Modelism - RHC Forum: VBar NEO - Modelism - RHC Forum
VBar NEO Noutati de la Mikado
#1 Useril este offline   ninel63
  • Postari: 100
  • Inregistrat: 04-August 08
Postat 29 April 2015 - 03:02 PM
Iata ce anunta:
VBar NEO now with bailout feature
VBar NEO will come to market in four varieties:
•with integrated receiver for VBar Control
•without receiver for use with other radio brands
•both also available with additional, external sensor
VBar NEO is equipped with the latest sensor technology for flybarless as well as for the bailout feature.
The additional external sensor should be used where a standard VBar Silverline would have been chosen. The sensors
(silverline type) with ring technology are still preferable on models with high vibration levels.
External sensors can be retrofitted any time. VBar NEO detects the external sensor and switches operating modes automatically.
In case of a sensor failure, VBar NEO will fall back to the internal sensors, thus providing real redundancy and
providing additional operational safety.
The bailout feature works independently from the external sensor.
VBar NEO can be set up using a VBar Control or a personal computer/laptop computer running MS Windows or MacOS.
VBar NEO will be brought to market with the reasonably priced Express version of the VBar firmware and can be updated easily at any given time (e. g. with Pro version, bailout feature or new and exciting features to come).
Update and registration processes will be much more straightforward, using the same VBar Control Manager tool already known from VBar Control. Featurs and Apps can be added easily through our App Store.
Available April/May 2015
  • Postari: 3026
  • Inregistrat: 14-June 07
Postat 29 April 2015 - 10:29 PM
Eu asteptam un bailout de ceva vreme de la Vstabi, fiind foarte multumit de unitatile de la ei.
Tot trageam speranta ca va veni intr-un pachet de update de versiune firmware.
Asta este, vom vedea multe Vbar "standard' SH la vanzare, pretul scade.
E bine ca il fac sa mearga cu si cu alte radio, nu doar cu radio proprie. ( altfel isi limitau singuri piata).
Astept primele reviews si dac ma convinge il voi incerca si eu pe unul din heli.
#3 Useril este offline   ninel63
  • Postari: 100
Postat 30 April 2015 - 12:02 PM
Astept si eu sa vad primele impresii dupa care foarte probabil sa iau o unitate pentru
700. Din cate am citit pe cateva forumuri inca multe lucruri sunt neclare.
#4 Useril este offline   Primus
  • Postari: 3026
Postat 30 April 2015 - 01:42 PM
Pana la urma 700 e functional ?
Am trimis un mail, dar nu stiu daca a ajutat.
Aceasta postare a fost editata de Primus: 30 April 2015 - 01:42 PM
  • Postari: 8341
Postat 30 April 2015 - 03:07 PM
Vbar clasic e fara valoare atata timp cat clonele de 20USD sunt la aceeasi versiune de soft. Daca ar mai scoata un update pentru clasic (eventual si cu bailout) s-ar schimba treaba. E la 5.3.4b de ani buni.
#6 Useril este offline   Primus
  • Postari: 3026
Postat 30 April 2015 - 03:21 PM
 stiganas, la 30 April 2015 - 03:07 PM, a spus:
Ar fi fost ideal pentru actualii clienti Vbar.
Nu se poate, cica hardware-ul nu suporta implementarea noului algoritm ( Rainer).
In principiu tu ai dreptate, clonele se dovedesc a fi OK.
Si totusi se vand Vstabi SH la 100-150 de euro.
  • Postari: 8341
Postat 30 April 2015 - 03:50 PM
Asa am citit si eu, vechiul hardware nu suporta bailout (senzorii).
Pe de alta parte nu pot sa cred ca au atins perfectiunea cu 5.3.4 si nu se mai poate aduce nici un fel de imbunatatire. In vest oamenii prefera originalul dupa constiinta/convingere, la noi e ca si cum ai incerva sa vinzi licente de office pentru acasa.
Eu am doua originale (din care unul a fost o avere) si tot mai sper ca o sa mai primeasca un update.
In mod normal NEO o sa fie mai bun. Sper doar sa nu isi piarda focusul investiind prea mult in statie, Vbar Control.
Piata de heli e in recesiune masiva, dupa boom-ul electric/lipo/FBL a cazut rau cu aparitia multicopterelor. Pentru Mikado a picat cam prost, tocmai ce au investit masiv in expansiune (productie/storage).
  • Postari: 3026
Postat 30 April 2015 - 04:20 PM
 stiganas, la 30 April 2015 - 03:50 PM, a spus:
Piata de heli e in recesiune masiva, dupa boom-ul electric/lipo/FBL a cazut rau cu aparitia multicopterelor. (productie/storage).
Multe companii cunoscute din domeniu se vad nevoite sa revizuiasca afacerile ( ma uitam de curand pe site-il celor de la Amain).
Scoti un produs nou la care sa mai pui ceva in plus, pare sa fie "solutia" pentru economia din ziua de azi, din upgrade nu prea se mai fac bani azi.
Mie mi s-a parut "bizara" miscarea cu Vbar Control, unii din cei care zboara exclusiv heli l-au adoptat.
Pentru Mikado e un produs "care face diferenta" si poate aduce o marja comerciala mai buna pentru business-ul lor .
#9 Useril este offline   ninel63
  • Postari: 100
Postat 30 April 2015 - 09:04 PM
Se pare ca vor sa se extinda si la avioane cu "Mikado Vplane". Azi am
vazut un clip pe You Tube cu Kyle Dahl facandu-i reclama:
https://www.youtube....h?v=l1Ep-RmqgJ0
#10 Useril este offline   booggy
  • Postari: 429
  • Inregistrat: 21-October 09
  • Interests:114223
Postat 11 September 2015 - 03:13 PM
Mikado VBar NEO w/6.1 Express
Foloseste cineva este multumit de el ?
