• Plug and play lightweight FPV goggles
• 5" TFT monitor with magnification lens
• 800 x 480 non blue screen monitor
• Neoprene foam cushioning stripes for added comfort
• Fully adjustable 3 position head strap
• Durable lightweight plastic design
• On screen menu with adjustable brightness, contrast and color controls
• Single button automatic channel scanning and manual search function
• Built-in 40 channel receiver
• Auto select between integrated receiver or external video source
Specs:
Weight: 258g
Dimensions: 168 x 158 x 105
Monitor: 16.9
Resolution: 800 x 480
Receiver: 40 channels
Working Voltage: 7-15v 2s ~ 4s
Operating Temperature: -20 ~ 80 degrees
Power Dissipation: 300mAh
Display: Power display function
Video Format: NTSC / PAL (automatic ID)
Channel Range: 5.645 ~ 5.945Ghz
Package Includes:
1 x Goggles
1 x Head Strap
2 x Eye Ring
1 x 5.8Ghz antenna
1 x Power extension cord
2 x Velcro strips
1 x Nose foam mount
Note: The goggles have a built-in T Connector. To use batteries with other connector types a battery adapter will be required. Please see related items.
Pret 230 lei.
