Modelism - RHC Forum: Avion Thunder Tiger Super Decathlon 40 NOU !!! NEZBURAT &# - Modelism - RHC Forum
Avion Thunder Tiger Super Decathlon 40 NOU !!! NEZBURAT &# ARF + motor Thunder Tiger F-75-S
#1 Useril este offline   neataticu
  • Postari: 1428
  • Inregistrat: 25-October 07
    Multi roto !
Postat 21 September 2011 - 03:33 PM
Vand un avion Super Decathlon de la Thunder Tiger, asamblat in proportie de 98%. Am lasat afara "ciubotzeii" de la roti pentru ca unde l-as fi zburat era iarba mare; si nu i-am lipit toate decalele. L-am scos la camp si am rulat un singur rezervor de rodaj, dupa care din lipsa de timp a devenit suport de praf.
Are 4 servo Futaba 3004 si un hextronix metal gear de 12kg pe directie ( este sistem push-pull cu cabluri).
Il dau ARF cu motor, servouri, fara RX si TX cu o canistra plina de 4L de tornado heli. Pret total magazin 1900 RON.
Eu vreau 1400 RON pe tot... avion, motor, servouri, combustibil.
0723243926
AVION:
Wing Span(mm / in.) 64" (1626mm)
Length(mm / in.) 45" (1145mm)
Wing Area(sq. dm² / sq.in.) 694 sq. in. (44.7 dm²)
Weight(g/ lbs.) 6 lb. (2.8kg)
Motor
Engine .40~.46 2C Req'd
Radio 4 CH Req'd
Vine cu motor Thunder Tiger F-75-S in 4 timpi.
Displacement(c.c. / cu.in.) 12.33c.c. / .752 cu.in.
Bore(mm / in.) 28.3 mm / 1.114 in.
Stroke(mm / in.) 19.6 mm / 0.772 in.
Practical R.P.M.(R.P.M.) 2,300 ~ 12,000 rpm
Output(BHP/RPM) 1.2 BHP / 11,000 RPM
Weight(g/oz) 457.2 g / 16.13 oz
Aceasta postare a fost editata de neataticu: 21 September 2011 - 03:38 PM
12CM Records
DJI Mavic Pro
#2 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 28 September 2011 - 01:27 PM
UP !
12CM Records
DJI Mavic Pro
#3 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 10 October 2011 - 10:03 PM
Up. 1300 roni. Ultimul pret. Mai jos nu-l dau.
12CM Records
DJI Mavic Pro
#4 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 03 December 2011 - 02:41 AM
UP!
12CM Records
DJI Mavic Pro
#5 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 16 December 2011 - 06:17 PM
UP ! pret special de sarbatori 1100 roni !
12CM Records
DJI Mavic Pro
#6 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 01 February 2012 - 04:02 PM
UP 1200 RON !
12CM Records
DJI Mavic Pro
#7 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 07 May 2012 - 09:04 AM
UP !!! 1400 Roni si arunc si un starter robbitronic, incalzitor de bujii, 2 packuri de receptie lipo, regulator de voltaj lipo
1600 roni si pun si un spektrum dx5e si e rtf.
12CM Records
DJI Mavic Pro
#8 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 17 May 2012 - 08:43 AM
UP ! Doar pana duminica 1000 roni...
Avionul artf - fara rx-tx + canistra de 4l tonado din care am rulat doar un rezervor.
Este nezburat... a mers un rezervor de rodaj la sol. Doar motorul a fost 700 de RONI...
12CM Records
DJI Mavic Pro
#9 Useril este offline   incepatoru
  • Postari: 2863
  • Inregistrat: 30-May 09
  • Interests:aero
Postat 02 November 2012 - 09:57 AM
..motorul separat la ce pret??
#10 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 03 January 2013 - 01:33 PM
UP ! 1000 RON !
12CM Records
DJI Mavic Pro
#11 Useril este offline   julian
  • Postari: 16
  • Inregistrat: 28-February 09
Postat 03 January 2013 - 09:58 PM
Schimbi cu auto hpi savage 4.6?are 3rezervoare merse
#12 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 04 January 2013 - 09:23 AM
Imi pare rau dar nu schimb cu auto sau altceva... doar bani.
12CM Records
DJI Mavic Pro
#13 Useril este offline   voltrone
  • Postari: 1
  • Inregistrat: 08-January 13
Postat 09 January 2013 - 10:10 AM
UP
#14 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 16 January 2013 - 10:05 AM
UP ! 1000 RON
12CM Records
DJI Mavic Pro
#15 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 29 January 2013 - 07:30 AM
up 900 ron urgent...doar saptamana asta... numai motorul este 700 roni + servouri + benzina, avionul vine mai mult decat gratis. 0723243926 Radu.
Aceasta postare a fost editata de neataticu: 29 January 2013 - 07:31 AM
12CM Records
DJI Mavic Pro
#16 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 06 February 2013 - 04:33 PM
UP ! 850 Ultimul Pret !!!
12CM Records
DJI Mavic Pro
#17 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 13 February 2013 - 09:36 AM
900 RON si pe langa avionul ARTF ( fara RX TX ) mai dau :
Canistra plina de 4l tornado, Starter robbe + 1 plumb de 7000mAh (cred), pompa de combustibil Thunder Tiger. Regulator Lipo Nosram 5A, 2 lipo receptie 2s de 800 si 1000 mAh, inca o elice ( nu mai stiu de cat e), 2 conuri ( unul de aluminiu, unul de plastic)...cred ca mai am si un rezervor + ce mai gasesc de aero termic.
Aveti toate accesoriile pentru a opera avionul.
Daca doriti varianta RTF pentru 200 de roni in plus pun si o statie E-FLY ETC62 + receptor. Scoasa doar o data la camp.
NU DAU NIMIC SEPARAT. Totul este la pachet !
12CM Records
DJI Mavic Pro
#18 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 20 February 2013 - 10:03 AM
UP ! 850 RON tot pachetul de mai sus. fara rx-tx.
12CM Records
DJI Mavic Pro
#19 Useril este offline   neataticu
  • Postari: 1428
    Multi roto !
Postat 20 February 2013 - 11:50 PM
vandut. topic closed?
12CM Records
DJI Mavic Pro
