Modelism - RHC Forum: Outrage Velocity N50 - Modelism - RHC Forum
Outrage Velocity N50 Se vinde
#1 Useril este offline   apstudio
  • Postari: 310
  • Inregistrat: 02-January 08
Postat 30 August 2014 - 08:29 PM
Fiindca someaza, mai bine il zboara vre-un doritor de nitro.
Se vinde Outrage Velocity 50 in urmatoarea echipare :
- Servo platou 3 x Savox SC-1258TG
- Servo coada Align DS650
- BEC Align HE50H10 B6T 2 In 1 Voltage Regulator
- Align RCE G600 Governor
- Servo acceleratie Savox SC-1258TG
- Motor OS MAX 55 HZ Limited Edition
- Head FBL original Outrage
- Pale 610mm SAB
Upgrade-uri :
- New gears (black)
- Lynx Heli Innovations Vertical Fin
- Upgrade Boom Support Spacer Set
- Lynx Heli Tail Boom Support Brace
Elicopterul se vinde fara controller FBL BEASTX.
Se poate preda si cu acesta (reglat, setat), dar se adauga pretul controller-ului, la momentul vanzarii.
Pret fara flybarless controller (BEASTX): 2000 RON.
Pret cu BEASTX: 2500 RON
Ofer orice detalii pe PM.
Nu fac schimburi.
Fisier atasat  IMG-20140830-00686.jpg (162.16K)
Fisier atasat  IMG-20140830-00690.jpg (241.42K)
Aceasta postare a fost editata de apstudio: 30 August 2014 - 08:30 PM
The Truth Is Out There.
#2 Useril este offline   apstudio
  • Postari: 310
Postat 30 August 2014 - 08:32 PM
Fisier atasat  IMG-20140830-00687.jpg (200.86K)
Fisier atasat  IMG-20140830-00688.jpg (247.45K)
Fisier atasat  IMG-20140830-00691.jpg (255.19K)
Fisier atasat  IMG-20140830-00694.jpg (168.13K)
#3 Useril este offline   apstudio
  • Postari: 310
Postat 08 September 2014 - 07:17 PM
Up,
2400 tot.
1950 fara beastx.
450 beastx separat.
Aceasta postare a fost editata de apstudio: 08 September 2014 - 07:18 PM
#4 Useril este offline   apstudio
  • Postari: 310
Postat 15 September 2014 - 09:22 PM
Up,
2400 tot.
1950 fara beastx.
450 beastx separat.
#5 Useril este offline   apstudio
  • Postari: 310
Postat 22 September 2014 - 04:10 PM
Up,
2400 tot.
1900 fara beastx.
450 beastx separat (Se da doar daca se vinde heli fara el).
#6 Useril este offline   apstudio
  • Postari: 310
Postat 01 October 2014 - 08:03 AM
Up,
2400 tot.
1900 fara beastx.
Se poata da si separat:
- Servo platou 3 x Savox SC-1258TG: 150$
- Servo gaz Savox SC-1258TG: 50$
- Servo coada Align DS650: 50$
- Align HE50H10 B6T 2 In 1 Voltage Regulator: 30$
- Align RCE G600 Governor: 30$
- OS MAX 55 HZ Limited Edition + toba: 350$
- Pale 610mm SAB: 50$
P.S. Electronica se da numai dupa ce se vinde motorul.
Aceasta postare a fost editata de apstudio: 01 October 2014 - 08:07 AM
#7 Useril este offline   apstudio
  • Postari: 310
Postat 14 October 2014 - 03:54 PM
Up!
#8 Useril este offline   apstudio
  • Postari: 310
Postat 28 October 2014 - 08:18 PM
UP!
#9 Useril este offline   apstudio
  • Postari: 310
Postat 24 November 2014 - 04:24 PM
Up,
2300 tot.
1800 fara beastx.
- OS MAX 55 HZ Limited Edition + toba: 330$
#10 Useril este offline   apstudio
  • Postari: 310
Postat 17 December 2014 - 12:55 PM
Up,
2300 tot.
1800 fara beastx.
#11 Useril este offline   apstudio
  • Postari: 310
Postat 11 January 2015 - 10:39 PM
Up.
#12 Useril este offline   apstudio
  • Postari: 310
Postat 25 January 2015 - 02:42 PM
Reducre, doar saptamana asta 2000 tot.
#13 Useril este offline   apstudio
  • Postari: 310
Postat 03 March 2015 - 09:33 PM
Up. 2200 tot.
#14 Useril este offline   apstudio
  • Postari: 310
Postat 14 March 2018 - 02:52 PM
Up. 2000.
Acum cu Beastx V4.
#15 Useril este offline   apstudio
  • Postari: 310
Postat 22 March 2018 - 02:08 PM
UP!!!
#16 Useril este offline   Michael911
  • Postari: 42
  • Inregistrat: 19-April 14
Postat 11 April 2018 - 02:05 PM
Gata de zbor cu tot cu radiocomanda receptor accu starter, eventual si niste zeamă il poti da?!
3 useri citesc topicul
