Modelism - RHC Forum: ALL IN ONE PRO Flight Controller v1.0 - Modelism - RHC Forum
  • 40 Pagini +
  • 26
  • 27
  • 28
  • 29
  • 30
ALL IN ONE PRO Flight Controller v1.0 Multiwii sau MegaPirate
#811 Useril este offline   renatoa
Postat 31 July 2013 - 01:30 PM
Vezi postareaicsss, la 31 July 2013 - 01:25 PM, a spus:
LOGGING se refera la inregistrarea datelor in zbor?
Da, placa V1 nu avea EEPROM pentru asta.
Aceasta postare a fost editata de renatoa: 31 July 2013 - 01:31 PM
#812 Useril este offline   Para
  • Postari: 462
  • Inregistrat: 20-December 11
Postat 31 July 2013 - 02:36 PM
Vezi postarearenatoa, la 31 July 2013 - 12:53 PM, a spus:
Hai cu colecta de o bere pentru sir Alex... :)
Cum procedam ? :)
#813 Useril este offline   icsss
  • Postari: 2085
  • Inregistrat: 16-May 10
Postat 02 August 2013 - 09:28 AM
Vezi postareaPara, la 31 July 2013 - 02:36 PM, a spus:
Cum procedam ? :)
Se pare ca actiunea s-a mutat aici: http://copter.ardupilot.com/
#814 Useril este offline   renatoa
Postat 02 August 2013 - 10:39 AM
Nu imi pare a fi site oficial, pare a fi de reclama pentru 3DR :unsure:
#815 Useril este offline   icsss
  • Postari: 2085
Postat 02 August 2013 - 10:42 AM
Vezi postarearenatoa, la 02 August 2013 - 10:39 AM, a spus:
Pe wiki scrie: "June 2013 UPDATE: The ArduCopter manual has now moved here. The manuals here are for legacy hardware and will no longer by updated or maintained."
#816 Useril este offline   icsss
  • Postari: 2085
Postat 02 August 2013 - 01:00 PM
Functia Compassmot exista la mpng < 3.0?
Din ce inteleg eu e altceva fata de "Automatic learning of offsets during flight"
http://copter.ardupi..._PDB_ESC_motors
EDIT: raspuns nu
Aceasta postare a fost editata de icsss: 02 August 2013 - 01:03 PM
#817 Useril este offline   icsss
  • Postari: 2085
Postat 02 August 2013 - 01:08 PM
"Inertial Navigation for Loiter and Auto meaning much more accurate control"
Daca ce scrie mai sus va functiona cel putin la fel de bine ca la Inertial ALT HOLD, V3.0 va fi de vis :)
#818 Useril este offline   icsss
  • Postari: 2085
Postat 02 August 2013 - 09:56 PM
Cam asa arata fara tren..
Imi place cum arata dar e incomod.
#819 Useril este offline   Para
  • Postari: 462
Postat 05 August 2013 - 01:21 AM
Vezi postareaicsss, la 02 August 2013 - 01:08 PM, a spus:
Eu am doua APM-uri, un 2.0 si un Flyer 2.5, pe care rulez AC 3.0.1 si zboara superb. Astept portarea MPNG doar pentru ca am si trei AIOP-uri pentru tot felul de masini de test si as vrea sa am platforma comuna sa le pot compara.
#820 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2183
  • Inregistrat: 28-November 06
Postat 05 August 2013 - 08:30 AM
Vezi postareaicsss, la 02 August 2013 - 09:56 PM, a spus:
ce de fire :)
imi aduce aminte de robotii din terminator :D
#821 Useril este offline   djtaotao
  • Postari: 995
  • Inregistrat: 27-January 11
Postat 11 August 2013 - 08:27 PM
Vezi postareaArchaeon, la 24 July 2013 - 09:28 AM, a spus:
idiotul de bluTUT nu vrea sa mearga
Nici mie nu a vrut sa-mi mearga pana nu am aplicat o metoda dubioasa, adica: click pe "connect" in Mission Planner, asteptat 15 secunde si abia apoi alimentat controller-ul.
Issue-ul e cunoscut si semnalat aici.
Aceasta postare a fost editata de djtaotao: 11 August 2013 - 08:28 PM
#822 Useril este offline   icsss
  • Postari: 2085
Postat 13 August 2013 - 10:04 PM
Please give me 1-2 days for test in flight and I will send to e-mail: download URL and instructions.
:clapping:
Aceasta postare a fost editata de icsss: 13 August 2013 - 10:04 PM
#823 Useril este offline   renatoa
Postat 16 August 2013 - 07:55 AM
ETA 19.08.2013...
Puneti berea la rece :D
Vezi postareaicsss, la 02 August 2013 - 09:28 AM, a spus:
Iar Sir Alex si-a tras si el site, in replica...
http://www.megapirateng.com/
#824 Useril este offline   icsss
  • Postari: 2085
Postat 17 August 2013 - 06:00 PM
LOITER-ul din MPNG (sau Arducopter) se comporta la fel ca cel de la NAZA?
Nu ma refer la precizie, ci la logica de functionare:
La NAZA, in LOITER, il poti deplasa din pnctual A in punctul B, iar cand eliberezi stick-urile ramane in punctul B.
La MPNG, in LOITER, imi da impresia ca incearca sa revina in punctul A. Asa e si la voi?
#825 Useril este offline   renatoa
Postat 17 August 2013 - 07:58 PM
Aceasi s-a mai spus si in postul 70 din topicul de fata.
http://code.google.c.../AC2_LoiterMode
#826 Useril este offline   icsss
  • Postari: 2085
Postat 18 August 2013 - 01:08 AM
Vezi postarearenatoa, la 17 August 2013 - 07:58 PM, a spus:
Cu toata rusinea.. dar postul #70 a fost demult uitat :)
"5m radius deadband" poate fi modificat din parametri?
Vad pe wiki "LOITER_RADIUS" dar e default=1 si nu are explicatii, cred ca e pt. arduplane.
#827 Useril este offline   icsss
  • Postari: 2085
Postat 19 August 2013 - 08:42 PM
Vezi postareaicsss, la 18 August 2013 - 01:08 AM, a spus:
pt AIO PRO V1.0 cum as putea masura vibratiile care ajung la ACC?
In TUNING nu prea se poate vedea mare lucru.
http://copter.ardupi...uringvibration/
#828 Useril este offline   Para
  • Postari: 462
Postat 21 August 2013 - 02:06 PM
Vezi postarearenatoa, la 16 August 2013 - 07:55 AM, a spus:
Ce facem, ca nu-i pasteurizata, si-i trece termenul... ;)
#829 Useril este offline   renatoa
Postat 21 August 2013 - 02:12 PM
Si nefiltrata... ;)
Daca urmariti, banuiesc ca ati vazut ca si altora le da laptele in foc...
#830 Useril este offline   renatoa
Postat 23 August 2013 - 09:06 AM
"Today I will send sources for supporters. I'm still not received results from testers. But I'm made ~10 flights and seems all works fine." :D
#831 Useril este offline   Archaeon
  • Postari: 223
  • Inregistrat: 17-August 11
  • Interests:De vreo 2-3 ani slow RC in zbor si pe apa. In rest fotografia, nitica arta si mai multa mestereala.
Postat 23 August 2013 - 09:13 AM
Uraaaaaaaaaaa! "MPNG running with default PID. Fly very well!!! I’m very satisfied with results. I’m made only basic calibrations, nothing changed in PID’s.""
Uichendul asta sper sa-mi fac timp de echilibrat motoariliii.
Computers runs on smoke...
"Once you let the smoke out, it will not work anymore."
#832 Useril este offline   renatoa
Postat 29 August 2013 - 04:07 PM
...I'm glad to present new version of MPNG 3.0.1 - R2
Important notice! This version still not support old boards with ITG3200 sensor (will be added in R3). Only flight controllers with MPU6050 currently supported.
What changed:
1. Fixed Compassmot calibration in terminal and test -> compass command.
2. Little optimized MPU6050 reading.
3. Added method to fix bootloader bug, when uploading to board hang.
#833 Useril este offline   icsss
  • Postari: 2085
Postat 10 September 2013 - 09:38 PM
Am observat ca in ultima vreme, pierd gps fix-ul in zbor pentru cateva secunde..
Am repozitionat gps-ul in afara cutiei.. foarte aproape de firele de la esc la baterie... asta sa fie?
In rest cer senin, aceleasi setari.. nimic schimbat si tot pe 2.9 zbor pt n-am avut inca timp de 3.0 :(
PS: a incerccat careva 3.0? Impresii lioter?
Aceasta postare a fost editata de icsss: 10 September 2013 - 09:39 PM
#834 Useril este offline   Para
  • Postari: 462
Postat 11 September 2013 - 08:40 AM
Am avut un servo brushless cu carcasa metalica care-mi bruia GPSul.
#835 Useril este offline   icsss
  • Postari: 2085
Postat 11 September 2013 - 12:53 PM
Vezi postareaPara, la 11 September 2013 - 08:40 AM, a spus:
O sa-l mut undeva mai departe de fire, esc-uri, etc.. si o sa recalibrez compasul.
Am mai observat ca din cand in cand o ia razna in loiter.. mai exact se inclina la ~45 de grade si ii da "blana" intr-o directie.. :D Pana sa repozitionez GPS-ul nu facea asa. Oricum e interesanta senzatia :))
PS: GPSul e influnetat de vibratii??
#836 Useril este offline   Para
  • Postari: 462
Postat 11 September 2013 - 01:02 PM
GPS-ul e influentat doar de radiatie electromagnetica. Daca ai emitatori in apropiere (bluetooth, telemetrie, videoTX) ii scade SNR-ul.
#837 Useril este offline   renatoa
Postat 11 September 2013 - 01:04 PM
Radiofrecventa mai corect zis, ca radiatie electromagnetica e si de la ESC-uri.
#838 Useril este offline   icsss
  • Postari: 2085
Postat 11 September 2013 - 01:24 PM
Vezi postarearenatoa, la 11 September 2013 - 01:04 PM, a spus:
:blink: deci ESC-ul sau firele de curent nu-l influenteaza..?
..si de ce DJI zice "The GPS is sensitive to vibration interference"?
#839 Useril este offline   renatoa
Postat 11 September 2013 - 01:30 PM
De ce nu citezi toata propozitia ?
"...so position the module at least 10cm from the tail rotor."
Tail rotor ? :o :unsure: mie imi suna ca s-a facut copy paste din altceva, cam ca la un doctorat ;) fara multa gandire
#840 Useril este offline   icsss
  • Postari: 2085
Postat 11 September 2013 - 02:56 PM
Vezi postarearenatoa, la 11 September 2013 - 01:30 PM, a spus:
or fi copiat de la un gyro pt heli.. asa are sens :)
  • 40 Pagini +
  • 26
  • 27
  • 28
  • 29
  • 30
18 useri citesc topicul
