Modelism - RHC Forum: Mini quad Q-BOT - Modelism - RHC Forum
Mini quad Q-BOT w/2.4gHz RF Module (Spektrum/JR/Futaba)
#1 Useril este offline   Adyn
  • Postari: 1142
  • Inregistrat: 30-August 07
Postat 16 December 2016 - 10:53 AM
Mini quad Q-BOT care poate fi folosit cu o telecomanda de aero Spektrum, JR, Futaba, Hitec, Turnigy, Walkera sau altele. Vone cu modul de2,4 GHz care se cupleaza pe mufa de Ttrainer si foloseste semnal PPM.
Se vinde cu 3 acumulatori si 2 seturi elici de schimb.
A fost folosit doar de citeva ori prin casa.
Functioneaza perfect
Pret 150 ron
Tel 0788238330
e-mail: syscad@gmail.com
Mai jos aveti caracteristici
Features:
• 2.4gHz RF module allowing for use with your own transmitter*
• 6-axis gyro stabilization system
• Ultra stable flight characteristics
• Aerobatic flight mode allowing for flips, rolls and loops
• Compact and lightweight design
*Note: Your Transmitter must have a trainer port (JR style 3.5mm or Futaba style 6-pin) and be capable of outputting PPM signal.
Quadcopter Specs:
Width: 125mm
Height: 35mm
Weight: 26g (w/out battery)
RF Module Specs:
Battery: 3.7V LiPoly Battery 120mAh
Operating Voltage: 3.7~12V DC
Operating Current: ≤ 100 mA
Operating Frequency: 2.4gHz
Spread Spectrum Mode: FHSS
Number of Frequency Channels: 20
Hopping Rate: 240 Jump/s
Included in box:
Q-BOT Micro Quadcopter
2.4gHz RF module
3.7V 20C 250mAh LiPoly battery x 2
USB dual battery charger
Spare propellers (2 x Black, 2 x Orange)
Screwdriver
Required:
Your own 4CH (5CH or more required for aerobatic mode) transmitter with trainer port (JR style 3.5mm or Futaba style 6-pin)
Fisier atasat  IMG_20161216_103027_.jpg (77.78K)
Fisier atasat  IMG_20161216_103131_.jpg (124.47K)
Fisier atasat  IMG_20161216_103227_.jpg (108.32K)
#2 Useril este offline   Adyn
  • Postari: 1142
Postat 24 December 2016 - 12:47 AM
up
#3 Useril este offline   Adyn
  • Postari: 1142
Postat 01 April 2017 - 12:08 AM
vandut
