Modelism - RHC Forum: Cum se traduce?????? - Modelism - RHC Forum
#1 Useril este offline   Travel Air
  • Postari: 1225
  • Interests:Zbor
Postat 20 March 2014 - 03:25 PM
Tot ma uit la caractristicile unui servo si nu ma dumiresc ce vor sa spuna. Mai multi useri spun asta despre ele.
Poate ma lamuriti voi....
Overall Rating
Value UNRATED
Quality UNRATED
14 thumbs up!
Weight (with wire): 28.2grams.
Dimensions (LxHxW): 31.3 x 28.2 x 16.3mm
Torque: 3.0kg seems accurate but not measured.
Speed (Full travel): 0.198sec
Stall current: <0.5A
Centering ok, smooth, quiet and strong. 4 out of 5 because of some travel in bearings and somewhat weak center torque.
Bogdan Floria
bogdan.floria@aeromodelism.ro
bogdanfloria@gmail.com
0757110983
#2 Useril este offline   Travel Air
  • Postari: 1225
  • Interests:Zbor
Postat 20 March 2014 - 04:04 PM
Adica nu inteleg ce inseamna "cuplu slab pe centru".
Bogdan Floria
0757110983
  • Postari: 3956
  • Inregistrat: 19-August 12
Postat 20 March 2014 - 04:18 PM
Adica nu are multa forta cand ii ceri sa se mute din mijloc spre un capat cand tragi mai tare de el.Poti sa fugi de servoul ala.
  • Postari: 19177
Postat 20 March 2014 - 05:26 PM
Cand e somewhat nu fugi, poate ca alternativele sunt just weak, fara somewhat ;)
Daca ne spui si de ce vorbesti, poate propunem ceva.
#5 Useril este offline   Travel Air
  • Postari: 1225
  • Interests:Zbor
Postat 20 March 2014 - 08:11 PM
Vezi postarearenatoa, la 20 March 2014 - 05:26 PM, a spus:
Scuze, eram convins ca am copiat si numele servoului.
asta
Si am intrat deja in posesia lor.... :pardon:
Aceasta postare a fost editata de Travel Air: 20 March 2014 - 08:13 PM
Bogdan Floria
0757110983
#6 Useril este offline   MLGore
  • Dream Team Forever
  • Postari: 2332
  • Inregistrat: 08-March 04
Postat 20 March 2014 - 08:16 PM
Vezi postareaTravel Air, la 20 March 2014 - 08:11 PM, a spus:
asta
Daca ne spui si la ce il folosesti sigur o sa ne dam seama daca e bun sau nu.
#7 Useril este offline   Travel Air
  • Postari: 1225
  • Interests:Zbor
Postat 20 March 2014 - 08:43 PM
Vezi postareaMLGore, la 20 March 2014 - 08:16 PM, a spus:
Ai pus degetul pe rana...
E un proiect care avanseaza doar in visele mele deocamdata.
Un tractor de planoare electric, cu anvergura pe la 2.5m si 3.5kg.
Deocamdatra am aripile taiate de dululutu, un motor,niste placaj, niste balsa, planuri listate.
Servourile au venit asa, fara sa le caut si sper sa vina pe aripa la flaps si eleron.
asta e modelul.
Aceasta postare a fost editata de Travel Air: 20 March 2014 - 08:48 PM
Bogdan Floria
0757110983
#8 Useril este offline   MLGore
  • Postari: 2332
Postat 21 March 2014 - 12:04 AM
Astea merg mult mai bine pt. proiectul tau: http://hobbyking.com..._32g_0_15s.html
