Modelism - RHC Forum: Rise of the machines :D - Modelism - RHC Forum
  • 35 Pagini +
  • 17
  • 18
  • 19
  • 20
  • 21
Rise of the machines :D ... astora incepe sa le fie frica...
#541 Useril este offline   renatoa
  • Postari: 19177
Postat 25 April 2015 - 06:00 PM
drone delivery... cum trimiti painea cu drona !
http://static.rcgroups.net/forums/attachments/8/3/9/7/a7799829-25-roadkill1.jpg
#542 Useril este offline   Nanok@
  • Postari: 382
Postat 02 May 2015 - 11:49 AM
Vezi postarearenatoa, la 26 March 2015 - 10:54 AM, a spus:
Era electricului s-a terminat !!! 2 ore doar asa de incalzire :D
http://www.energyor.com/news/post:28
A fuel cell is a device that converts the chemical energy from a fuel into electricity through a chemical reaction with oxygen or another oxidizing agent.[1]
Fuel cells are different from batteries in that they require a continuous source of fuel and oxygen/air to sustain the chemical reaction whereas in a battery the chemicals present in the battery react with each other to generate an electromotive force (emf). Fuel cells can produce electricity continuously for as long as these inputs are supplied.
The first fuel cells were invented in 1838. The first commercial use of fuel cells came more than a century later in NASA space programs to generate power for probes, satellites and space capsules. Since then, fuel cells have been used in many other applications. Fuel cells are used for primary and backup power for commercial, industrial and residential buildings and in remote or inaccessible areas. They are also used to power fuel-cell vehicles, including forklifts, automobiles, buses, boats, motorcycles and submarines.
Aceasta postare a fost editata de Nanok@: 02 May 2015 - 11:51 AM
#543 Useril este offline   renatoa
  • Postari: 19177
Postat 14 May 2015 - 07:37 PM
A fost inaugurata epoca vandalismului cu drona...
http://www.wired.com...ns-epic-nyc-tag
Incep sa cred ca toate astea sunt de fapt actiuni de marketing, orice ar fi, doar sa se vorbeasca de "marele alb" :)
#544 Useril este offline   dan_mitea
Postat 17 May 2015 - 11:59 PM
http://techno.lapres...-americains.php
Cea mai mica drona?
#545 Useril este offline   renatoa
  • Postari: 19177
Postat 18 May 2015 - 05:50 AM
Neah, sunt si mai mici si in plus motorizate.
Asta e o aripa, se lanseaza de sus, transmite date si "moare", ca mustele de unde i-au pus numele.
#546 Useril este offline   navigator
Postat 19 May 2015 - 07:35 AM
La fel de fidelă precum Cârtiță din "Natură si Aventură" dar parcă ceva mai capabilă in anumite condiții: https://www.lily.camera/
#547 Useril este offline   renatoa
  • Postari: 19177
Postat 19 May 2015 - 08:28 AM
Pentru o lume narcisista... :) sau care bea cam mult redbull...
#548 Useril este offline   renatoa
  • Postari: 19177
Postat 25 May 2015 - 08:07 AM
Trebuia sa fie un roman... care sa intre in istorie.
http://www.engadget....nd-into-history
Domnu' Dan, asta e pentru amicii dumitale :)
#549 Useril este offline   Sere4uall
  • Postari: 580
  • Inregistrat: 11-October 08
Postat 25 May 2015 - 02:01 PM
tocmai ce am vazut si eu sitrea si vroiam sa postez :) foarte tare filmuletul
Off-road: HPI Baja 5sc SS 1:5
Losi 8ight-T 2.0 - 4WD Truggy
Traxxas Summit
On-road: HPI Mirco RS4 -4WD 1:18
Mini-Z
Tamya MR-03 Alfa Romeo Giulieta -2WD 1:10
Spektrum DX-3E
Spektrum DX-3S
#550 Useril este offline   renatoa
  • Postari: 19177
Postat 28 May 2015 - 03:21 PM
In sfarsit o utilizarea cinstita a "dronelor"... in astfel de cazuri se aproba zborul peste mase mari :D
http://www.diyphotog...michigan-crowd/
care sare primul si la noi ? :D
Aceasta postare a fost editata de renatoa: 28 May 2015 - 03:22 PM
#551 Useril este offline   renatoa
  • Postari: 19177
Postat 03 June 2015 - 08:17 AM
Noapte buna copii... daca mai puteti dupa ce vedeti asta :D
#552 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3627
  • Inregistrat: 09-June 07
Postat 03 June 2015 - 08:59 AM
O porcarie totala.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#553 Useril este offline   renatoa
  • Postari: 19177
Postat 03 June 2015 - 09:34 AM
Sa ghicim... tocmai ti-ai luat una alba ? :D
#554 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3627
Postat 03 June 2015 - 12:50 PM
Una neagra dar nu in viitorul apropiat.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#555 Useril este offline   renatoa
  • Postari: 19177
Postat 06 June 2015 - 10:26 AM
Ai semnal la celular? Guvernul va stii daca zbori ceva in zona aia :D
http://www.theguardi...ellphone-towers
#556 Useril este offline   renatoa
  • Postari: 19177
Postat 18 July 2015 - 11:42 AM
Posta elvetiana a inceput testele... nu mai spun la ce :)
https://www.post.ch/...art-drone-tests
Cu 10 km si 1 kg as zice ca sunt realisti, nu ca altii... dar avand in vedere relieful, si ce ar putea insemna 10 km... 'icea, peste munte... hmmm... :unsure:
Aceasta postare a fost editata de renatoa: 18 July 2015 - 11:43 AM
#557 Useril este offline   renatoa
  • Postari: 19177
Postat 21 July 2015 - 06:25 PM
http://uk.reuters.co...N0PV1EE20150721
Pe langa Otopeni... nici un nebun ?
#558 Useril este offline   renatoa
  • Postari: 19177
Postat 24 August 2015 - 03:50 PM
Sony si drone...
http://blogs.sonymob...e-drone-launch/
#559 Useril este offline   Parfenov
  • Postari: 737
  • Inregistrat: 25-July 13
Postat 24 August 2015 - 07:33 PM
Da ce ciudat arata ... nu prea inteleg bine din poza aia sistemul de propulsie , daca chiar ila ii .. sunt 2 elice fata in fata ?
Parfenov Razvan
#560 Useril este offline   renatoa
  • Postari: 19177
Postat 24 August 2015 - 07:59 PM
Poate fi ori un coaxial, ori o quadrupala.
#561 Useril este offline   icsss
  • Postari: 2085
  • Inregistrat: 16-May 10
Postat 25 August 2015 - 09:43 AM
Vezi postarearenatoa, la 24 August 2015 - 07:59 PM, a spus:
http://www.popsci.co...?src=SOC&dom=fb
#562 Useril este offline   Parfenov
  • Postari: 737
Postat 25 August 2015 - 09:51 AM
2 in 1 .. super :))
Parfenov Razvan
#563 Useril este offline   renatoa
  • Postari: 19177
Postat 25 August 2015 - 10:19 AM
Ce nu s-a spus in articol, si se vede mai greu in imagini, este ca sunt doua sisteme, pe langa coaxial mai are 3 EDF-uri micutze incastrate in bot si aripi, probabil cu rol de stabilizare suplimentara in hover.
Care stabilizare, cel putin la decolarea aia, demonstrativa cred, e cam varza, la staiful lui Sony as avea pretentii si nu as arata asa ceva lumii.
Daca cititi o sa vedeti ca este un proiect dat unor 3rd party, nu cercetare proprie Sony... care cred ca nu sunt de nivelul lui Sony, cel putin platforma asta nu ma impresioneaza... poate niste ARCA, au invatat si ei sa sifoneze banii cu talent :)
Aceasta postare a fost editata de renatoa: 25 August 2015 - 10:22 AM
#564 Useril este offline   renatoa
  • Postari: 19177
Postat 28 August 2015 - 05:38 PM
De ce sa le banam... bicoz !
https://youtu.be/KX8cuGiQb4Y?t=52
Aceasta postare a fost editata de renatoa: 28 August 2015 - 05:40 PM
#565 Useril este offline   Parfenov
  • Postari: 737
Postat 28 August 2015 - 06:21 PM
asta inseamna sa fii mafiot :)))) cand ai nevoie de un moment de liniste te urci acolo :)) asta daca nu ii vant
Parfenov Razvan
#566 Useril este offline   renatoa
  • Postari: 19177
Postat 31 August 2015 - 08:38 AM
Apropo de tot felul de cazuri de intalniri/facaturi raportate intre avioane 1:1 si drone, aveti link la un raport al unui incident recent, din 26 aug, care este acum dezbatut pe forumurile de flight advocacy, ca fiind cu multe semne de intrebare...
http://www.asias.faa...28-AUG-15,PIPER
Piper-ul a fost lovit in ampenaj dar fara ca aripile sau fuselajul sa prezinte cea mai mica zgarietura, deja dubios... apoi inaltimea de 2500 ft (762m), nu tocmai accesibila chiar oricarei drone... pentru cine nu stie fantoma are limitare din FC la 500m altitudine ;)
Apoi lovitura aia... cam dura chiar si pentru o elice de carbon... :unsure: si alte amanunte...
#567 Useril este offline   Săndel
  • Postari: 1210
  • Inregistrat: 10-January 15
Postat 31 August 2015 - 10:48 AM
https://youtu.be/OUWv-Lj3oig
- Captain Sum Ting Wong
- Wi Tu Lo
- Ho Lee Fuk
- Bang Ding Ow.
#568 Useril este offline   renatoa
  • Postari: 19177
Postat 31 August 2015 - 10:39 PM
mare... gradina... gard... multi... rotoare :D
#569 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3627
Postat 01 September 2015 - 08:47 AM
Si veteranul.....
https://www.youtube....h?v=L75ESD9PBOw
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#570 Useril este offline   Săndel
  • Postari: 1210
Postat 03 September 2015 - 10:59 PM
https://www.youtube....h?v=dSMHZ74nML4
Acuma am dat de el. Căutam idei de impermeabilizare...
Remarcaţi ”sarcina utilă” ;)
- Wi Tu Lo
- Ho Lee Fuk
- Bang Ding Ow.
  • 35 Pagini +
  • 17
  • 18
  • 19
  • 20
  • 21
loading
