Modelism - RHC Forum: motoare brushless si brushed - Modelism - RHC Forum
#1 Useril este offline   laurcon
  • Postari: 804
  • Inregistrat: 26-October 09
Postat 20 June 2014 - 09:00 AM
1) Turnigy 540S V-Spec Inrunner w/ Impeller 1350kv
High torque inrunner, excellent for running propellers without needing a gearbox.
The unique stator design creates a low current and high torque motor great for outrunner replacements and much more efficient than inrunners of the same size.
Dimension: 52mm x 36mm, 66mm(with shaft)
Weight: 141g (kv1350) (not including connectors)
Diameter of shaft:5mm
Length of front shaft:13mm
Lamination thickness: .2mm
Spec.
Battery: 3-4 Cell 4S/14.8V
RPM: 1350kv
Max current: 40A
No load current: 2.1A
Internal resistance: 75.2ohm
Data:
3S 11.1V
Prop: APC7x4, APC10x4.7
Max Current: 16.6A, 37A
Pull: 720g, 1260g
4S 14.8V
Prop: APC7x4
Max Current: 29A
Pull: 1100g
ESC: 60A
Battery Type: 3-4S Only
pret 120 lei
2)Motor Electric POWER 700/ 13T
Un motor puternic pentru
navomodele si aeromodele
Tensiune nominala: 4.8 - 12 V
Curent nominal: 22 A
Turatie: 12800 rpm
pret 85 lei
3) Mabuchi 755/9012
Tensiune 6-18 Volti
-Arbore de 5 mm
-Lungime 60 mm
-Diametru 44,4 mm
-Greutate 293 grame
-Consum
3V 4700 rpm 1.70A
6V 9400 rpm 1.90A
9V 14500 rpm 2.20A
12V 20000 RPM 2.70A
14V 22022RPM 2.7A
15V 25100 RPM 3.00A
18V 30400 rpm 3.75A
Pret 80 de lei.
4) POWER 600/21
POWER 600/21 este recomandat a fi montat in navomodele, alimentat cu 8 celule NiMH/ NiCd.
Prevazut cu ventilator intern.
Specificatii:
Tensiune de lucru: 6 - 12 V
Curent: 12 A
Curent maxim: 19 A
Turatie: 12400 rpm la eficienta maxima
Diametru ax: 3.17 mm
Masa: 220 g
Dimensiuni: D38 x L57 mm
pret 57 lei
Prefer contactarea telefonica la 0722608545
Transportul si rambursul le suporta cumparatorul.
"o barca face cat o mie de posturi" - skipper
#2 Useril este offline   laurcon
  • Postari: 804
Postat 03 July 2014 - 06:29 AM
up
#3 Useril este offline   laurcon
  • Postari: 804
Postat 15 July 2014 - 08:49 AM
UP
#4 Useril este offline   laurcon
  • Postari: 804
Postat 20 July 2014 - 07:01 AM
up
#5 Useril este offline   laurcon
  • Postari: 804
Postat 02 September 2014 - 08:03 AM
up
#6 Useril este offline   tripl3x
  • Postari: 19
  • Inregistrat: 29-January 12
Postat 16 September 2014 - 02:42 PM
Vezi postarealaurcon, la 02 September 2014 - 08:03 AM, a spus:
up
am un regulator pentru 6v . ai un motor pentru mine la 6v? pentru navomodel plantat doua cuve
Aceasta postare a fost editata de tripl3x: 16 September 2014 - 02:45 PM
#7 Useril este offline   laurcon
  • Postari: 804
Postat 24 September 2014 - 12:47 PM
up
#8 Useril este offline   laurcon
  • Postari: 804
Postat 13 October 2014 - 06:36 AM
numarul 4 dat
restul valabile
#9 Useril este offline   AndreiTentean
  • Hot Wheels
  • Postari: 176
  • Inregistrat: 01-February 05
  • Interests:Motorsport
Postat 02 November 2014 - 01:05 AM
cu ax de 5 mm ?
Uneori o singura prostie consacra un prost.
#10 Useril este offline   laurcon
  • Postari: 804
Postat 09 November 2014 - 07:06 AM
Vezi postareaAndreiTentean, la 02 November 2014 - 01:05 AM, a spus:
cu ax de 5 mm ?
punctele 2} si 1}
#11 Useril este offline   laurcon
  • Postari: 804
Postat 15 December 2014 - 08:01 AM
valabil
#12 Useril este offline   laurcon
  • Postari: 804
Postat 29 January 2015 - 02:06 PM
up
#13 Useril este offline   laurcon
  • Postari: 804
Postat 23 February 2015 - 11:34 AM
up
#14 Useril este offline   laurcon
  • Postari: 804
Postat 04 March 2015 - 08:21 AM
up
#15 Useril este offline   laurcon
  • Postari: 804
Postat 28 March 2015 - 06:52 AM
1)2)3) valabile
#16 Useril este offline   laurcon
  • Postari: 804
Postat 04 April 2015 - 07:24 PM
up
#17 Useril este offline   laurcon
  • Postari: 804
Postat 15 June 2015 - 07:24 PM
up
#18 Useril este offline   laurcon
  • Postari: 804
Postat 22 July 2015 - 06:32 AM
up
#19 Useril este offline   laurcon
  • Postari: 804
Postat 05 August 2015 - 06:52 AM
punctul 1) vandut
au mai ramas
Turatie: 12800 rpm
pret 85 lei
3) Mabuchi 755/9012
Tensiune 6-18 Volti
-Arbore de 5 mm
-Lungime 60 mm
-Diametru 44,4 mm
-Greutate 293 grame
-Consum
3V 4700 rpm 1.70A
6V 9400 rpm 1.90A
9V 14500 rpm 2.20A
12V 20000 RPM 2.70A
14V 22022RPM 2.7A
15V 25100 RPM 3.00A
18V 30400 rpm 3.75A
Pret 80 de lei.
Transportul (24lei-ramburs inclus) prin Fan Courier il suporta cumparatorul.
Trimit cu Posta Romana doar cu plata in avans .
Telefon 0722608545 Laurentiu
