Modelism - RHC Forum: Incarcator acumulatori Robbe Power Peak Ultimate - Modelism - RHC Forum
#1 Useril este offline   LukeSoft
  • Postari: 17
Postat 07 December 2014 - 12:22 PM
Incarcator rapid, cu carcasa de metal.
Cu egalizator integrat si ecran LCD ce afiseaza curentul, tensiunea si capacitatea.
Functii:
- Incarcare
- Detectie automata a numarului de celule
- Protectie la polaritate inversa pe mufa de iesire
- Semnal acustic si optic la incarcare
Specification
Operating voltage: approx. 10 V ... 15 V DC
12 V lead-acid battery or a powerful well stabilised mains
PSU (do not use a car battery charger!)
Current drain: max. approx. 14 A
Nominal battery voltage: 1.2 V ... 30.0 V (1 ... 25 NICD / NIMH cells,
2V ... 12 V lead-acid)
Fast-charge current 0.1 ... 5 A, voltage-dependent; see table
(approximate values)
3V 6V 9V to 20V 40V
max: 2A 3A 5A 3A
Trickle charge current: none
Automatic charge termination: Delta Peak process / lead-acid process
Discharge termination: automatic, at approx. 0.8 V / cell (NICD and NIMH only)
Max. discharge power: approx. 20 W
Discharge current: 0.5 A ... 3.0 A
Protective functions: Polarity protection at input and output, short-circuit
protection on output, overheating protection, low voltage
protection, excess voltage protection
Dimensions: approx. 125 x 155 x 80 mm
Pret: 190 RON negociabil
Telefon: 0745172823
#2 Useril este offline   LukeSoft
  • Postari: 17
Postat 07 December 2014 - 01:04 PM
Vandut.
3 useri citesc topicul
