32 PM
Suport electronica + intrerupatoare
Imagine atasata: IMG_0047.JPG
#28 Useril este offline   sergiu 4wd
  • Postari: 1553
  • Inregistrat: 20-December 09
  • Interests:RC
Postat 09 March 2013 - 09:40 PM
Am trimis un PM si nu am primit nici un raspuns .
Am o placa de sticlo-textolit dimensiunea unei coli A4 si de 3 mm grosime . Poti sa tai niste forme in ea ? Cat ar costa ? In ce zona a Bucurestiului ai atelierul poate vin intr-o zi sa iti explic despre ce e vorba .
Bafta !
Scurtu Sergiu - 0766301990
#29 Useril este offline   LaserCut
  • Postari: 289
Postat 09 March 2013 - 11:00 PM
Ti-am raspuns la mesaj. Acum am avut acces la computer. Poti veni uni cu placa la mine.
#30 Useril este offline   LaserCut
  • Postari: 289
Postat 19 March 2013 - 04:34 PM
Reduceri pana la sfarsitul lunii. Ex.: 1m taiere placaj usor 4mm 4RON
Gravura 4ron/minut
  • 5 Pagini +
17 useri citesc topicul
0 membri, 17 vizitatori, 0 utilizatori anonimi
