Modelism - RHC Forum: EG Aircraft RAVEN 25% - Modelism - RHC Forum
EG Aircraft RAVEN 25% bind and fly, powered by DLE 30 cc
#1 Useril este offline   sunchaser
  • Postari: 414
  • Inregistrat: 23-February 09
Postat 10 May 2013 - 10:10 AM
De vanzare Raven 25% de la EG Aircraft cu urmatoarea echipare:
- motor: DLE 30cc V2 (undeva intre 30-40 de zboruri pe un scale Spacewalker de la Seagull)
- receptor: Futaba R617FS 2,4Ghz
- acumulator aprindere: NiMH, 2500 mAh, 4,8V nou
- acumulator receptie: Lipo RAY, 7,4V, 3000 mAh nou
- regulator: Nosram 10A
- servo-uri semielevatoare si eleroane: 4 x SAVOX 0254 MG digital (viteza @ 6.0V: 0.14 sec/60°,cuplu @ 6.0V: 7.2 kg-cm, dual bearing, metal gear)
- servo directie: 1 x SAVOX 0252 MG digital (viteza @ 6.0V: 0.19 sec/60°,cuplu @ 6.0V: 10.5 kg-cm, dual bearing, metal gear)
- servo gaz: SAVOX 0351 digital(viteza @ 6.0V: 0.17 sec/60°,cuplu @ 6.0V: 4.1 kg-cm)
- RCEXL ignition cut off
Cate ceva despre model:
- tren principal si bechie din fibra de carbon
- lonjeroane aripi si fuselaj dublate/laminate cu carbon
- brate de comanda aluminiu eloxat (Futaba, Hobbyking)
- anvergura: 1,88m
- lungime: 1,75m
- greutate gata de zbor: 4,7 - 5 kg
PRET:
- bind and fly (include electronica si motor): 1950 RON
- ready to fly (totul mai putin receptorul): 1750 RON
- pret fara motor si fara receptor (include toate de mai sus, mai putin motorul DLE 30 si receptorul): 1350 RON
#2 Useril este offline   sunchaser
  • Postari: 414
Postat 20 May 2013 - 10:07 AM
Up !
#3 Useril este offline   sunchaser
  • Postari: 414
Postat 27 May 2013 - 11:36 AM
Up !
#4 Useril este offline   Dan Liviu
  • Postari: 423
  • Inregistrat: 24-February 13
Postat 27 May 2013 - 12:04 PM
superb modelul -a zburat mult?
#5 Useril este offline   sunchaser
  • Postari: 414
Postat 28 May 2013 - 11:40 AM
Vezi postareaDan Liviu, la 27 May 2013 - 12:04 PM, a spus:
Salut ! Are 3 zboruri.
#6 Useril este offline   sunchaser
  • Postari: 414
Postat 05 June 2013 - 12:37 PM
Up !
#7 Useril este offline   sunchaser
  • Postari: 414
Postat 14 June 2013 - 10:41 AM
Up !
#8 Useril este offline   sunchaser
  • Postari: 414
Postat 18 June 2013 - 09:35 AM
Vandut !
3 useri citesc topicul
