Modelism - RHC Forum: lista piese quadcopter - Modelism - RHC Forum
lista piese quadcopter constructie quad fpv
#1 Useril este offline   adynita
  • Postari: 14
  • Inregistrat: 24-March 13
Postat 27 March 2013 - 10:42 PM
Buna,
Sunt Ady din Iasi, si as dori sa imi asamblez un quadcopter de la zero cu preturi minime. Un prieten m-a ajutat cu o lista de piese, dar as vrea si alte pareri.
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE
$3.19
Q450 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version
$11.99
On-Board Lipoly Low Voltage Alarm 2s~3s
$1.99
USBasp AVR Programming Device for ATMEL proccessors
$4.95
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware)
$53.82
TS353 5.8G 400mW FPV Transmitter
$69.99
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Green)
$3.14
Hobby King 30A ESC 3A UBEC
$8.86
ZIPPY Flightmax 2200mAh 3S1P 25C
$8.99
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
$22.99
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board
$29.99
2830-11 1000KV Outrunner Brushless Motor Free Mounts
$10.99
Va multumesc
  • Pfiu Drace, zboara!!!
  • Postari: 2111
  • Inregistrat: 16-March 13
  • Interests:Aero, 3D
Postat 27 March 2013 - 10:50 PM
Vezi postareaadynita, la 27 March 2013 - 10:42 PM, a spus:
Buna,
$3.19
$11.99
$1.99
$4.95
$53.82
$69.99
$3.14
$8.86
$8.99
$22.99
$29.99
$10.99
Va multumesc
poti uita de kk2.0 si frame-ul ales, cauta pe forum userul para si comanda un frame de la el, sunt bestial lucrate si sunt smechere, ca placa ardupilot, arduflyer, sau aiop v2, kk este veche si nu ofera multi senzori, am avut kk-ul vechi, doar cu gyro si nu se compara cu multiwii ce il zbor acuma.
http://www.rhcforum....dcopter-pliant/
Aceasta postare a fost editata de RedDevil: 27 March 2013 - 10:51 PM
Fly it, like you stole it!
#3 Useril este offline   worms
  • Postari: 1345
  • Inregistrat: 20-November 06
Postat 28 March 2013 - 09:32 AM
Buna,
$3.19
$11.99
$1.99
$4.95
$53.82
$69.99
$3.14
$8.86
$8.99
$22.99
$29.99
$10.99
Va multumesc
ai uitat de M3 x 20mm Nylon Screws $ 1.07
si de 2 x M3 Nylon Nut $ 0.69
pai facem treaba ca lumea sau nu?
Aceasta postare a fost editata de worms: 28 March 2013 - 09:34 AM
#4 Useril este offline   dr.ace
  • Postari: 400
  • Inregistrat: 24-April 08
Postat 28 March 2013 - 08:00 PM
Daca vrei mai mult sa zbori fara restrictii, kk 2.0 e perfect, daca vrei sa petreci 90% din timp in fata laptop-ului pentru setari si 10% sa te uiti ce frumos sta singur la punct fix, mergi pe o placa 'desteapta' cu cit mai multi senzori.
Bateria merge, dar mi se pare cam mica, vei avea autonomie redusa, mai ales daca vrei echipare FPV. Ar merge un 3000 sau chiar 5000mah.
Vad ca ai ales Tx video, asta inseamna ca mai trebuie o camera video, eventual un lipo mic de 400-500mah pentru alimentare Tx si ceva pentru vizualizarea imaginii la sol, monitor, laptop cu tuner tv sau ochelari.
P.S. Sincer ar fi bine sa asculti sfaturile acelui prieten din Iasi, care probabil ti-a si aratat cu ce se maninca aceste zburatoare.
#5 Useril este offline   icsss
  • Postari: 2085
  • Inregistrat: 16-May 10
  • Interests:Aeromodelism
Postat 28 March 2013 - 08:09 PM
Vezi postareadr.ace, la 28 March 2013 - 08:00 PM, a spus:
..daca vrei sa petreci 90% din timp in fata laptop-ului pentru setari si 10% sa te uiti ce frumos sta singur la punct fix, mergi pe o placa 'desteapta' cu cit mai multi senzori.
adica ce vrei sa zici? : :rofl:
vine si timpul meu... sper :D
Aceasta postare a fost editata de icsss: 28 March 2013 - 08:13 PM
#6 Useril este offline   RedDevil
  • Postari: 2111
Postat 28 March 2013 - 09:56 PM
iudat ca eu nu am stat 90% din timp in fata la laptop, si am zburat cu el, asa cu multi senzori cu tot :yahoo:
#7 Useril este offline   worms
  • Postari: 1345
Postat 28 March 2013 - 10:12 PM
Vezi postareaRedDevil, la 28 March 2013 - 09:56 PM, a spus:
ciudat ca eu nu am stat 90% din timp in fata la laptop, si am zburat cu el, asa cu multi senzori cu tot :yahoo:
pai ce sa zic, ai nimerit o placa defecta? :D
eu pentru incepatori nu pot sa recomand decat naza. pui si zbori, mai repede nu se poate.
Aceasta postare a fost editata de worms: 28 March 2013 - 10:16 PM
#8 Useril este offline   RedDevil
  • Postari: 2111
Postat 28 March 2013 - 10:19 PM
Vezi postareaworms, la 28 March 2013 - 10:12 PM, a spus:
placa isi face treaba prea bine, culmea m-a costat undeva la 90 lei cu totu, nou nu sh, traiasca hk si ;) avantaju meu ca nu am stat sa citesc tone de deocumentatie, am luat-o pe bajbaite si pe intrebate. efectiv am stat cam 10% din timp la laptop.
da si banii dati pe un naza, basca esti legat de gps-u lor, scump....... la placa mea cu inca 30 dolari am gps de la rctimer sau hk......:drinks: de restu pot da de baut :good:
Aceasta postare a fost editata de RedDevil: 28 March 2013 - 10:21 PM
#9 Useril este offline   adynita
  • Postari: 14
Postat 01 April 2013 - 12:13 AM
in urma discutiilor am o ultima actualizare:
http://www.hobbyking...rame_450mm.html
http://www.hobbyking...rs_GENUINE.html
http://www.hobbyking..._Firmware_.html
http://www.hobbyking...ion_Green_.html
http://www.hobbyking...SC_3A_UBEC.html
http://www.hobbyking...ccessories.html
http://www.hobbyking...trol_Board.html
http://www.hobbyking...less_Motor.html
http://www.hobbyking..._3S1P_20C_.html
http://www.hobbyking...et_Antenna.html
http://www.hobbyking..._Module_RX.html
http://www.hobbyking..._Tx_Rx_Set.html
as fi pus un kit fatshark dar nu sunt pe stoc:
http://www.hobbyking...nd_5_8G_TX.html
#10 Useril este offline   icsss
  • Postari: 2085
Postat 01 April 2013 - 07:48 AM
Baterie pentru FPV?
Pana la urma ce cumperi, TX/RX separat sau ochelari cu TX/RX? Daca mergi pe TX/Rx separat iti mai trebuie o camera si monitor/esycap pt laptop.
Ar mai fi varianta de frame cu PCB.
Cum afisezi telemetria, ai gasit ca se poate afisa direct pe ecranul statiei?
Aceasta postare a fost editata de icsss: 01 April 2013 - 07:49 AM
#11 Useril este offline   icsss
  • Postari: 2085
Postat 01 April 2013 - 08:08 AM
Vezi postareaicsss, la 01 April 2013 - 07:48 AM, a spus:
Baterie pentru FPV?
pt. FPV sunt si alte surse, poate chiar mai bune ca HK si cu ochelari pe stock..
#12 Useril este offline   costi_n
  • Postari: 338
  • Inregistrat: 30-November 10
Postat 01 April 2013 - 09:47 AM
Vezi postareaadynita, la 01 April 2013 - 12:13 AM, a spus:
NU fatshark PREDATOR. Sunt oribili. Fov mic. Distanta interpupilara prea mica. Nu ai posibilitarea sa pui un RX video mai bun (sensibil), decat extern. Mergi pe FS DOMINATOR chiar daca sunt putin mai scumpi
Aceasta postare a fost editata de costi_n: 01 April 2013 - 09:49 AM
#13 Useril este offline   adynita
  • Postari: 14
Postat 01 April 2013 - 02:10 PM
Baterie pentru FPV?
nu este pe stoc frameul ala
#14 Useril este offline   adioperator
  • Postari: 1356
  • Inregistrat: 12-November 09
  • Interests:aeromodelism
Postat 01 April 2013 - 03:45 PM
Frame gasesti si pe rctimer. Tot acolo gasesti si niste kit-uri ce includ frame, regulatoare, motoare si elici la niste preturi decente cu transport inclus.
Aterizari line !
Aceasta postare a fost editata de adioperator: 01 April 2013 - 03:48 PM
#15 Useril este offline   adynita
  • Postari: 14
Postat 01 April 2013 - 08:25 PM
Vezi postareaadioperator, la 01 April 2013 - 03:45 PM, a spus:
Aterizari line !
am dat comanda. acum astept cu nerabdare :)
#16 Useril este offline   icsss
  • Postari: 2085
Postat 01 April 2013 - 08:48 PM
Vezi postareaadynita, la 01 April 2013 - 08:25 PM, a spus:
Te-ai miscat repede. Sa speram ca ai luat tot :clapping:
#17 Useril este offline   adynita
  • Postari: 14
Postat 01 April 2013 - 08:52 PM
Vezi postareaicsss, la 01 April 2013 - 08:48 PM, a spus:
hai ca iti dau lista:
coletul 1:
Your order details are:
1x #260000001/24291 Hobbyking SK450 Glass Fiber Quadcopter Frame 450mm = $16.99
1x #XT60/9572 Nylon XT60 Connectors Male/Female (5 pairs) GENUINE = $3.15
4x #F-30A/15205 Hobby King 30A ESC 3A UBEC = $35.44
1x #ACC6/7028 Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories = $22.99
1x #9171000073/24723 Hobbyking KK2.0 Multi-rotor LCD Flight Control Board = $27.99
5x #D2830-111000/12921 D2830-11 1000kv Brushless Motor = $45.20
1x #DJT/14355 FrSky DF 2.4Ghz Combo Pack for JR w/ Module & RX = $49.33
1x #350000001/13197 1/3-inch Sony CCD Video Camera 700TV Lines F1.2 (PAL) = $32.60
1x #TX-9X-M2/8992 Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware) = $53.82
2x #017000062/25822 10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Orange) = $5.28
1x #277000005/31647 RP-SMA 5.8GHz Circular Polarized spiroNet Antenna(SWARM94487750) = $34.39
1x #STCR351305/15295 5.8g 200mw FPV Wireless AV Tx & Rx Set = $57.99
coletul 2:
3x #Z40003S-20/7634 ZIPPY Flightmax 4000mAh 3S1P 20C (SWARM94688090) = $57.31
1x #ZC.500.3S.25/21330 ZIPPY Compact 500mAh 3S 25C Lipo Pack = $5.89
1x #Z18002S-5F/14076 ZIPPY Flightmax 1800mAh 9.9V 5C LiFePo4 TX Pack = $9.99
sper sa nu fi uitat ceva :)
#18 Useril este offline   Para
  • Postari: 462
  • Inregistrat: 20-December 11
Postat 02 April 2013 - 02:10 AM
Vezi postareaadynita, la 01 April 2013 - 08:52 PM, a spus:
Elici, inca vreo 3-4 seturi, ax motor si prop-adaptere. :)
Postat 02 April 2013 - 07:37 AM
N-as merge pe acel cadru nici sa mi-l faci cadou...
Controller... zau daca mai inteleg de ce mai incepe azi lumea cu KK, fie el la patrat... ca sa aiba de ce sa se plictiseasca repede si sa zica ca progreseaza ? Si o zic asta ca unul care am "fabricat" acum doi ani vreo 30 de KK-uri, si m-am oprit singur in momentul in care a aparut mwii, fiind convins ca lumea o sa dea cu flit la KK instant... uite ca m-am inselat... fooooarte ciudat... :unsure:
Antenele Spironet: sucks, avem in tara meseriasi care le fac mai bune, pe cinstite, nu ca vrea sa le fac reclama. Si mai ieftin.
Baterie... s-a mai scris pe aici, nu stiu daca la dumneata sau la altcineva ca 4000 e prea mare pentru asemenea cadru.
Aceasta postare a fost editata de renatoa: 02 April 2013 - 07:38 AM
#20 Useril este offline   Ciprian Dughir
  • Postari: 564
  • Inregistrat: 30-January 12
  • Interests:Multicoptere
Postat 02 April 2013 - 09:15 AM
KK2 e ok pentru inceput pentru ca are setarile la botul calului dar nu straluceste la stabilizare. Unele jucarii le stabilizeaza impecabil, cu altele nu se intelege deloc (nu-l scoti din tremurat orice i-ai face: PID, izolare, recalibrare etc) Cu unele ESC/motoare se impaca, cu altele nu (celebra problema cu motoarele care pocnesc). In schimb, DJI Naza merge pe toate combinatiile de ESC/motoare pe care le am prin casa fara probleme. Cum a mai scris cineva pe-aici: controlerul e creierul jucariei, daca vrei ceva inteligent trebuie sa scoti banul. M-am jucat cu tot felul de controlere, ba mi-am proiectat unul si programat de la zero (ce-i drept cu MSP430 de la Texas Instruments ca e nativ 16 bit). Toate au metehnele lor. Crius e mult mai ok decat KK2 si diferenta de pret nu e colosala. Poate te gandesti si la varianta asta. ;)
Cat despre cadru, asculta-l pe renatoa.
#21 Useril este offline   costi_n
  • Postari: 338
Postat 02 April 2013 - 07:23 PM
Si inca un aspect important. La CRIUS cu inca aprox. 20$ poti pune si un OSD <_< iar daca mai faci un efort de 40$ poti pune si telemetrie in 433
Ochelarii? Monitorul? vad ca nu ai ales nimic
#22 Useril este offline   adynita
  • Postari: 14
Postat 02 April 2013 - 07:27 PM
Vezi postarearenatoa, la 02 April 2013 - 07:37 AM, a spus:
am inceput acest forum de ceva vreme si am asteptat sugestii... cam tarziu cu critica. si mai ales ca am avut un buget si deja l-am depasit cu 30%. as fi vrut si eu un alt frame dar nu erau pe stoc.
dar voi tine cont de sfaturi si e posibil sa imi constuiesc un frame cu brate de aluminiu, daca ce am comandat nu e destul de mare. si upgrade voi face in timp, dupa ce mai capat experienta. multumesc oricum
#23 Useril este offline   adynita
  • Postari: 14
Postat 02 April 2013 - 07:31 PM
Vezi postareacosti_n, la 02 April 2013 - 07:23 PM, a spus:
e posibil sa mai obtin o finantare si o sa imi iau FatShark AttitudeSD FPV Headset System w/5.8G TX de 360$, doar daca am rabdare si sunt cuminte. si un OSD
#24 Useril este offline   RedDevil
  • Postari: 2111
Postat 02 April 2013 - 07:35 PM
Vezi postareaadynita, la 02 April 2013 - 07:27 PM, a spus:
Quad
ia uite aici super oferta, acelasi frame il zbor eu acuma, super tapan si usor, doar 170 grame chel.
#25 Useril este offline   adynita
  • Postari: 14
Postat 02 April 2013 - 07:44 PM
are cineva vreo idee de monitor mai ieftin?
si ce e mai bine sa iau: monitor sau tv cu intrare video? sau o placa video pt laptop?
am vazut in bazar un tv lcd de 5" cu 120 ron. nu stiu cat e de bun.
Scuze de dezinformare, am confundat cadrul, am crezut ca ai luat:
http://www.hobbyking...rame_500mm.html
Este OK ce ai luat, desi Q450 cu care incepusei era si mai OK. Si este in stoc.
Imi pare rau ca nu am vazut topicul mai de mult, trebuia sa il postezi la multicoptere.
#27 Useril este offline   adynita
  • Postari: 14
Postat 02 April 2013 - 07:45 PM
Vezi postarearenatoa, la 02 April 2013 - 07:44 PM, a spus:
ai vazut ca e dublu la pret?
#28 Useril este offline   adynita
  • Postari: 14
Postat 02 April 2013 - 07:48 PM
Vezi postareaadynita, la 02 April 2013 - 07:45 PM, a spus:
q450 a aparut azi in stoc ca ieri nu era
Postat 02 April 2013 - 07:50 PM
La care te referi ? ala dantelarie da, e scump, pus ca odata rupt, nu prea mai ai ce inlocui. Am crezut ca l-ai luat cand am vazut fiberglass in titlu.
Q450 e ieftin, e chiar indicat de luat doua din start.
Inca un motiv pentru care nu am acordat atentie topicului era lista de link-uri... pai cine sta sa le viziteze pagina cu pagina ?!
#30 Useril este offline   costi_n
  • Postari: 338
Vezi postareaadynita, la 02 April 2013 - 07:44 PM, a spus:
Am eu un monitor de 7 inch pe care nu il mai folosesc. De fapt este un TV portabil iertator cu "blue screen-ul". Cauta pe net PL8006. Imi trimiti PM daca esti interesat
13 useri citesc topicul
