Modelism - RHC Forum: Carte TEHNICA de strung SP80 - Modelism - RHC Forum
Carte TEHNICA de strung SP80 ma poate ajuta cineva
  • Postari: 2453
  • Inregistrat: 28-February 05
  Postat 23 February 2006 - 02:32 PM
MA POATE AJUTA CINEVA cu o carte tehnica de SP 80 de arad?
PLEASE!
URGENT
Platesc transport, scanare, copiere.... :(
Aceasta postare a fost editata de Dragut: 23 February 2006 - 08:42 PM
  • Postari: 2453
Postat 23 February 2006 - 08:49 PM
Am gasit ca strunguletul ar fi copia fidela a lui MN80 produs de TOS.
Adica:
http://www.toscelakovice.cz/English/Soustr...truhy/mn80a.htm
Caracteristici:
TECHNICAL DATA
Work area of the machine:
Rotating diameter over bed ...............................mm 160
Rotating diameter over carriages ...................... mm 90
Point width .........................................................mm 320
Bed width ...........................................................mm 120
Achievement of the hauptmotors .......................KW 0,55
Total mass of the machine ..................................kg 180
Spindle:
Front spindle nose ............................................ M 39x4
Spindle drilling .....................................................mm 18
Spindle-hollowcone-metrically............................. mm 25
Spindle speed range (9 stages) ....................... 1 /min. 150-2000
Feed motions and threads:
19 longitudinal feed stages ...............................mm.U-1 0,01-0,15
19 metric threads - upward gradient ................mm 0,2-3
15 Whitworth threads Gew./1 " .......................36-7
17 module threads Module ...............................0,2-1,5
18 diametrically pitch threads ..........................D.P. 20-80
Headstock:
Guide hollow cone .......................................... MORSE 1
Guide from thrust .............................................mm 80
Durchmeser of the headstock guide .................mm 20
#3 Useril este offline   Dragut
  • Postari: 2453
Postat 23 February 2006 - 08:50 PM
http://personal.telefonica.terra.es/web/me...s/Tos_Su16x.htm
http://www.lathes.co.uk/tos/
inca 2 linkuri
Da cartea PAUZA
Aceasta postare a fost editata de Dragut: 23 February 2006 - 08:51 PM
  • Postari: 2453
Postat 23 February 2006 - 09:10 PM
Si un club al detinatorilor de MINISTRUNGURI:
http://groups.yahoo....roup/9x20Lathe/
  • Postari: 2453
Postat 04 July 2007 - 06:47 PM
Si dupa indelungi chinuri si peripetii:
  • Imagine atasata: post-13-1183567650.jpg
#6 Useril este offline   Dragut
  • Postari: 2453
Postat 04 July 2007 - 06:48 PM
modificam turatia:
  • Imagine atasata: post-13-1183567707.jpg
#7 Useril este offline   Dragut
  • Postari: 2453
Postat 04 July 2007 - 06:49 PM
si intram din nou in span ;)
  • Imagine atasata: post-13-1183567754.jpg
#8 Useril este offline   vrajitoru
  • Postari: 211
  • Inregistrat: 10-July 07
Postat 11 January 2008 - 06:24 PM
Salut, vreau sa te intreb cum merge strungul ca am gasit si eu unu la 1000 usd si stau pe ganduri daca sa-l iau sau nu.
Ce grosime poti trece prin ax ?
#9 Useril este offline   Dragut
  • Postari: 2453
Postat 14 January 2008 - 08:10 PM
depinde in ce stare se afla strunguletu... eu am dat pe el undeva la 8 milioane si am mai bagat fo 6 in el...
Miine iti zic cam cit trece prin ax.
Vezi ca din fabrica nu a fost dotat cu universal ci cu bucse elastice.
Eu i-am facut cadou un TOS de 80 cu ambele seturi de bacuri.
#10 Useril este offline   vrajitoru
  • Postari: 211
Postat 14 January 2008 - 08:13 PM
pe okazii este unu la 1000 de usd dar are absolut tot la el
Sa te uiti te rog
#11 Useril este offline   Dragut
  • Postari: 2453
Postat 14 January 2008 - 08:19 PM
uite ca am gasit si scanul:
  • Imagine atasata: post-13-1200334750.jpg
  • Postari: 2453
Postat 14 January 2008 - 08:21 PM
Ai deja pe adresa de pe Yahoo 10 pagini...
E bine sa-l vezi tu sau sa-l vada cineva de meserie. Sa vada care e starea ghidajelor ce jocuri are ... ce uzura... eventual o proba de lucru...
Stima
  • Imagine atasata: post-13-1200334860.jpg
Aceasta postare a fost editata de Dragut: 14 January 2008 - 08:29 PM
#13 Useril este offline   vrajitoru
  • Postari: 211
Postat 15 January 2008 - 04:06 PM
Merci fain
am gasit si gaura :D 16mm doar...
#14 Useril este offline   Andyf97
  • Postari: 2
  • Inregistrat: 12-November 13
Postat 13 November 2013 - 11:33 AM
VB Engleza?
I hope so; I wonder if you could help me.
I have an SP80 Lathe and trying to find a 4 jaw chuck for it.
#15 Useril este offline   bitex
Postat 13 November 2013 - 12:12 PM
I sent you a private message.
If you have the pleasure to fill location in profile, it might appear more effective advice.
Thank you for coming with us, I hope we can work together. Also, I have an SP80.
Regards, Ovidiu
#16 Useril este offline   crysst
  • Postari: 91
  • Inregistrat: 29-February 12
Postat 27 February 2014 - 07:57 PM
pana la urma a aparut vre-un manual al strungului SP80? ceva in afara de datele tehnice?
3 useri citesc topicul
