Modelism - RHC Forum: Drona xk x 380 - Modelism - RHC Forum
Drona xk x 380 x380
#1 Useril este offline   asoka
  • Postari: 16
  • Inregistrat: 19-March 16
Postat 23 April 2018 - 04:22 PM
La vanzare drona xk x380, stare foarte buna, putin folosita, fara probleme. Acum este echipata complet cu gimbal camera emitatoare ecran osd. Pretul aici este pentru drona simpla asa cum vine ea cu cutie cu tot plus un rucsac de transport valoare 3 mil dedicat si inca o baterie 2 mil si elici de rezerva dji etc.
Specifications:
Brand name: XK
Model NO.: Detect X380
Item type: Quadcopter
Material: ABS
Controller mode: Mode 2
Remote control frequency: 2.4GHz
Remote distance: 1000m
Suitable ages: Above 14 Years old
Motor: 2212 950KV brushless main motor
Remote distance: about 1000 meters
Charging voltage: 100-240V
Quadcopter battery capacity: 11.1V 5400mAh 20C Li-po
Charging time: about 2 hours
Flight time: more than 30 minutes
Battery dimension: 10 * 4.5 * 3.5cm
Quadcopter dimensions: 30.5 * 30.5 * 21.2cm
Quadcopter weight: 945g
Package information:
Package size: 40.4 * 35.3 * 34.5cm / 15.9 * 13.9 * 13.6in
Package weight: 2466g / 5.4lb
Gift box package
Caution:
This product is not a toy, before flying, please read the manual carefully or under the guidance of the experienced players.
The propellers of the quadcopter should be correctly assembled, otherwise you won't fly it.
If there is no GPS signal (without green light flashing slowly), please do not conduct auto-return operation.
If there is low voltage alarming, please land your quadcopter as soon as possible.
Notice:
This version does not include the camera and the gimbal displayed in the picture above, pls in kind prevail.
Package list:
1 * XK Detect X380 Quadcopter
1 * Transmitter (mode 2)
1 * Battery Charger (EU plug)
1 * 11.1V 5400mAh 20C Li-Po Battery
2 * Pair Propellers for Quadcopter
1 * Camera Fixing Accesssory set
1 * Tool and Cable set
1 * English Manual
Pretul este de 900 lei. Drona plus rucsac plus extra baterie plus elici.
https://www.amazon.c...t/dp/B012HYUVPK
#2 Useril este offline   asoka
  • Postari: 16
Postat 26 April 2018 - 02:57 PM
870
#3 Useril este offline   asoka
  • Postari: 16
Postat 02 May 2018 - 02:06 AM
850
#4 Useril este offline   asoka
  • Postari: 16
Postat 25 May 2018 - 09:17 PM
closed
3 useri citesc topicul
