Corona 939MG Servo Corona 939MG
Postat 04 October 2013 - 03:46 AM
Rascal 1940mm fs.61 nitro
Rascal 120 DLE 30
U Can Do .46 nitro .52, 2T
Beaver 1520
Maule 1500
Helios 2545
Postat 04 October 2013 - 07:10 AM
La heliurile FBL servo se leaga de unitatea FBL. Frecventa de lucru se seteaza din unitate in mod normal.
Servourile digitale moderne lucreaza la 333Hz (standard Futaba).
Frecventa la care rezista 939MG nu stiu care este, poate sa fie orice intre 50 si 333Hz. Trebuie sa cauti pe forumuri (de pilda rcgroups) sa vezi cum a mers la altii.
GigiGL, la 04 October 2013 - 03:46 AM, a spus:
Postat 04 October 2013 - 10:53 PM
Mie-mi trebuie ptr APM 2.5, pot seta doar general frecventa la toate 4 servo..
nu prea am reusit sa gasesc informatie..si "faza" cu testarea nu mi se pare prea profi
multumesc ptr raspunsuri.
Postat 05 October 2013 - 06:31 AM
mellbo, la 04 October 2013 - 04:04 AM, a spus:
Folosesc acest tip de servo pe avioanele mele, merge foarte bine, dar nu pot spune daca suporta frecvente mai mari pe refresh.
Atat spune producatorul pentru versiunea analogica:
http://www.corona-rc.com/Upload/20119195926556.jpg
CS939MG Analogue Servo Type:CS939MG Analogue Servo
Weight:12.5g/0.44 oz
Operating voltage:4.8V / 6.0V
Operating current:200mA / 240mA
Operating speed:0.14sec.60º/ 0.13sec.60º
Stall torque:2.5kg.cm / 2.7kg.cm
Dead band:≤5uSec
Operating speed:40º/one side pulse traveling 400us
Potentiometer:2 slider/
Direct DriveBall bearing:MR85Gear
Material:Metal
Connector wire length:215mm
Temperature:-20℃~+60℃
Si cea digitala:
http://www.corona-rc.com/Upload/201191104037102.jpg
Type:DS329MG
Weight:32g
Operating current:300mA / 400mA
Operating speed:0.11sec.60º/ 0.12sec.60ºStall torque:3.8kg.cm / 4.5kg.cm
Dead band:≤3uSec
Potentiometer:5 slider/Indirect
DriveBall bearing:MR106
Gear Material:Metal
Connector wire length:300mm
Temperature:-20 ℃ to +60℃
Rascal 120 DLE 30
Beaver 1520
Maule 1500
Helios 2545
Postat 05 October 2013 - 09:34 AM
Aceasta e versiunea digitala:http://www.corona-rc.com/Upload/200962421219816.jpg
DS939MG Type:DS939MG
Weight:12.5g
Operating voltage:4.8V~6.0V
Operating speed:0.14sec/60º
Dead band:≤3uSec
Operating speed:40º one side pulse traveling 400μs
Potentiometer:2 slider/Direct Drive
Ball bearing:MR85
Rascal 120 DLE 30
Beaver 1520
Maule 1500
Helios 2545
Postat 05 October 2013 - 11:15 AM
A folosit cineva aceste servouri?
Corona DS238MG Digital Metal Gear Servo 4.6kg/ 22g/ 0.14sec
Corona DS238HV Digital Metal Gear Servo 4.6kg/ 22g/ 0.13 Sec
La un planor de 3 m anvergura vreau sa le folosesc.
Ciao Sorin
http://hobbyking.com/hobbyking/store/images/new11/header03.jpg
Postat 05 October 2013 - 12:30 PM
SORIN CAIUS, la 05 October 2013 - 11:15 AM, a spus:
Ciao Sorin
Nu acel model, dar am mai multe atat Corona cat si Turnigy cu acelasi numar de cod, atat digitale cat si analogice, care sunt identice, mai putin eticheta si o mica diferenta la pret. Doar pe aripa Zagi si pe Bixler am cu angrenaj plastic, restul numai MG. Putin zgomotoase datorita angrenajului, dar in aer nu deranjeaza. In rest pot spune ca lucreaza excelent. Unul singur s-a defectat, un 929MG, dar din vina mea, un blocaj mecanic neobservat la timp pe rudder la Piper datorita unei mufe de cuplare cablu eleron intrata accidental sub bratul lui, la montarea pentru zbor. Cele digitale sunt foarte sensibile, practic simt si reactioneaza la fiecare din cei 200 pasi pe care ii face stickul statiei pe cursa completa min-max.
Aceasta postare a fost editata de GigiGL: 05 October 2013 - 12:32 PM
Rascal 120 DLE 30
Beaver 1520
Maule 1500
Helios 2545
