Modelism - RHC Forum: probleme cu mgm compro 12025-3 Race Boat E-SERIES - Modelism - RHC Forum
probleme cu mgm compro 12025-3 Race Boat E-SERIES nu pot s-al programez
#1 Useril este offline   zaxx
  • Postari: 29
  • Inregistrat: 05-July 10
Postat 03 September 2010 - 09:33 PM
Buna seara
Incerc de ceva vreme sa programez regulatorul de la mgm http://mgm-compro.com/index.php?tid=brushl...e-boat-e-series dar nu-mi iese deloc. Barca merge cam 15-20 de secunde dupa care moare de tot in sunet de bip cam 2/ sec. Scot barca din apa si constat ca motorul este destul de caldut...Toate probele au fost facute fara sa conectez regulatorul la pc (default settings)
Si acum sa ma prezint....
Prima setare este pe magin one de la robbe cu 16 nimh de 3300 si moto ROXXY 3656/ 06 ,1800 rpm/ V, Curent maxim in sarcina 53 A
A doua setare este pe o barca nuoa mini mogli de 400mm cu un motor lehner basic xl de 5000 rpm/V la max 125 A si cell 8 nimh de 3300
incerc sa pun si niste poze... sper ca am spus ce era mai important
Astept cu mare nerebdare raspunsurule voastre ...
date regulator
Controller for motors brushless
Reversible controller yes
Number of Li-Ion, Li-Pol feeding cells 2 - 6
Number of NiCd, NiMh feeding cells 6 - 18
Number of A123 feeding cells 3 -7
Compatible with any feeding cells yes
Operating voltage 6 - 25.5 V
Max. continuous current (for full throttle) 120 A
Max. peak current (peak 5 sec.) 150 A
Version BEC / Switching BEC / OPTO Switching BEC
BEC voltage 5 / 6 V
Max. BEC current at 25 °C 6 A
BEC short circuit protection yes
Number of regulation steps 1024
PWM frequency 8/16/32 kHz
On-state switch (FETs) resistance at 25 °C 2 × 0.40 mohm
Dimensions 50×31×17 mm 1.97×1.22×0.67 in
Dimensions with external capacitor 65×31×17 mm 2.56×1.22×0.67 in
Weight without power conductors 45 g 1.447 oz
Weight incl. all conductors 71 g 2.283 oz
Power conductors cross-section to batt. / to mot. 4/4 mm2 0.0062 in2
Length of the power conductors 110 mm 4.331 in
Servocable cross-section 0.25 mm2 0.0004 in2
Length of the servocable 190 mm 7.480 in
MULTUMESC
  • Imagine atasata: 7.jpg
  • Imagine atasata: 6.jpg
Aceasta postare a fost editata de zaxx: 03 September 2010 - 09:44 PM
#2 Useril este offline   Zue
  • Postari: 1495
  • Inregistrat: 05-January 07
Postat 04 September 2010 - 11:48 AM
incearca sa schimbi acumulatorii cu niste lipo, nimh s-ar putea sa nu-ti dea suficienti amperi
tel.0745026562
#3 Useril este offline   zaxx
  • Postari: 29
Postat 04 September 2010 - 12:04 PM
Vezi postareaZue, la Sep 4 2010, 11:48 AM, a spus:
multumesc de sfat...
asa ma gindeam si eu,dar de ce nu vrea sa mearga pe motourl de la magin one de max 55 A
am folosit aceleasi celule jamara 3300 2x8 cell
#4 Useril este offline   CornelP
  • Postari: 538
  • Inregistrat: 13-June 09
Postat 04 September 2010 - 04:52 PM
Ar trebui vazut ce are pe default la low voltage cutoff. Daca setarea este pe o tensiune mai mare, orice scadere cat de mica a tensiunii va bloca ESC-ul. Daca se poate rearma dupa scurt timp, sigur e LVC-ul... Daca vii duminica, ia si manualul de programare, poate facem ceva pe loc... :)
PS: Bine ai venit!!!
Aceasta postare a fost editata de CornelP: 04 September 2010 - 04:53 PM
#5 Useril este offline   zaxx
  • Postari: 29
Postat 04 September 2010 - 08:40 PM
Vezi postareaCornelP, la Sep 4 2010, 04:52 PM, a spus:
Ar trebui vazut ce are pe default la low voltage cutoff. Daca setarea este pe o tensiune mai mare, orice scadere cat de mica a tensiunii va bloca ESC-ul. Daca se poate rearma dupa scurt timp, sigur e LVC-ul... Daca vii duminica, ia si manualul de programare, poate facem ceva pe loc... http://www.rhcforum....tyle_emoticons/default/tongue.gif
Multumesc de primire...
Asa cum am crezut este setat la 0,96 v,cred ca este suficient ?
Am facut un print screen cu setarile in default...si manualul .... http://mgm-compro.com/manuals/en-manual-tm...-d240808-02.pdf
Specific ca de fiecare data cind am facut teste accu erau incarcati bine.
  • Fisier atasat  1.doc (128.5K)
#6 Useril este offline   CornelP
  • Postari: 538
Postat 04 September 2010 - 09:58 PM
Incearca sa-i setezi numarul de celule si tipul lor...
  • Imagine atasata: setari_esc.jpg
#7 Useril este offline   fulgerica
  • Postari: 2235
  • Inregistrat: 31-July 07
  • Interests:vintage
Postat 05 September 2010 - 01:31 AM
Vezi postareazaxx, la Sep 4 2010, 01:04 PM, a spus:
pt ca bateriile acelea nu-ti dau nici macar 30A continuu nici atunci cand sunt noi.
vino pe YOR si-ti imprumutam celule de care vrei si o sa vezi ca merge.
bateriile sunt f importante. o sa vezi ca si cele lipo, mai ales hobbyzbang, pica dupa un timp si nu-ti mai dau curentul necesar si barca o sa se manifeste la fel cum ai descris.
Aceasta postare a fost editata de fulgerica: 05 September 2010 - 01:33 AM
Laser frate!
#8 Useril este offline   zaxx
  • Postari: 29
Postat 05 September 2010 - 07:54 PM
Multumesc tuturor celor care m-au ajutat cu acest regulator...
Se pare ca este de la cell... amperajul prea mic ...
#9 Useril este offline   nitroshift
  • Postari: 128
  • Inregistrat: 22-June 09
Postat 05 September 2010 - 08:04 PM
Daca te ajuta cu ceva, ne putem vedea pe balta langa romtelecom si aduc si un 6s cu mine aproape nou (2 incarcari cu balancer).
#10 Useril este offline   iony
  • Postari: 2346
  • Inregistrat: 06-April 07
Postat 05 September 2010 - 08:24 PM
si ce sa faca cu el |?
sa il puna sus pe barca
este mare
lui ai trebuie 3cel de 2200ma 40c descarcare
#11 Useril este offline   nitroshift
  • Postari: 128
Postat 05 September 2010 - 08:38 PM
Am si un 3S / 4000mAh... E bun?
#12 Useril este offline   iony
  • Postari: 2346
Postat 05 September 2010 - 08:55 PM
nop
nu incape
barca are cam 50cm
#13 Useril este offline   usulica
  • Postari: 417
  • Inregistrat: 13-April 09
  • Interests:modelism ( navo , auto ) , arte martiale , calatorii , colectii , carti , filme
  Postat 17 September 2010 - 03:36 AM
Vezi postareanitroshift, la Sep 5 2010, 09:38 PM, a spus:
salut nitroshift!
cred ca sunt bune lipo ale tale 3s de 4000 si chiar si cele 6s dar nu stiu daca tine motorul la cea de-a doua barca magin one de la robbe :)
de ajuns la baneasa linga romtelecom ajungem sigur dar sa vedem mai exact cind ca trebuie sa ne punem de acord si cu okazia asta sa facem citeva teste klumea :D
te anunt aici sau pe thread-ul tau cu van lines ok?
merci!
p.s. cam asa arata regulatorul cu pricina
  • Imagine atasata: 120_24_3.JPG
Only performance matters!!!
0722733067 / 0744977799 / 0768740960 / 0771661458
YM: cbanica1 , MSN: cbanica
#14 Useril este offline   nitroshift
  • Postari: 128
Postat 17 September 2010 - 08:16 AM
E in regula, cu singura problema ca eu incep serviciul luni, deci ne vom putea vedea doar seara sau in week-end...
