Modelism - RHC Forum: FEG Inovation - 10 Kw Wind turbine - Modelism - RHC Forum
FEG Inovation - 10 Kw Wind turbine Prima turbina eoliana realizata in Romania in serie.
#1 Useril este offline   Buggy-man
  • Postari: 1804
Postat 08 May 2015 - 08:17 AM
Foarte interesant.
https://www.youtube....h?v=pnemYPPiwT8
Rated Power - 10 Kw @ 10 m/s
Peak Power - Constant Power via IMT Controller to 10 KWatt up to 15 m/s
Output Voltage - Up to 500 VDC
Blade Quantity & Tipe - 3 Glass Fiber Blades, LNP (Low Noice Profile), Pich Adjustable
Rotor Blade Diameter - 4,5 m
Start-up Wind Speed - 1,8 m/s
Rated Wind Speed - 10 m/s
Survival Wind Speed - 45 m/s
Generator - DualStage, Three Phase, Permanent Magnetic Generator
Efficiency - > 0.96
Turbine Controller - IMT (Integrated Microcontroller Technology)
Turbine & Generator Protection - Over: Wind Speed, 250 RPM, Voltage Initial Set-up (via microcontroller dumper load box)
Comunication - WiFi & RS485 for Software Up-Load
Voltage Supply - 22 - 36 Volt DC
Kwh/month - >1.100 Kwh/month @ 6 m/s
Turbine Weight - 300 kg
Noise - 40 db(A) @ 5m/s
Temperature Range - -25°C to +60°C
Design Lifetime - 20 Years
Warranty - 5 Years (Only with annual regular inspection)
RHCForum - Webmaster
loading
