Modelism - RHC Forum: Vand Belt-CP nou de la E-SKY RTF Galben - Modelism - RHC Forum
#1 Useril este offline   degette
  • Postari: 47
  • Inregistrat: 08-April 10
  Postat 21 June 2010 - 06:55 PM
Specification:
Leght - 650 mm
Height - 230 mm
Main Rotor Blades diameter - 680 mm
Tail Rotor Blades diameter - 130 mm
Flight weight - 670 gr
Empty weight - 340 gr
Motor - 450 brushless motor
Rotate Ratio 12:140/10:22
ESC - 25A Brushless speed controller
Gyro - Esky professional gyro
Servo - 8g x 4 pcs
Transmitter - 6 channels or above 6 channels ( helicopter sistem ) CH 78 / FM 35,180
Receiver - 6 channel or above 6 channels
Battery - LI- Poly battery 1800 mah,11.1 V, 20 C discharge
Caracteristici:
CCPM Systems
Auto-Rotation systems
Tail belt drive system
High intertial main blade
High rigidity I-RON main shaft
Shock proof I-RON landing skids
Full ball bearing & metel ball end
High strenght carbon fibre tail stand bar
Full Alluminiu
Ne zburat ,ne reglat, cu piese de rezerva noi ( Tail rotor , main rotor , rigla pale, suport pale,etc)
Pret 350 Euro + 50 euro piesele
Poze la cerere,(sunt prea mari si nu merg incarcate aici)
Tel 0764313552
#2 Useril este offline   degette
  • Postari: 47
  Postat 23 June 2010 - 03:57 PM
Am adaugat poze
#3 Useril este offline   degette
  • Postari: 47
Postat 03 August 2010 - 10:31 PM
up
#4 Useril este offline   degette
  • Postari: 47
Postat 23 August 2010 - 11:54 AM
up
#5 Useril este offline   degette
  • Postari: 47
Postat 12 September 2010 - 02:19 PM
up
#6 Useril este offline   degette
  • Postari: 47
Postat 26 October 2010 - 05:38 PM
300 euro cu tot cu piese.
#7 Useril este offline   nelu77
  • Postari: 337
  • Inregistrat: 01-April 09
  Postat 26 October 2010 - 06:24 PM
Vezi postareadegette, la Oct 26 2010, 06:38 PM, a spus:
300 EURO ??? ...sau e o gresala... :huh:
este mai jos un anunt cu cca. 400 RON ...daca nu ma insel - pt. acelasi model RTF.
#8 Useril este offline   RAPTOR
  • Postari: 277
  • Inregistrat: 05-December 09
  • Interests:heli,aero......
Postat 27 October 2010 - 07:11 PM
Nu mi se pare deloc ciudat,omul a mai avut un anunt in care cerea tot cam dublu decat daca il luai singur de nou.
#9 Useril este offline   degette
  • Postari: 47
Postat 31 January 2011 - 02:20 AM
up
