Modelism - RHC Forum: Regulator Traxxas EVX-2 si Stabilizator Guardian 2D/3D - Modelism - RHC Forum
#1 Useril este offline   razAlexandru
  • Postari: 4
  • Inregistrat: 01-October 15
Postat 05 October 2015 - 10:35 AM
Vand Regulator Brushed Traxxas EVX-2
180A -forward/reverse
For 16 volt dual battery, dual motor setups
Three programmable drive profiles
Full-proportional reverse with brakes
EZ-Set push button setup
Waterproof design for running in mud, snow and other wet running conditions
Low voltage detection for use with LiPo batteries
SPECIFICATIONS
Input Voltage: 6-14 NiCd, NiMH OR 2S-4S LiPo
Case Size: 2.27 x 2.0 x 1.05" (58 x 51 x 27mm)
Weight: 4.1oz (116g) w/heat sink, 3.6oz (102g) w/o heat sink
Motor Limit (550 size): 12 turns
Rated Current Forward/Reverse: 180 amps
Braking Current: 360 amps
BEC Voltage: 6.0 volts DC
BEC Current: 2.5 amps
Protection: Thermal shutdown
Pret: 200lei
Eagle Tree Guardian 2D/3D Stabilizer
Features:
• 3D aerobatic flight mode
• 2D flight mode (wing leveling)
• Heading hold/direct rate sub-modes
• Remote mode selection (from transmitter switch)
• Automatic turn coordination
• Easily adjustabe stabilization gains
• Supports standard fixed wing, delta and v-tail configurations
Specs:
Input voltage: 4.5~16VDC
Current draw: 31mA
Weight: 11g
Dimensions: 41x22x11mm
Pret: 150lei
ambele in stare perfecta; telefon:0761969785
Predare personala in Bucuresti la Piata Presei Libere, trimit si prin curier.
#2 Useril este offline   razAlexandru
  • Postari: 4
Postat 09 October 2015 - 10:29 PM
Stabilizatorul - vandut
Regulatorul este inca valabil.
