Modelism - RHC Forum: Piper Clipped Wing .....Wot 4 - Modelism - RHC Forum
Piper Clipped Wing .....Wot 4 .......balsa...
#91 Useril este offline   SID
  • Tot ce zboara si nu se mananca
  • Postari: 1453
  • Inregistrat: 26-December 09
Postat 02 November 2014 - 12:13 PM
poze
  • Imagine atasata: DSC_0276.JPG
  • Imagine atasata: DSC_0275.JPG
#92 Useril este offline   SID
  • Postari: 1453
Postat 02 November 2014 - 12:34 PM
poze
https://www.dropbox....C_0274.JPG?dl=0
https://www.dropbox....C_0275.JPG?dl=0
https://www.dropbox....C_0276.JPG?dl=0
https://www.dropbox....C_0277.JPG?dl=0
https://www.dropbox....C_0278.JPG?dl=0
https://www.dropbox....C_0279.JPG?dl=0
https://www.dropbox....C_0280.JPG?dl=0
https://www.dropbox....C_0281.JPG?dl=0
https://www.dropbox....C_0282.JPG?dl=0
https://www.dropbox....C_0283.JPG?dl=0
https://www.dropbox....C_0289.JPG?dl=0
https://www.dropbox....C_0291.JPG?dl=0
https://www.dropbox....C_0292.JPG?dl=0
#93 Useril este offline   SID
  • Postari: 1453
Postat 02 November 2014 - 12:38 PM
si un mic video (calitate slaba dar...)
https://www.youtube....-gF5aqk&edit=vd
Aceasta postare a fost editata de danysoft32: 02 November 2014 - 12:38 PM
#94 Useril este offline   gabyyo9inu
  • Postari: 558
  • Inregistrat: 07-December 12
  • Interests:Tot ce zboara radiocomandat si nu numai...
Postat 02 November 2014 - 02:16 PM
Super Dany... :good:
GabyYO9INU
#95 Useril este offline   SID
  • Postari: 1453
Postat 02 November 2014 - 06:33 PM
Vezi postareagabyyo9inu, la 02 November 2014 - 02:16 PM, a spus:
Da Gaby dar ai vazut inca trage violent dreapta cel putin la decolare, trebuie sa gasesc cauza acestui fenomen. Si vreau sa ma ajutati sa gasim impreuna solutia "victoriosa" sa-l pot zbura relaxat nu sa stau sa "mestec " in stick-uri sa-l tin pe linia de "plutire"
Dan
#96 Useril este offline   renatoa
  • Postari: 19187
Postat 04 November 2014 - 01:16 PM
L-as tura tinandu-l in mana, si daca trage dreapta este unghiul motor, ca static fluxul de aer nu are efect asupra directiei.
Dar nu este un tras dreapta simplu, doar directie cu pastrare nivel, e cu rasucire, ceeace ma face sa banui o torsionare a aripii... :unsure:
#97 Useril este offline   SID
  • Postari: 1453
Postat 04 November 2014 - 01:20 PM
da renato dar ma iut la aripa si nu pare. Repet NU PARE asta nu inseamna ca nu poate fi torsionata...
La ochi nu-mi pare torsionata dar avand in vedere ca am dat cu ea in pamant (instalata pe alt fuselaj) exact in partea dreapta unde a fost si putin reparata, asta ma face sa cred ca ai dreptate chiar daca la ochi pare totul OK
Sa ajung acasa si verifiv, poate o sa termin si aripa ce o am in constructie si vedem daca va mai trage
#98 Useril este offline   Flying Buddha
  • 3D Freestyle
  • Postari: 1429
  • Inregistrat: 19-December 13
Postat 04 November 2014 - 01:39 PM
Vezi postareadanysoft32, la 04 November 2014 - 01:20 PM, a spus:
Daca pui degetele sub ea la mijloc cade in dreapta sau sta balanta? Poate prin absurd ai greutate mai mare pe partea dreapta dar nu stiu daca intr-o situatie de genul acesta ar trage violet spre dreapta. Ai eleroanele alineate perfect? Sigur nu ai cel din dreapta un pic radicat fata de stanga? Nu cumva din poza asa pare cel putin ca ai un pic de diedru negativ? Daca pui echerul sub aripa la mijloc in ambele parti ai diferente mari? Sau ai fix 90 de grade? Ai aliniere cu stabilizatorul orizontal la aripi? Sau e diferenta mare? Pune o linie lunga la capete si iti dai seama si de aici.
Felicitari oricum pentru constructie, arata bine ;).
#99 Useril este offline   SID
  • Postari: 1453
Postat 04 November 2014 - 02:07 PM
Vezi postareabogdan.motrici, la 04 November 2014 - 01:39 PM, a spus:
Bogdane te-ai uitat la toate pozele ?
L-am agatat din fata de la jumatatea fuselajului si l-am tinut de ampenajul verticat cu mana. Nu se lasa in niciuna din parti.
Eleroanele sunt aliniate, am masurat (sa spun asa alinierea...) distanta dintre capetele aripii si capetele ampenajului orizontal (pe diagonala) si este egala. Cu echerul pus cum zici sub aripa nu am verificat (o sa verific si asta). Mai ramane de verificat (pe un plan perfect drept) si torsionarea aripii cum recomanda Renato, de verificat am veificat-o prin metoda "babeasca" adica doar vizual si nu pare, dar ramane de vazut daca e asa.
P.S
Merci de apreciere si modelul tau arata foarte bine :drinks:
#100 Useril este offline   Flying Buddha
  • 3D Freestyle
  • Postari: 1429
Postat 04 November 2014 - 02:56 PM
Vezi postareadanysoft32, la 04 November 2014 - 02:07 PM, a spus:
P.S
Ok, incearca doar cu aripa si degetele puse sub ea la mijloc si vezi de curiozitate.
#101 Useril este offline   SID
  • Postari: 1453
Postat 04 November 2014 - 03:00 PM
o sa verific si asa
#102 Useril este offline   SID
  • Postari: 1453
Postat 04 November 2014 - 05:51 PM
Am inceput verificarile sugerate de voi
1. torsionarea aripii - nu este torsionata
2.verificarea echilibrarii/greutaii - se pare ca aici este o problema (sau asta se pare ca-i cauza...), tinuta de la jumatate se inclina spre dreapta !!! (Bogdane se pare ca ai dreptate)
3.verificarea eleroanelor - sunt pe aceiasi linie, totusi se pare ca la eleronul din dreapta s-au slabit balamalele si la cea mai "finuta" atingere se modifica alinierea cu celalalt
Verificarile continua...
P.S
Multumesc tuturor
sa mai umblu si la ampenaj ? (vertical care este si el inclinat foarte putin spre dreapta, sper ca nu ma inseala ochiulpt.ca nu am cum verifica cu un echer sau mai stiu eu ce instrument de masura din cauza celor 2 baghete de balsa lipite la baza stabilizatorului)
#103 Useril este offline   renatoa
  • Postari: 19187
Postat 04 November 2014 - 05:55 PM
Tinut in mana si turat, fara aripa, ce comportare are ?
Daca se rasuceste puternic ar putea fi supramotorizat, s-ar mai putea corecta din unghi.
#104 Useril este offline   SID
  • Postari: 1453
Postat 04 November 2014 - 05:59 PM
Vezi postarearenatoa, la 04 November 2014 - 05:55 PM, a spus:
acum il verific renato iti spun imediat
#105 Useril este offline   SID
  • Postari: 1453
Postat 04 November 2014 - 06:09 PM
Acum l-am verificat mi-l trage din mana si are tendinta sa-l duca in jos, nu-l trage nici in dreapta nici in stanga
#106 Useril este offline   SID
  • Postari: 1453
Postat 19 November 2014 - 11:14 AM
Revin, cam tarziu dar...
Problema cu trasul in dreapta s-a rezolvat.
Cauza :
aripa neechilibrata, era mai grea pe partea dreapta si de aici si problemele. Am echilibrat aripa si acum totul marge perfect.
Dan :drinks:
P.S
Rezolvarea a fost facuta acum 2 saptamani dar abia acum am postat :pardon:
#107 Useril este offline   pccdtk
  • Postari: 1747
  • Inregistrat: 09-June 02
Postat 24 November 2014 - 03:29 PM
Plan PW-balsa :
  • Imagine atasata: PW_balsa_plan_002a.jpg
Aceasta postare a fost editata de pccdtk: 24 November 2014 - 03:29 PM
#108 Useril este offline   pccdtk
  • Postari: 1747
Postat 24 November 2014 - 03:32 PM
Toate arhivele sunt necesare ( si redenumite doar*.rar ) si contin planul in format *.ai , *.dwg , *.cdr si *.pdf
Aceasta postare a fost editata de pccdtk: 24 November 2014 - 03:34 PM
#109 Useril este offline   SID
  • Postari: 1453
Postat 24 November 2014 - 03:34 PM
Multumim Robert !:clapping: :drinks:
#110 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2400
  • Inregistrat: 05-August 09
Postat 24 November 2014 - 03:39 PM
Vezi postareapccdtk, la 24 November 2014 - 03:32 PM, a spus:
Robert,
trimite-mi si mie fisierele pe mail.
Mersi,
:drinks: :drinks:
Olivian Diaconescu
T one F22-2.7 m in curand..
#111 Useril este offline   SID
  • Postari: 1453
Postat 24 November 2014 - 03:42 PM
Vezi postareaoachidori, la 24 November 2014 - 03:39 PM, a spus:
Robert,
Mersi,
:drinks: :drinks:
downloadeaza-le de aici, dupa care le redenumesti si stergi extensia .txt la toate dupa care extragi fisierul nr 1 si gata le ai
Dan
#112 Useril este offline   pccdtk
  • Postari: 1747
Postat 24 November 2014 - 03:45 PM
Cateva precizari :
- Fuselaj - balsa de 2mm
- Lonjeroane fuselaj 6x3 mm ( pin sau brad )
- Panouri fuselaj - placaj usor de 3 mm
- "Cutie" int.fuselaj - polistiren extrudat de 50 mm
- Ampenaje - balsa 6x6 mm
- Nervuri aripa - balsa 2mm . Cate 6 pe fiecare semiplan ( nervura 3 si 4 apropiate la 12 mm pentru a permite montajul intre ele a unui servo - mini ) astfel incat sa se obtina 100 cm anvergura .
- Lonjeroane aripa 4x4 mm pin sau brad
- "Invelire" bord de atac si de fuga precum si formarea chesoanelor dea lungul nervurilor - balsa de 1.5 mm
#113 Useril este offline   pccdtk
  • Postari: 1747
Postat 24 November 2014 - 04:03 PM
Arhiva nesplituita :
http://www.4shared.c...balsa_plan.html
4 useri citesc topicul
