Modelism - RHC Forum: naza v2 - Modelism - RHC Forum
naza v2
#1 Useril este offline   worms
  • Postari: 1345
  • Inregistrat: 20-November 06
Postat 27 April 2013 - 08:06 PM
razboiul performantelor se muta si in partea de controlere de zbor si ca urmare a atacurilor asupra pozitiei de lider din partea zero-uav avem un nou anunt dji in gama low cost, ramane de vazut si pretul. reamintim ca in gama profesionala a fost lansata pentru wookong noua unitate imu v2 cu performante se zice mult imbunatatite.
NEW NAZA V2 Comming Soon. What’s new with the NAZA V2:
New Hardware - PMU V2
New case design with CANBUS port. Enhanced BEC functionality, better heat dissipation. Extra CANBUS ports, enhances the scalability of the system and will support Gopro Zenmuse, iOSD and Bluetooth module for assistant software use on smart phones in the future, etc..
Later NAZA V1 can also be upgraded using PMU V2 and support Gopro Zenmuse, iOSD and Bluetooth module..
Main Controller
The hardware structure has been optimized and the scalability and performance of the flight control system has been enhanced
Independent LED Module
What’s new with the NAZA V2 : Firmware and functions
- New attitude stabilization algorithm, provides better flight performance / maneuverability;
- New flight control performance, provides better flight experience; (flight control is smoother, take-off is easier, and solved the swinging problem when descending at high speed.)
- Support for Octo-rotor;
- One-motor stopped still can land safely (Hexa-rotor, Octo-rotor)
- Automatic course deviation compensation, reduced the effects of magnetic disturbance; interference around the compass detection & warning;
- Added IMU advanced calibration, error identification and warning, reduced the impact of sensor error to the flight performance
Aceasta postare a fost editata de worms: 27 April 2013 - 08:09 PM
#2 Useril este offline   worms
  • Postari: 1345
Postat 27 April 2013 - 09:07 PM
si avem si ceva poze de pe forumurile din china
#3 Useril este offline   cristirenault
  • Postari: 27
  • Inregistrat: 15-October 06
Postat 29 April 2013 - 09:26 PM
Parca am presimtit sa mai am putina rabdare :p
#4 Useril este offline   EBA
  • Postari: 956
  • Inregistrat: 09-April 09
  • Interests:AEROMODELISM
Postat 29 April 2013 - 11:24 PM
Vezi postareaworms, la 27 April 2013 - 09:07 PM, a spus:
Sunt curios la ce pret or sa-l scoata.
Deja mi-am luat zero-uavul asa ca......
SUNTEM FUDULI
#5 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Inregistrat: 03-October 08
  • Interests:Aero
Postat 03 May 2013 - 07:55 AM
390 euro
#6 Useril este offline   worms
  • Postari: 1345
Postat 03 May 2013 - 08:16 AM
#7 Useril este offline   cristirenault
  • Postari: 27
Postat 04 May 2013 - 09:42 AM
Ce bine se ridica si sta dracovenia in aer.
Sa vedem la ce pret o sa apara pe piata romaneasca.
  • Postari: 19177
Postat 04 May 2013 - 10:18 AM
390 euro :)
#9 Useril este offline   worms
  • Postari: 1345
Postat 04 May 2013 - 10:19 AM
sau 449 dolari :) vre-o 16 milioane lei vechi.mai pui 4 si cumperi un zero-uav x4-navigator si ai si 8 wp , telemetrie ,comunicatie cu telefonul pentru zbor sau setari etc
Aceasta postare a fost editata de worms: 04 May 2013 - 10:23 AM
  • Postari: 19177
Postat 04 May 2013 - 10:21 AM
cat despre cat de bine... vezi in topicul de crius aio filmul cu proiectul ArduPhantom, si poate iti schimbi parerea cum se poate zbura cu 100$.
#11 Useril este offline   worms
  • Postari: 1345
Postat 04 May 2013 - 10:34 AM
Vezi postarearenatoa, la 04 May 2013 - 10:21 AM, a spus:
e vorba de alte accelerometre,de aia a aparut upgrade la naza la v2, dji wookong imu la v2 sau mai nou microkopter la flight control v2.2 .cand schimba crius accelerometrele putem vorbi de egalitate, deocamdata comparam mere cu pere :) . Solutia ardu e buna pentru cine vrea sa vada cu ce se mananca multicopterele si ii place sa seteze toata ziua, pentru performanta se cere altceva.
#12 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Interests:Aero
Postat 05 May 2013 - 07:58 AM
Vezi postareaworms, la 04 May 2013 - 10:19 AM, a spus:
ZERO UAV vine tare din urmă ... aştept şi eu să văd cine îşi ia jucăria minune
PS. oricum va scade preţul la NAZA v1 dacă le mai produc.
Aceasta postare a fost editata de Mihai Oprescu: 05 May 2013 - 08:01 AM
#13 Useril este offline   worms
  • Postari: 1345
Postat 05 May 2013 - 10:33 AM
Vezi postareaMihai Oprescu, la 05 May 2013 - 07:58 AM, a spus:
Vezi postareaEBA, la 29 April 2013 - 11:24 PM, a spus:
Aceasta postare a fost editata de worms: 05 May 2013 - 10:34 AM
#14 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Interests:Aero
Postat 07 May 2013 - 03:23 PM
Primele impresii ZERO UAV???
#15 Useril este offline   Ciprian Dughir
  • Postari: 564
  • Inregistrat: 30-January 12
  • Interests:Multicoptere
Postat 07 May 2013 - 03:51 PM
Nu vad de ce sa scada pentru ca se poate pune softul v2 fara probleme pe el.
#16 Useril este offline   worms
  • Postari: 1345
Postat 07 May 2013 - 05:46 PM
Vezi postareaCiprian Dughir, la 07 May 2013 - 03:51 PM, a spus:
pai degeaba se pune softul daca nu functioneaza la parametric optimi :) ,naza v2 are alt accelerometru fata de v1 si care accelerometru e mult mai précis, e de generatie noua. upgrade are sa se faca prin schimbarea unitatii mc la pretul de 69 dolari sau euro, nu stiu exact.
  • Postari: 19177
Postat 07 May 2013 - 07:21 PM
A rasuflat cumva ce accel nou are ? Este 9150 ca APM 3 ?
#18 Useril este offline   worms
  • Postari: 1345
Postat 07 May 2013 - 07:31 PM
Vezi postarearenatoa, la 07 May 2013 - 07:21 PM, a spus:
nu stiu pe naza ce e dar pe mk e R9500M . se pare ca primul pe lista care a deschis seria upgrade-urilor pe acceleromere a fost zero-uav cu versiunea x6 cu p la urma, ei au fost "capul rautatilor" si care au starnit furtuna asta de schimbari. acum cine nu e in trend dispare, e o piata cu miscari bruste, azi e cineva lider ,maine altcineva etc.
Aceasta postare a fost editata de worms: 07 May 2013 - 07:34 PM
  • Postari: 19177
Postat 07 May 2013 - 07:38 PM
Offf... iar cu predictiile astea... :)
Vezi ce scriai acum un an sa vezi ca piata e in acelasi stare.
#20 Useril este offline   Ciprian Dughir
  • Postari: 564
Postat 07 May 2013 - 08:36 PM
Vezi postareaworms, la 07 May 2013 - 05:46 PM, a spus:
69euro e doar un PMU mai destept, in cazul in care mai vrei un port sbus, nu are treaba cu controlerul. Azi am zburat controlerul v1 cu noul soft(v2) si e muuuult mai stabil. Se simte clar diferenta intre soft-uri.
  • Postari: 19177
Postat 07 May 2013 - 08:53 PM
Daca e muuult mai stabil, inseamna ca pana acum era doar vrajeala, chestie de care unii se lamurisera de mult, nu stiu de ce nu vor cei multi sa se lamureasca...
Sau mai exact, de ce sa dai 400$ la chinez ca sa te vrajeasca cu o pocnitoare care in banii aia nu are decat RTH, nici o navigare in puncte, cand poti avea acelasi lucru cu 100$ si mai dai 100$ unui mester autohton ca sa ti-l puna la punct, si asa incurajezi inteligenta locala... Ce naiba, avem in forumul asta destule dovezi ca sunt controlere ieftine si cel putin de nivelul Naza.
Persoana care scrie se exclude, nu e nici un apropo sa imi ofer seviciile.
PS: dumneata parca scriai undeva ca esti cadru universitar... :unsure: asta se preda acum, superioritatea lucrului gata facut chinezesc ? Intrab ca unul care are si el in spate 10 ani de Alma Mahsii, prin anii 90...
Aceasta postare a fost editata de renatoa: 07 May 2013 - 08:55 PM
#22 Useril este offline   worms
  • Postari: 1345
Vezi postareaCiprian Dughir, la 07 May 2013 - 08:36 PM, a spus:
se poate sa fie asa ca nu am acordat atentie subiectului ca nu ma intereseaza naza, pe moment interesul meu e canalizat pe x6p . ideea e ca in lupta asta pentru piata deja marii producatori incep sa acorde diferite facilitati (fara extra-cost) si se zice ca vor fi si ceva wp default la wookong, semn ca exista concurenta fie de la mk,dji,zero-uav sau de ce nu APM , apropo de apm, acestia au progresat tare de vre-un an de cand nu m-am mai jucat cu ei si tin trena la gama low-cost alaturi de noile platforme PX4 si Autoquad 6 .o piata cu o dinamica puternica si lupta fara menajamente pentru suprematie din care principalii castigatori au sa fie chinezii cu clonele lor ieftine :).
Aceasta postare a fost editata de worms: 07 May 2013 - 08:56 PM
  • Postari: 19177
Postat 07 May 2013 - 08:57 PM
Asta cu dat wp-uri incluse in pret e alta stupiditate in RC-ul zilelor noastre ca si cu canalele la statii...
#24 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Interests:Aero
Postat 08 May 2013 - 08:50 AM
Vezi postarearenatoa, la 07 May 2013 - 08:53 PM, a spus:
Foarte de acord cu incurajarea inteligentei locale !
Dar trendul lumii noastre romanesti este sa cumpere un produs care face de toate, de preferabil sa il bage in priza si sa mearga ... revin la ce spuneam mai demult, oamenii nu mai vor sa citeasca manuale de utilizare, sa seteze si sa instaleze, sa testeze, toti cumpara laptop-uri sa apese pe buton si sa intre pe net, apoi constata acasa ca are FreeDos si nu Uindousul ala misto al lui vecinu de la doi. Apoi cum snobismul sau comoditatea e in floare, de ce sa dau banii unui profesionist, mai bine apelez la un prieten (lasa ca-i dau eu o bere sau o cafea), nu e asa ??!?!
Pana ajunge la concluzia expusa de Dvs. mai sus, trece ceva timp, nervi, bani uneori aruncati degeaba...
#25 Useril este offline   Ciprian Dughir
  • Postari: 564
Postat 08 May 2013 - 09:14 AM
Asta voia sa fie un atac direct? :)
Vad ca esti foarte chitit impotriva produselor DJI. Ti-e frica ca pier multiwii, arducopter, Crius etc? Stai linistit ca nu pier. ;) Fiecare cu optiunea lui.
Faptul ca am ales NAZA e pur si simplu o optiune personala (sunt fotograf profesionist si am nevoie de produse de calitate in munca mea, nu sa astept dupa nu stiu ce release care corecteaza bug-ul x, dar introduce inca 2 bug-uri noi ;) ), n-are treaba cu facultatea sau cu ce predau acolo. Crede-ma ca mi-au trecut prin mana destule controlere ca sa pot spune ca Naza merita toti banii. Au si ei bubele lor, dar s-au vazut si la case mai mari probleme.
P.S.: Remarca ta e ceva de genul: a... esti mecanic? pai de ce iti cumperi masina gata facuta, cand poti sa-ti iei un chit, s-o montezi, sa bibilesti un an la ea si apoi sa o proptesti in primul gard?
#26 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Interests:Aero
Postat 08 May 2013 - 09:26 AM
Vezi postareaCiprian Dughir, la 08 May 2013 - 09:14 AM, a spus:
sunt fotograf profesionist si am nevoie de produse de calitate in munca mea, nu sa astept dupa nu stiu ce release care corecteaza bug-ul x, dar introduce inca 2 bug-uri noi ;) ), ........ Crede-ma ca mi-au trecut prin mana destule controlere ca sa pot spune ca Naza merita toti banii. Au si ei bubele lor, dar s-au vazut si la case mai mari probleme.
NAZA pentru hobby-isti isi merita banii din plin, eu fiind posesor de asa ceva, dupa ce am aruncat ceva bani pe diverse controllere si nervi si timp & crash-uri.
Sunt convins de faptul ca exista alternative mai ieftine, care intr-un final pot functiona la fel de bine ca produsele DJI sau ZERO UAV ori altele. Oricum pentru aplicatii profi NAZA-M nu e facut.
PS. eu merg pe produs DJI pentru ca imi satisface nevoile dupa esecurile avute (nu am apelat la serviciile nimanui pentru a face functionale controllerele ieftine avute)
Aceasta postare a fost editata de Mihai Oprescu: 08 May 2013 - 09:28 AM
#27 Useril este offline   worms
  • Postari: 1345
Postat 08 May 2013 - 09:44 AM
m-am jucat cu toate controlerele importante de pe piata de la multiwii incoace asa ca pot exprima o opinie zic eu competenta, toate au partile lor bune sau rele dar ce a asigurat succesul dji a fost usurinta cu care le poti utiliza, scoti din cutie si in doua ore cel mult ai un produs 100% functional si asta fara sa ai vre-o facultate facuta, asta i-ti asigura satisfactia deplina, asta nu au inteles ceilalti. din punctul meu de vedere cei mai buni de pe piata sunt indiscutabil microkopter dar ca sa construiesti o scula de la ei te taie toate transpiratiile si daca nu stii electronica mai bine nu te apuci. la mk sau apm sau multiwii pana zbori scula tre sa stai bine cu nervii ca ai de lipit si de setat de-ti vine acru.sa luat exemplu topicului cu aoio care nu se mai termina si pentru ce? sa ajungi sa setezi o panarama de quad. la naza totul e simplu, ala zboara singur sau mai nou si mai usor e cu phantomul.asta vrea lumea, iluzia ca este un mare constructor si si-a facut scula singur de la a la z si apoi usurinta setarilor si a zborului safe.
Aceasta postare a fost editata de worms: 08 May 2013 - 09:48 AM
#28 Useril este offline   Mihai Oprescu
  • Postari: 666
  • Interests:Aero
Postat 08 May 2013 - 11:25 AM
Vezi postareaworms, la 08 May 2013 - 09:44 AM, a spus:
EPIC ! :-)
#29 Useril este offline   worms
  • Postari: 1345
Postat 08 May 2013 - 02:48 PM
se pare ca nu accelerometrele au fost schimbate in v2 de la naza ci numai amortizoarele de silicon :) :
-Există unele mici diferențe în MC și GPS dintre cele două versiuni.Amortizare intern în V2 a fost îmbunătățit, iar GPS-ul din V2 este similar cu Phantom, ceea ce înseamnă că are un fierastrau filtru construit în și este mai bine la respingerea interferențe.
Aceasta postare a fost editata de worms: 08 May 2013 - 02:48 PM
  • Postari: 19177
Postat 08 May 2013 - 03:16 PM
Nu se poate ! ar fi trebuit sa apara in toate tabloidele ca Naza si-a schimbat silicoanele :D :p
