1-receptor Graupner MC-18 PCM microcomputer 18-Kanal SUPERHET abc 9canale
pret 100 ron
2-receptor Graupner SMC-20 SPCM 20=kanal SUPERHET abc 10canale
pret 150 ron
3-receptor Multiplex PICO 3/4 FM/PPM 4canale
pret 100ron
4-receptor SunJp micro 6 canale FM/PPM greutate 7,5grame
pret 50ron
detalii romilea@yahoo.com tel 0722784753
5
Motor brushless pt Heli nou nefolosit doar l-am montat pe un planor si atat
Il vand deoarece este pt heli eu am nevoie de un motor cu turatii mai mici l-am cumparat acum 2 saptamani de la lindinger.
A costat 69Euro il vand cu 180 Ron
pentru mai multe detalii intrati aici http://shop.lindinge...oducts_id=82657
Zellen3-4LiPoLuftschrauben-Geh.-Ø/Ges.-L o.W./W-Ø27,85/38,3/3,17 mmGewicht:79 gAnw.Beispiel/Features3S/2700-2850mAh; 4S/3000mAhU/V:3000Motor-ArtAußenläufer
6
Motor brushless Kontronik Kora 15-10W outrunner
Specs list for KON24310 Motor KV 1130 rpm/V Dimensions D - 40.5mm, H - 39.0mm, Shaft length - 30mm Shaft diameter 5mm Application 450 size helicopters Lipo battery requirement 2S - 4S Weight 148gm
180Ron
tel.0722784753
Number of downloads: 44 -
Number of downloads: 46 -
