Modelism - RHC Forum: Recomandare imprimanta 3D - Modelism - RHC Forum
  • 58 Pagini +
  • 54
  • 55
  • 56
  • 57
  • 58
#1651 Useril este offline   gyany_eugen
  • Postari: 977
  • Inregistrat: 17-December 10
  • Interests:Electronica, IT
    Aeromodelism
Postat 08 October 2020 - 09:58 AM
Si haideti sa vedem un pic din carecteristicile motoarelor folosite de Geeetech care cel putin la mine functioneaza pe P3Steel la 48 grade pe X, 54 grade pe Y. Nu am mai masurat pe Z si E care sunt reci. Masuratorile au fost facute la o viteza de 70mm/s.
Am ramas surprins sa constat ca motoarele la de la Geeetech au inductanta 6,2 mH. https://www.geeetech...ter-p-1011.html
Ei zic asa: Hybrid stepper motor 42SHD0034-20B for 3D printer ,,This is the stepper motor we use on the X/Y/Z axis for Geeetech Prusa I3 and Delta series 3D printers"
General specification
Step angle: 1.8°
Number of phase:2
Insulation resistance:100MΩmin. (500V DC)
Insulation class:Class B
Rotor inertia:38g cm2
Mass:0.2kg
Wiring length: 700mm
Connector: XH (2.54mm-4pin)
Net weight: 232g
Shipping weight: 310g
Electrical specification
Rated voltage:5V
Rated current: 1.0A (aici am editat, caci pe site la ei e o greseala fiind trecut voltage in loc de current)
Resistance per phase: 5.0Ω±10%
Inductance per phase: 6.2mH±20%
Holding torque: 300mN.m
Detent torque: 12mN.m
Un calcul in tabelele de mai jos, in primul modificand doar inductanta, in cel de al doilea modificand si curentul.
  • Imagine atasata: tabel 4.jpg
  • Imagine atasata: tabel 5.jpg
Turnigy 9x -Er9x
#1652 Useril este offline   mihaighe
  • Postari: 460
  • Inregistrat: 29-January 10
Postat 08 October 2020 - 10:05 AM
Vezi postareagyany_eugen, la 07 October 2020 - 11:47 AM, a spus:
Piulite canal T m3, m4, m5
Vezi ca piulitele alea de M5 patrate cam joaca pe canal si te chinuie,mai bine comanzi de alea dreptunghiulare ca sant fix pe canal.
#1653 Useril este offline   mihaighe
  • Postari: 460
Postat 08 October 2020 - 10:10 AM
Vezi postareagyany_eugen, la 08 October 2020 - 07:25 AM, a spus:
Haha.
Na ca l-am prins si pe dl. Mihai online.
Te-am ajutat ca am putut si mi-a placut ca nu te lasi,spor in continuare ,ne mai auzim.
Urmaresc cu interes imprimanta ta cea noua.
#1654 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 08 October 2020 - 10:27 AM
Vezi postareamihaighe, la 08 October 2020 - 10:05 AM, a spus:
Chiar acum ma jucam cu ele. Le-am luat de la Stefan. Altceva nu avea in stoc si nu am rabdare sa mai astept. Am folosit si la Hypercube piulite patrate si sunt ok. Imi plac alea cu bila, postmontaj dar nu gasesc nicaieri.
Turnigy 9x -Er9x
#1655 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 08 October 2020 - 11:17 AM
Vezi postareamihaighe, la 08 October 2020 - 10:10 AM, a spus:
Nu pot spune decat multumesc... nu mai insist. Gasesc eu o modalitate de revansa.
De lasat nu ma las, numai sa ma tina puterile. Imi plac provocarile.
A fost un proiect frumos. Axe cromate de la Geeetech, LCD, motoare, fulii, sursa. Am folosit bucse sinterizate SKF. A fost greu de reglat colinearitatea precum si presiunea pe ele, a trebuit sa reproiectez scaunele bucselor, dar odata facute lucrurile astea merge ca masina de cusut. Am ramas surprins de nivelul de zgomot redus, care nu cred ca il voi obtine cu ghidajele liniare. O sa vedem ce va iesi.
Deocamdata macar doua fotografii. Nu mai am rabdare, si nici putere sa fac un build log, desi merita din plin. In foto 4 printeaza acum pentru imprimanta noua.
  • Imagine atasata: zzz.jpeg
  • Imagine atasata: P3Steel.jpeg
  • Imagine atasata: zz.jpeg
  • Imagine atasata: P3steel1.jpg
Aceasta postare a fost editata de gyany_eugen: 08 October 2020 - 11:21 AM
Turnigy 9x -Er9x
#1656 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 11 October 2020 - 08:29 AM
Pentru Djtaotao, in special, dar nu numai.
Pana la urma, inevitabilul s-a intamplat. Vineri am lipsit 5 minute de langa laptop si cand m-am intors l-am gasit pe ecran de boot. A picat hardul. Toate bune si frumoase, 99,99% din fisiere le aveam salvate. Nu stiu cum, dar se pare ca Marlin-ul pentru ambele imprimante nu l-am salvat nicaieri.
Am facut cu Avrdude backup, la ambele imprimante, la flash si eeprom. Bineinteles ca fisierele sunt cu extensia hex. Ceea ce ma intereseaza mai mult sunt configuration.h, configuration_adv.h si pins.h.
Din curiozitate si pentru a nu mai configura Marlinul inca o data pentru ambele imprimante, vin cu o intrebare.
Exista posibilitatea de a face aceste fisiere human readable? Stiu ca e greu, dar nu imposibil si nu stiu daca merita efortul. Cu M503 obtin prea putine informatii.
Asasez un print screen la backup-ul cu Avrdude.
Multumesc. :drinks:
  • Imagine atasata: eepromcmd.png
Turnigy 9x -Er9x
#1657 Useril este offline   bbogdanmircea
  • Postari: 267
  • Inregistrat: 25-October 07
Postat 11 October 2020 - 09:03 AM
Păi hex e codul mașină.
Dacă știi zonele în care sunt stocate valorile parametrilor care te interesează ai putea.
Dar cred că majoritatea valorilor le poți vedea în consolă cu comenzi GCODE gen M503, parcă mai stau și altele.
#1658 Useril este offline   djtaotao
  • Postari: 995
  • Inregistrat: 27-January 11
Postat 11 October 2020 - 04:09 PM
M503 folosesc si eu ca sa aflu valorile cand fac Marlin nou, dar doar pt valori, pentru restul configuratiei nu stiu ce variante ai.
Ma mai folosesc de functia de compare din notepad++ cand vreau sa compar versiuni de fisiere *.h. Vezi, poate te ajuta notepad++ la fisierul hex, macar sa-l deschizi.
#1659 Useril este offline   bbogdanmircea
  • Postari: 267
Postat 11 October 2020 - 04:14 PM
Poți face reverse engineering ptr același tip de Marlin, pui niște setări și generezi .hex apoi modifici dolari setare generezi și compari hex și vezi adresa unde se schimbă în hex.
E posibil să fi făcut asta cineva deja și să fie adresele pe undeva pe net.
#1660 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 11 October 2020 - 05:41 PM
Vezi postareadjtaotao, la 11 October 2020 - 04:09 PM, a spus:
:drinks: Fisierul l-am deschis si cu notepad din windows. Problema e ca nu vad decat ceea ce se vede si in imagine. Am incercat si cu Notepad ++ si rezultatul e acelasi. Am incercat sa atasez si fisierul hex dar zice ca nu este permis acest tip de fisiere.
Turnigy 9x -Er9x
#1661 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 11 October 2020 - 05:51 PM
Vezi postareabbogdanmircea, la 11 October 2020 - 04:14 PM, a spus:
M-am gandit si la asa ceva, dar cred ca mi-ar luat prea mult timp si nu stiu daca ajung la un rezultat.
Sa explic de ce as fi dorit sa fac lucrul asta. La Prusa I3Steel am folosit LCD-ul de la Geeetech, Reprap Discount LCD. Toate bune si frumoase, doar ca nu reuseam sa il fac sa functioneze. Teoretic e la fel cu oricare alt LCD 2004, dar practic nu e. Difera dimensiunile, dar asta am rezolvat-o proiectand carcasa, dar cel mai nasol a fost ca am sapat o saptamana pana cand mi-am dat seama ca a trebuit sa modific in pins.h pentru a il face sa functioneze. Asta e problema, ca dupa 7 luni, nu imi mai amintesc ce. :blush:
In rest nu e problema cu configuration.h nici configuration_adv.h nici cu Prusa nici cu Hypercube, astea le scriu repede.
Turnigy 9x -Er9x
#1662 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 11 October 2020 - 06:19 PM
Scuze, nu stiu de ce nu a luat foto. Atasez din nou. Se vede doar o parte din continut. Imagine atasata: eeprom.jpg
Aceasta postare a fost editata de gyany_eugen: 11 October 2020 - 06:24 PM
Turnigy 9x -Er9x
#1663 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 11 October 2020 - 06:34 PM
Hai ca era dimplu, doar ca nu ma mai duce mintea. Pun aici ceea ce se vede cu Notepad. :clapping: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Turnigy 9x -Er9x
#1664 Useril este offline   bbogdanmircea
  • Postari: 267
Postat 11 October 2020 - 07:01 PM
FF înseamnă nimic.
Atâta lucru pot să-ti spun.
#1665 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 11 October 2020 - 07:29 PM
Vezi postareabbogdanmircea, la 11 October 2020 - 07:01 PM, a spus:
FF înseamnă nimic.
Stiu si e ,,super". De regula fff se refera la culoare. Fisierele flash si eeprom sunt raportate ca ok doar ca trebuie rescrise cu programator din cate imi dau seama. Asta e. Bine ca am sincronizat restul in cloud.
Firmware-ul il rezolv eu mai greu sau mau usor, dar daca pierdeam amintirile era mai urat. Oricum... o saptamana de caca. Ce incepe rau se termina rau. Azi sm facut 80 km pentru 200 saibe m5/15mm/1mm tot pt. imprimanta. In oras nu am gasit decat m5/15/1,5.
Turnigy 9x -Er9x
#1666 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 12 October 2020 - 08:44 AM
:good: Mare dreptate aveti. Prind foarte putin din marginile profilului. Daca piulite canal nu am gasit, m-am gandit la o alta solutie. In felul acesta suprafata de contact cu profilul este mult mai mare si se centreaza perfect. Doar ca e munca multa. Doua trasari pe fiecare saiba si doua taieturi.
  • Imagine atasata: 20201012_092556.jpg
  • Imagine atasata: 20201012_092705.jpg
  • Imagine atasata: 20201011_084226.jpg
Turnigy 9x -Er9x
#1667 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 12 October 2020 - 12:59 PM
Cam atat pe astazi.
  • Imagine atasata: 20201012_135528.jpg
Turnigy 9x -Er9x
#1668 Useril este offline   bbogdanmircea
  • Postari: 267
Postat 12 October 2020 - 04:10 PM
Vezi postareagyany_eugen, la 11 October 2020 - 07:29 PM, a spus:
Recomand pentru fiecare imprimanta de facut cate un proiect pe GitHub si se pot mentine acolo fisierele importante din configuratia SW, fisiere HW sau mecanica care sunt unicat pentru acea imprimanta, notite, etc.
Si cu ocazia asta mai inveti si Git sau poti folosi un plugin gen Tortoise Git.
Eu cam asa incerc sa fac cu proiectele cele mai importante desi recunosc ca un backup fizic la partitia cu proiecte nu am mai facut de multisor pe HDD-ul de backup.
In alta ordine am mai dat si eu drumul la un print de cateva ore, pare sa mai mearga Hypercub-ul, desi serverul de Repetier de pe RPi3 care comanda imprimanta
mai da eroare, de exemplu s-a oprit in mijlocul printului vreun minut fara sa faca nimic, timp in care hotendul imi topea piesa si curgea material din el ...
Cred ca ar trebui sa incerc un server de Octoprint, dar lenea e mare.
Voi ce solutii folositi pentru controlul imprimantei, vizualizare remote la ce se intampla, oprire de siguranta etc???
#1669 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 12 October 2020 - 06:00 PM
Vezi postareabbogdanmircea, la 12 October 2020 - 04:10 PM, a spus:
:good: Asa ar fi trebuit sa fac, dar sincer nu imi mai ajunge timpul. Sau ar fi fost mai simplu sa le salvez pe hhd extern sau in cloud.
Si cand ai scris asta, Bogdan, m-a apucat tremuricii. Nu stiu cum, dar am reusit performanta sa nu salvez mai nimic legat de 3DPrint. Abia acum mi-am dat seama ca am pierdut in proportie de 90% si din ceea ce am proiectat.
Nu ai posibilitatea de a printa de pe sd?
Vizualizare remote nu folosesc. De cand l-am pierdut pe tata, mai stau ziua cu mama sa o mai sustin, mai las imprimanta functionand cand plec, si ne mai auzim la telefon. Ea o inchide cand termina de printat. Se pot face multe, dar timpul este scurt. Azi m-am apucat de lucru la 6.30 si dupa 9 ore de lucru, mi se parea ca nu am facut nimic.
Nu am avut probleme de niciun fel inafara de penele de curent, care din fericire au fost la 2 - 5 - 10 minute de la start.
Tot in Germania? Asa zicea Stefan.
Turnigy 9x -Er9x
#1670 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 13 October 2020 - 08:23 AM
La treaba din nou.
Desi in BOM la numarul de coltari e trecut 16, mai printez inca 16 pentru a acoperi fiecare colt.
  • Imagine atasata: 20201013_091455.jpg
Turnigy 9x -Er9x
#1671 Useril este offline   bbogdanmircea
  • Postari: 267
Postat 15 October 2020 - 10:42 PM
Va apreciez rabdarea si migala cu care va construiti imprimantele.
Din pacate eu ca softist nu posed aceste calitati, la mine e important doar sa mearga.
Momentan imi dau batai de cap generarea suportilor interiori la piese, se lipesc prea tare
mai ales in partea de jos si sus si trebuie sa-i rup bucata cu bucata dupa ce se termina piesa.
Folosesc setarile default din Cura, presupun ca ceva nu e in regula.
Sfaturi cum as putea sa calibrez sa fie ok?
#1672 Useril este offline   djtaotao
  • Postari: 995
Postat 15 October 2020 - 10:54 PM
Setarile default, 15% densitate, zig-zag, cu 0.1mm distanta pe Z-top/bottom ar trebui sa fie ok si sa se deprinda usor.
#1673 Useril este offline   bbogdanmircea
  • Postari: 267
Postat 15 October 2020 - 11:12 PM
Default am si eu dar eu printez la 210 PLA poate de asta se topește mai tare și se unește suportul cu piesa.
#1674 Useril este offline   djtaotao
  • Postari: 995
Postat 15 October 2020 - 11:14 PM
Poti incerca sa maresti z distance, la 0.15mm.
#1675 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 16 October 2020 - 06:49 AM
Vezi postareabbogdanmircea, la 15 October 2020 - 10:42 PM, a spus:
Acum nu folosesc Cura, dar poate ajuta: 15% infill, extra inflation distance 0.00 mm, support base layers 2, combine support every 1 layer, dense support layers 0, dense infill percentege 50%, support type normal, support pillar resolution 1.00 mm, max overhang angle 45%, horizontal offset from part 0,4, upper vertical separation layers 1, lower separation layers 1, support infill angles 45, -45.
Momentan am schimbat filamentul pentru o alta lucrare si nu printez pentru imprimanta. Piesele care le printez acum nu au nevoie de suporti, iar piesele care le am deja printate pentru imprimanta au suportii desprinsi, dar la prima piesa printata cu suporti pentru imprimanta voi face niste poze mai detaliate cu aparatul foto, caci ceea ce iese cu telefonul nu prea reflecta realitatea. Mi-am batut ceva vreme capul exact cu aceeasi problema dar acum se desprind foarte usor, iar materialul depus pe suporti iese in forma scontata. Cred ca si temperatura are un efect asupra adeziunii suportilor la straturile piesei. Eu merg cu 230 first layer si 225 in rest, no cooling, PETG. Cateva grade pot face diferenta.
Daca ajuta cu ceva iti pot trimite un fisier gcode sau profilul fff, dar pentru PETG. Dai ai un print sa vedem ce iese si apoi comparam cu ce imi iese mie.
Multumesc pentru apreciere. Nu e nevoie sa folosim persoana a II-a plural. :good:
Trebuie doar timp si rabdare. Ieri am constatat ca am printat degeaba coltarii suplimentari. Sunt cu 2 mm mai lungi fata de ceea ce am nevoie. Si cand sa ma apuc de proiectat altii, am zis sa plect la ,,vanatoare'' prin magazine. Am gasit niste coltari metalici la un magazin de bricolaj.
Cadrul iese foarte rigid si in cote, dar e al naibii de greu de montat cu coltarii dublati, e inghesuit tare. Daca nu aveam rabdare probabil, ca adunam toti sfintii prin casa.
Turnigy 9x -Er9x
#1676 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 16 October 2020 - 12:34 PM
Gata partea de jos a cadrului. Trei zile de munca. Ce a ramas in sus e usor. Nu a scapat niciun surub fara saiba. A iesit foarte rigid.
  • Imagine atasata: 1.jpeg
  • Imagine atasata: 2.jpeg
Turnigy 9x -Er9x
#1677 Useril este offline   mihaighe
  • Postari: 460
Postat 18 October 2020 - 05:41 PM
Vezi postareagyany_eugen, la 16 October 2020 - 06:49 AM, a spus:
vezi ca la magazine de fierarie gasesti coltari si teuri potrivite pentru imprimanta,se folosesc la tamplarie pentru geamuri.
vad ca iese frumos cadrul ,spor la construit.
Aceasta postare a fost editata de mihaighe: 18 October 2020 - 05:43 PM
#1678 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 18 October 2020 - 06:58 PM
Vezi postareamihaighe, la 18 October 2020 - 05:41 PM, a spus:
Multumesc. :drinks:
Ce fel de coltare si t-uri sunt? O poza sau un link?
Si acum alta problema.
O recomandare cine ar putea sa imi taie minunea din imagine Al 3mm (nu retin exact denumirea materialului sau aliajului)? Am fisierul dxf. Problema e ca doresc cat mai repede.
  • Imagine atasata: 1.jpg
Turnigy 9x -Er9x
#1679 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 19 October 2020 - 03:55 PM
Atat pe astazi. Am proiectat si printat stopper-ele pentru ghidajele liniare (cele din proiectul original sunt firave si nu sunt fixate decat prin presare in gaurile ghidajelor) si am pregatit suruburile cu piulitele T slot pentru fixarea ghidajelor.
  • Imagine atasata: 4.jpg
  • Imagine atasata: 5.jpg
Turnigy 9x -Er9x
#1680 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 19 October 2020 - 03:56 PM
  • Imagine atasata: 3.jpg
Turnigy 9x -Er9x
  • 58 Pagini +
  • 54
  • 55
  • 56
  • 57
  • 58
11 useri citesc topicul
