Modelism - RHC Forum: Quad, ESCuri, Gimbal, Tren ateriz. - Modelism - RHC Forum
Quad, ESCuri, Gimbal, Tren ateriz. Elici, Lipo 5000mAh/610mAh, diverse
#1 Useril este offline   icsss
  • Postari: 2085
  • Inregistrat: 16-May 10
Postat 02 September 2015 - 01:22 PM
Am trecut la casa 250, prin urmare vand urmatoare:
ESC Mystery 30A Simonk - 4 buc - 44 RON/buc --> http://www.hobbyking...ue_Series_.html
Motor 2830-11 1000 KV - 4 buc - 29 RON/buc --> http://www.rctimer.c...roduct-121.html si doua de aici: http://www.hobbyking...less_Motor.html
Adaptoare motor - 4 buc - 5 RON/buc --> http://www.rctimer.c...roduct-545.html
Frame Famous 550 (2 seturi de brate) - 1 buc - 305 RON --> http://www.goodluckb...e-aircraft.html
Elici 9050 tripala (3+3) - 6 buc - 4 RON/buc --> http://www.hobbyking...otate_2pc_.html
Ax motor 2830-11 - 3 buc - 4 RON/buc
Adaptoare + suport motor - 3 buc - 8 RON/buc
Piese schimb 2830-11 1000 KV - 23 RON
TOTAL pachet (nu se da pe bucati): 700 RON + transport
Quadul l-am incarcat pana la putin peste 1600g (FPV, tren, gimbal, foto compact, 5000mAh) si duce OK.
Dar l-am zburat si ca platforma FPV pentru flipuri/rolluri, etc. (1100g, ~12-13 min. timp de zbor cu 5000mAh)
Pe langa bratele de aluminiu am se dau si bratele originale.
ESC Mystery 30A (1 cu Simonk si unul soft stock) - 2 buc - 44 RON/buc --> http://www.hobbyking...ue_Series_.html
Tren aterizare - 1 buc - 30 RON --> http://www.goodluckb...kit-yellow.html
Gimbal 2 axe - 1 buc - 80 RON
Lipo 3s 5000mAh 20C (rezistenta interna 6,4,6) - 1 buc - 37 RON --> http://www.hobbyking...idProduct=35834
Lipo 3s 5000mAh 20C (rezistenta interna 5,4,6) - 1 buc - 50 RON --> http://www.hobbyking...idProduct=35834
Lipo 3s 610mAh 20C (rezistenta interna 48,38,35 L-am folosit doar pentru alimentare sistem FPV) - 1 buc - 17 RON --> https://www.hobbykin...idProduct=50125
Elici 1150 Gemfan - 6 buc - 32 RON/set --> http://flyduino.net/...-Black-2CW-2CCW
Elici 1045 (4+4) - nefolosite - 8 buc - 25 RON/set --> http://www.hobbyking...Warehouse_.html
Elici 1045 Carbon (3+3 - o elice putin ciobita) - 6 buc - 81 RON/set --> http://www.rctimer.c...roduct-660.html
Elici 1045 (4+1) - 5 buc - 2 RON/buc --> http://www.hobbyking...c_CCW_2pc_.html
* mare parte din elici sunt deja echilibrate pe stand magnetic
Adaptoare 2830-11 clema pe ax - 10 buc - 2 RON/buc
Camera FPV - 1 buc - 45 RON --> http://www.hobbyking...amera_PAL_.html
FC KK1 - 1 buc - 15 RON
Daca un pret nu vi se pare OK, astept PM.
  • Fisier atasat  s-04.jpg (146.75K)
  • Fisier atasat  s-08.jpg (149.9K)
  • Fisier atasat  s-06.jpg (175.47K)
Aceasta postare a fost editata de icsss: 02 September 2015 - 01:22 PM
#2 Useril este offline   icsss
  • Postari: 2085
Postat 02 September 2015 - 01:24 PM
  • Fisier atasat  s-12.jpg (206.37K)
  • Fisier atasat  s-05.jpg (167.45K)
  • Fisier atasat  s-01.jpg (158.33K)
  • Fisier atasat  s-16.jpg (130.41K)
  • Fisier atasat  s-25.jpg (118.68K)
#3 Useril este offline   icsss
  • Postari: 2085
Postat 02 September 2015 - 01:25 PM
  • Fisier atasat  s-24.jpg (129.53K)
  • Fisier atasat  s-23.jpg (132.68K)
#4 Useril este offline   icsss
  • Postari: 2085
Postat 02 September 2015 - 01:29 PM
  • Fisier atasat  s-02.jpg (154.23K)
  • Fisier atasat  s-09.jpg (141.87K)
  • Fisier atasat  s-10.jpg (146.23K)
  • Fisier atasat  s-07.jpg (130.46K)
  • Fisier atasat  s-13.jpg (171.6K)
  • Fisier atasat  s-14.jpg (142.2K)
  • Fisier atasat  s-15.jpg (148.85K)
  • Fisier atasat  s-17.jpg (139.62K)
  • Fisier atasat  s-18.jpg (127.06K)
  • Fisier atasat  s-19.jpg (136.27K)
  • Fisier atasat  s-20.jpg (137.01K)
  • Fisier atasat  s-21.jpg (131.5K)
  • Fisier atasat  s-22.jpg (122.49K)
Aceasta postare a fost editata de icsss: 02 September 2015 - 01:29 PM
#5 Useril este offline   icsss
  • Postari: 2085
Postat 02 September 2015 - 01:33 PM
Aceasta postare a fost editata de icsss: 02 September 2015 - 01:33 PM
#6 Useril este offline   nxpress
  • Postari: 58
  • Inregistrat: 12-October 13
Postat 02 September 2015 - 01:59 PM
eu vreau in primul rand camera si trenul !
as vrea si 2-3 rc timer 2830-11 1000 KV dar vad ca nu dai separat ..
elicile
Elici 1150 Gemfan - 6 buc - 32 RON/set .. setu e celde de 4 ?
noob
#7 Useril este offline   icsss
  • Postari: 2085
Postat 02 September 2015 - 02:07 PM
Vezi postareanxpress, la 02 September 2015 - 01:59 PM, a spus:
elicile
Un set = numarul de bucati disponibile. In alte cuvinte, nu le dau la bucata, ci doar la set.
Ai PM.
#8 Useril este offline   yjytya
  • Postari: 233
  • Inregistrat: 15-April 15
Postat 02 September 2015 - 06:22 PM
Salut! Daca mai sunt valabile elicile 1150 Gemfan si cele 1045 nefolosite, le vreau eu. Multumesc!
#9 Useril este offline   Lord_Thor
  • Postari: 213
  • Inregistrat: 24-August 14
Postat 02 September 2015 - 07:59 PM
Salut vreau eu bateria de 37ron...astept mesaj pe prv...ms
Never say never...
#10 Useril este offline   icsss
  • Postari: 2085
Postat 02 September 2015 - 08:54 PM
Aveti mesaje pe privat ;)
#11 Useril este offline   nxpress
  • Postari: 58
Postat 03 September 2015 - 12:25 PM
renunt nu mai iau nimic nu imi convin conditiile ca suspect... in care doar eu as avea de pierdut .
Aceasta postare a fost editata de nxpress: 03 September 2015 - 12:27 PM
noob
#12 Useril este offline   nxpress
  • Postari: 58
Postat 03 September 2015 - 12:36 PM
omu daca nu vrea sa iti ridice coletu nu te mai pune sa trimiti, ca nu are nimic de castigat ...daca il pui sa iti plateasca tot inainte poate ramane cu buza umflata ... Adica e suspect omu care nu ar avea nimic de castigat. dar nu e suspect si cel care ar primi bani degeaba fara sa dea nimic ... deasta tanzactiile de genu sunt mai mult decat dubioase.
Aceasta postare a fost editata de nxpress: 03 September 2015 - 12:40 PM
noob
#13 Useril este offline   icsss
  • Postari: 2085
Postat 03 September 2015 - 12:38 PM
Vezi postareanxpress, la 03 September 2015 - 12:25 PM, a spus:
renunt nu mai iau nimic nu imi convin conditiile de suspect in care doar eu as avea de pierdut .
Da, imi pare rau, dar livrare cu ramburs (partial) prin posta romana la Post Restant nu-mi cade bine. Cozi, timp si batai de cap.
Prefer: plata in avans 100% + livare prin curier/posta roamana.
Dar merge si: 70 ron in avans + livrare cu ramburs prin curier (fara posta romana).
#14 Useril este offline   icsss
  • Postari: 2085
Postat 03 September 2015 - 12:49 PM
Vezi postareanxpress, la 03 September 2015 - 12:36 PM, a spus:
Opreste-te aici pentru ca nu-i cazul sa starnesti o polemica inutila.
Astea-s conditiile in care trimit si punct.
1) Plata in avans 100% + livare prin curier/posta roamana.
sau 2) 70 ron in avans + livrare cu ramburs prin curier (fara posta romana).
Aceasta postare a fost editata de icsss: 03 September 2015 - 12:50 PM
#15 Useril este offline   H7-25
  • Postari: 242
  • Inregistrat: 28-June 12
  • Interests:modelism, fishing, surveying
Postat 03 September 2015 - 09:44 PM
Am lasat mesaj pt. li-po 3s 5000mah.
In God we trust, all others must pay cash!
#16 Useril este offline   Doru Brad
  • Postari: 165
  • Inregistrat: 25-June 15
Postat 04 September 2015 - 12:41 PM
Va salut,
Din lista de mai sus ce mai este inca disponibil?
Lipo 3s 5000mAh 20C mai este careva disponibil?
#17 Useril este offline   icsss
  • Postari: 2085
Postat 04 September 2015 - 01:03 PM
Elici 1045 Carbon (3+3 - o elice putin ciobita) - 6 buc - 81 RON/pt toate 6 --> http://www.rctimer.c...roduct-660.html
Flight Controller KK1 - 1 buc - 15 RON
Aceasta postare a fost editata de icsss: 04 September 2015 - 01:05 PM
#18 Useril este offline   icsss
  • Postari: 2085
Postat 07 September 2015 - 09:54 AM
Quadul se da si fara frame/elici, astfel:
Piese schimb 2830-11 1000 KV - 23 RON (cel putin un motor complet)
TOTAL pachet (se da si fara ESCuri): 371 RON + transport
Elici 9050 tripala (3+3)-6 4 buc (2+2) - 16 RON/4buc
Aceasta postare a fost editata de icsss: 07 September 2015 - 09:56 AM
#19 Useril este offline   PETT
  • Postari: 362
  • Inregistrat: 26-May 15
Postat 07 September 2015 - 10:57 AM
Vezi postareaicsss, la 07 September 2015 - 09:54 AM, a spus:
Salut! Daca se poate, as dori o rezervare, pana pe 15, la camera, kk.1 si 3s-ul de 610. Un pret pentru toate? Vineri ajung in Iasi. Daca reusesc sa fac banii pana atunci, poate ne vedem. Oricum, mi-ar face placere sa te cunosc, dat fiind ca sunt din Vaslui si incerc sa ma stiu cu modelistii din zona, Cu stima, Petru
Aceasta postare a fost editata de PETT: 07 September 2015 - 11:01 AM
#20 Useril este offline   icsss
  • Postari: 2085
Postat 07 September 2015 - 11:44 AM
Vezi postareaPETT, la 07 September 2015 - 10:57 AM, a spus:
Salut, n-ai rezervare, dar ai PM :) si te astept cu placere la un zbor intr-un weekend cu soare :)
#21 Useril este offline   icsss
  • Postari: 2085
Postat 10 September 2015 - 10:35 PM
Mai adaug si un servo foarte bun, HGD(inolab) digital 261HB Carbon Gear Servo 20g / .06sec / 2.4kg - aproape nou, pana in 10 zboruri. - pret 110 lei
Elici 1045 Carbon (3+3 - o elice putin ciobita) - 6 buc - 81 RON/6 buc --> http://www.rctimer.c...roduct-660.html
Aceasta postare a fost editata de icsss: 10 September 2015 - 10:37 PM
#22 Useril este offline   icsss
  • Postari: 2085
Postat 18 September 2015 - 11:43 PM
frame quad, tren aterizare, gimbal si servo inolab --> negociabil
Aceasta postare a fost editata de icsss: 18 September 2015 - 11:44 PM
#23 Useril este offline   icsss
  • Postari: 2085
Postat 11 October 2015 - 08:04 PM
hai ca se dau si la bucata, motare, escuri, etc..
#24 Useril este offline   Zeus
  • Postari: 2455
  • Inregistrat: 15-January 09
Postat 11 October 2015 - 10:53 PM
Salut, daca motoarele sunt noi si complete, ma intereseaza 2 cred...
#25 Useril este offline   icsss
  • Postari: 2085
Postat 19 October 2015 - 11:45 PM
Aici s-au cam ametit lucrurile.
Ce a ramas la vanzare gasiti in topicul asta:
http://www.rhcforum....l-elici-carbon/
10 useri citesc topicul
