Modelism - RHC Forum: De care Motor - Modelism - RHC Forum
De care Motor mai puternic un pic decat 755
#31 Useril este offline   laurcon
  • Postari: 804
  • Inregistrat: 26-October 09
Postat 15 February 2010 - 07:44 PM
Cauta aici la rubrica hobbis http://www.conrad-int
Sunt niste motoare Igarashi care se incadreaza in ceea ce cauti tu, si la 6 si la 12v .
Cei de la Conrad Romania ti le pot aduce.
Aceasta postare a fost editata de laurcon: 15 February 2010 - 07:44 PM
"o barca face cat o mie de posturi" - skipper
#32 Useril este offline   Navi
  • Postari: 35
  • Inregistrat: 16-February 10
Postat 17 February 2010 - 01:06 AM
http://www.alibaba.c...v_DC_MOTOR.html
http://www.alibaba.com/product-gs/26141708...V_dc_motor.html
http://www.alibaba.c...0/dc_motor.html
http://gdsanxing.en.alibaba.com/product/26...V_dc_motor.html
#33 Useril este offline   Navi
  • Postari: 35
Postat 20 February 2010 - 12:13 AM
Ăsta cred că este motorul pe care îl cauți Graupner SPEED 720 BB Torque, am să-l comand si eu.
http://www.rokemodel...gr/gr6372gb.htm
Sau mai uităte aici
http://homepage.ntlworld.com/edward.matthe...rs/graupner.htm
http://www.sussex-mo...exd.asp?id=1206
#34 Useril este offline   ipsihi
Postat 20 February 2010 - 01:02 AM
...este sub 755/40, aici ai 4100rpm vs 5000, se pare ca se exista o diferenta!!!
#35 Useril este offline   manolo
  • Postari: 3555
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 20 February 2010 - 01:38 AM
Sugerez un Igarashi 4260-30 ,85W
Barcute intinse!
Tel. 0744915775
#36 Useril este offline   mariandmd
  • Postari: 2161
Postat 20 February 2010 - 09:35 AM
intradevar
incearca un 900 bb
Aceasta postare a fost editata de mariandmd: 20 February 2010 - 09:36 AM
#37 Useril este offline   sand man
  • Postari: 167
  • Inregistrat: 18-January 10
Postat 20 February 2010 - 09:56 AM
Vezi postareamariandmd, la Feb 20 2010, 10:35 AM, a spus:
intradevar
incearca un 900 bb
Corect!
La aceeasi tensiune si amperaj :
755/40....................32W
700 BB....................30W
900BB......................99W :D
“Keep the voltage high ”
#38 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 20 February 2010 - 01:42 PM
Vezi postareasand man, la Feb 20 2010, 09:56 AM, a spus:
Corect!
900BB......................99W :)
Este si asta o varianta si mai sint si altele,dar ar fi trebuit trecut si consumul in A si rot/min ,ca sa poti face o comparatie corecta.
Barcute intinse!
Tel. 0744915775
#39 Useril este offline   sand man
  • Postari: 167
Postat 20 February 2010 - 01:54 PM
@manolo
ai citat chiar tu :
la aceeasi tensiune si amperaj
Ce nu e corect, pentru o comparatie ?Informatia e completa.
Daca e nevoie pot da si turatia si amperajul . Nu e nici un secret .
Aceasta postare a fost editata de sand man: 20 February 2010 - 01:58 PM
#40 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 20 February 2010 - 02:47 PM
Nu e vorba de secret datele sint publice ,daca la 12 V sint de acord ,dar din caracteristica motoarelor nu pot avea acelasi consum ,atit timp cit puterile sint diferite .
Barcute intinse!
Tel. 0744915775
#41 Useril este offline   oxygen2k8
  • Postari: 425
  • Inregistrat: 24-November 09
  • Interests:Pescuitul
Postat 20 February 2010 - 04:54 PM
Mai puternic decat 755/40.... ar fi doua 755/40 :rolleyes:
It's time to go outside and play now!
#42 Useril este offline   sand man
  • Postari: 167
Postat 20 February 2010 - 06:15 PM
Vezi postareamanolo, la Feb 20 2010, 03:47 PM, a spus:
Ce te faci ,ca mai apare si turatia la mijloc ? Uups!
:) :rolleyes: :D
#43 Useril este offline   sand man
  • Postari: 167
Postat 20 February 2010 - 06:40 PM
@ manolo
Te asigur ca datele sint corecte .Aproximative , dar corecte.
Acum imi dau seama unde ai facut confuzia , e vorba de puterea la axul motorului .
Aceasta postare a fost editata de sand man: 20 February 2010 - 06:49 PM
#44 Useril este offline   Stavrica George Cristian
  • Postari: 734
  • Inregistrat: 14-August 08
  • Interests:Pescuit, Modelism
Postat 20 February 2010 - 07:56 PM
oxygen 2 motoare 755 vor da aceeasi viteza...doar cuplul va creste...si bineinteles consumul
deci pana la urma ce ma sfatuiti sa iau.?
pe mine ma intereseaza sa aiba barca viteza ....un pic mai tare ca un 755/40, cine il stie cum merge cu elica de 50mm
si un consum intre 5-7 amperi...
va multumesc celor care au incercat sa vina cu o propunere
tel.0722359121
stavrica.george@gmail.com
#45 Useril este offline   amador
  • Postari: 802
  • Inregistrat: 29-March 08
Postat 20 February 2010 - 08:08 PM
Vezi postareamanolo, la Feb 20 2010, 02:47 PM, a spus:
ba da...un bl are la acelasi consum mai multa putere la ax decat un periat...vezi diferenta de randament dintre ele :)
#46 Useril este offline   sand man
  • Postari: 167
Postat 21 February 2010 - 08:06 AM
Amador, manolo se referea la cele trei motoare care sint toate periate, dar nu stiu la ce putere se gindea.
In nici un caz la puterea la ax adica puterea mecanica a motorului , data de produsul dintre turatie si cuplu .
La aceeasi tensiune si amperaj ea difera de la motor la motor pentru ca difera cuplu si turatia.
bafta!
#47 Useril este offline   sand man
  • Postari: 167
Postat 22 February 2010 - 05:40 PM
Corect!
900BB......................99W :o
Baieti , aici e gogonata rau de tot.
La 900BB torque , 99W! Imposibil !Cam ce eficienta ar fi necesara?
Nu stiu cum a fost posibil si ma mir ca nu a observat nimeni sa faca corectia.
Pun mai jos ,daca are nevoie cineva, pentru comparatii, turatii si cupluri ale motoarelor respective:
750/40
12,4V..................4,02A..............66,7 mN .m....................4672rot / min...............32,6 W
720BB torque
12,32V.....................4,o7A..............106,8 mN .m.................2918rot / min.................32 W
900BB torque
12,32V..................4,142A................72 mN .m.................6315 rot / min..................47,54 W
Sper sa nu fi gresit nimic de data asta :)
#48 Useril este offline   ipsihi
Postat 22 February 2010 - 05:47 PM
...de aici!!!
Speed 900 BB TORQUE SMC-M-6373
Nominal Voltage 12.0v - Voltage Range 6.0 - 40v - No load RPM 6,500 - No Load Current 1.1 A - Current @ Max Efficiency 8.0 A - Stalled Current 54A - Max Efficiency 71 % - Case length mm 95.0 - Case dia. mm 51.5 - Free shaft length mm 15.0 - Shaft Dia. mm 6.00 - Weight (g)645
...de departe este cel mai eficient in clasa periatelor de consum mic, dar negasind in ro asa ceva, pretul devine prohibitiv in fata altor solutii de motorizare!!!
Aceasta postare a fost editata de ipsihi: 22 February 2010 - 05:49 PM
#49 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 22 February 2010 - 08:10 PM
S-au poate alegi ceva de aici:
Barcute intinse!
Tel. 0744915775
#50 Useril este offline   BillyBoy32
  • Postari: 756
  • Inregistrat: 18-August 08
Postat 06 March 2010 - 10:56 PM
Vezi postareacricri_pescar68, la Jan 16 2010, 04:04 PM, a spus:
motorul postat de ipsihi al folkosesc si cei de lla rahova de pe strada iliada acest motor sa cam ancinge si cam face condens an barca gasiti apa a patito un ptieten deal meu ia cam ruginit ceva pe acolo
Frate esti de-a dreptul criminal :rolleyes: , ti-am citit topicurile cu mare interes si am ras cu lacrimi (fara caterinca). Pe bune acum, este chiar atat de grea gramatica asta si Lb. Romana?
ON - Poti sa incerci cateva motorase de la minicompresoare auto! Eu am nimerit un motoras de care spun, destul de bun si la ora actuala merge fara probleme si ca racire i-am pus un cooler micut (a fost mai mult decat suficient) .Dar daca doresti un motor mai bun decat cel care il folosesti , trebuie sa iei in considerare mai multi factori: elica potrivita, dimensiunea si greutatea barcii si din cate am inteles si antibradisul cauzeaza vitezei. Motorasul care il am , este pus pe un ''sicriu'' in greutate totala de 7 Kg,gata de plantat si avea un consum de (intre) 5-6A. Sunt convins ca pe o barca mai ''ascutita'' ,(gen cele facute de domnul Ipsihi) aceste motorase dau un randament mai bun decat clasicul 755. Stima!!
Aceasta postare a fost editata de BillyBoy32: 06 March 2010 - 11:04 PM
#51 Useril este offline   bogdan_minitehnicus
  • Postari: 1275
  • Inregistrat: 20-April 07
Postat 08 March 2010 - 05:31 PM
Vezi postareaStavrica George Cristian, la Jan 14 2010, 08:46 PM, a spus:
As dori si eu sa pun pe barca un motor mai puternic decat 755,sa aiba barca un pic mai multa viteza, dar care sa nu consume enorm
Astept sugestiile voastre...fie la 6V fie la 12 V
nimik mai simplu in loc de 12 v il alimentezi la 14 celule si o elice tripala de 5. Merge impecabil l-am testat
#52 Useril este offline   sand man
  • Postari: 167
Postat 08 March 2010 - 06:17 PM
...de ce nu 16 celule , eu tocmai vreau sa experimentez asta acum. E adevarat , mai greu cu regulatorul, la ce preturi sint la noi in tara.
#53 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 10 March 2010 - 11:38 AM
16 celule nu merg...la specificatiile motorului zice ca merge pana la 18 v
tel.0722359121
#54 Useril este offline   sand man
  • Postari: 167
Postat 11 March 2010 - 08:23 AM
Vezi postareaStavrica George Cristian, la Mar 10 2010, 11:38 AM, a spus:
Deocamdata astept sa primesc regulatorul si acumulatorul . Dupa ce fac testele va spun care a fost rezultatul.
Parerea mea este ca daca merge la 18 V merge si la 20V .
Dar m-as mira sa nu-l fi testat cineva la tensiunea asta deja. Nu e nimeni care sa ne spuna cum sta treaba?
#55 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 12 March 2010 - 07:19 PM
nu ma mai intereseaza varianta de 12 v,iese barca prea grea
ma intereseaza un motor de 6v care sa fie asemanator cu 755...
multumesc
tel.0722359121
#56 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 12 March 2010 - 07:36 PM
a probat cineva un CLASH 21 ??
tel.0722359121
#57 Useril este offline   Adistul
  • Postari: 1490
Postat 12 March 2010 - 09:48 PM
Vezi postareaObelixx, la Mar 11 2010, 05:38 AM, a spus:
Sau din seria Igarashi, unul din astea, si daca se baga cineva sa aduca sunt amator
H5088-009-GF-7 sau H5088-012-GF-7 http://www.igusa.com...tors/H5088.html
5088-013-GF-7 http://www.igusa.com...otors/5088.html
par OK motoarele. a testat cineva vreo 1? interesant e si Clash21 dar pe un Lipo de 3 celule.
Aceasta postare a fost editata de Adistul: 12 March 2010 - 09:50 PM
La fel e si cand esti prost.
tel: 0771 088 207
adistul@yahoo.com
#58 Useril este offline   irion
  • Postari: 286
  • Inregistrat: 11-September 08
Postat 12 March 2010 - 10:38 PM
Vezi postareaAdistul, la Mar 12 2010, 09:48 PM, a spus:
Se presteaza perfect un clash 21 cu reductor planetar la 6 V,insa costul este mult prea ridicat datorita reductorului care stim bine ce pret are.
#59 Useril este offline   Stavrica George Cristian
  • Postari: 734
Postat 12 March 2010 - 11:20 PM
cam cat consuma cu reductor planetar de la si__ra???
tel.0722359121
#60 Useril este offline   sand man
  • Postari: 167
Postat 13 March 2010 - 07:47 AM
Vezi postareaStavrica George Cristian, la Mar 12 2010, 07:19 PM, a spus:
multumesc
Te rog spune-mi si mie , cum ai putea sa ai un cistig in privinta greutatii mergind pe varianta de acumulator Pb de 6V ?
15 useri citesc topicul
