Modelism - RHC Forum: SUNDOWNER 50 - Modelism - RHC Forum
SUNDOWNER 50 SA VINA IN HANGARUL MEU!
#1 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
  • Inregistrat: 03-February 07
  • Interests:AEROMODELISM
Postat 10 February 2009 - 11:40 PM
http://www.youtube.com/watch?v=Hr1OBW1u0sU...id=f886acb0cee8
ADOR VITEZA!!!
#2 Useril este offline   andreirosca
  • Postari: 271
  • Inregistrat: 08-December 06
Postat 10 February 2009 - 11:55 PM
vrei viteza ! se pare ca x-treme doar a deschis pofta de viteza
#3 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 10 February 2009 - 11:56 PM
DA ! :blink: ...ce-i drept asta e la capitolul termice.
ADOR VITEZA!!!
#4 Useril este offline   andreirosca
  • Postari: 271
Postat 11 February 2009 - 12:01 AM
arata bine si cred ca e super bine lucrat (hangar 9) merita !
#5 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 February 2009 - 12:04 AM
aduce cu POLE-CAT ..dar are alte caracteristici de zbor vad ....e super avionul asta ( din punctul meu de vedere ) .l-am cam studiat de o vreme , si am auzit lucruri bune despre el!
Aceasta postare a fost editata de TUROK: 11 February 2009 - 12:05 AM
ADOR VITEZA!!!
#6 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 February 2009 - 12:13 AM
Specs
* Wing Span:63 in. (1600mm)
* Overall Length:47.4 in. (1204mm)
* Wing Area:572 sq. in. (36.9 sq. dm.)
* Flying Weight:6-7 lbs (2.7-3.2 kg.)
* Engine Size:.40 -.52 2-stroke glow or .56 - .82 4-stroke glow
* Motor Size:E-Flight Power 46BL Outrunner Motor (EFLM4046A)
* Radio:4 channels minimum; 5 recomended
* Servos:requires 5 standard servos
* Trim Scheme Colors:Pearl Charcoal HANU846, Silver HANU881, White HANU870, Orange HANU877
* CG (center of gravity):2 1/2 in. back from the leading edge at the fuselage
* Wing Loading:24.2 - 28.2oz per sq. ft.
Aceasta postare a fost editata de TUROK: 11 February 2009 - 12:15 AM
ADOR VITEZA!!!
#7 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 February 2009 - 12:23 AM
Based on the Sundowner Formula 1 80-inch giant-scale racer, this speedy sport performer has a scaled-down aggressive racer body design that always makes it look like it’s tearing through the sky. Because of its smooth flight characteristics and precise, sport handling, even intermediate pilots will feel comfortable behind the sticks. Unlike other racers that may be difficult to fly, the Sundowner 50’s streamlined design makes this racer smooth, precise and ready-to-roll. It may look like a racer thanks to its body design, but it is an aerobatic sport model geared for performance.
The .50-size Sundowner can be powered for performance using a variety of 2- or 4-stroke glow engines or converted to electric power for clean, no-fuss flying. The two-piece plug-in wing makes transporting this aircraft an easier process. A removable top hatch provides access to the plane’s interior to make it easy to get to the electronics and/or fuel tank. The Sundowner also includes installed high-quality prehinged hardware and a heavy-duty anodized aluminum wing tube which provides extreme durability at low weight.
So take the Sundowner 50 ARF to the flying field—and enjoy all the stares you get as it streaks into a turn at mach speed.
Aceasta postare a fost editata de TUROK: 11 February 2009 - 12:26 AM
ADOR VITEZA!!!
#8 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 February 2009 - 12:39 AM
in acest filmulet poate imi explica si mie cineva ce tip de statie are tipul care piloteaza ..... :blink:
http://www.youtube.c...mcc8Yd5Rno&NR=1
ADOR VITEZA!!!
#9 Useril este offline   REAL DESIGN
Postat 11 February 2009 - 09:01 AM
Modelele astea tip "RACER" nu vor avea viata usoara pe pista de la Chitila.
Daca vei urmarii filmele cu ele o sa observi ca au piste de beton sau iarba
perfect nivelata ( iar de multe ori pt. reclama pilotii lor sunt foarte buni ).
Daca il urmaresti pe Silvestri in filmele lui nu se vor asemana aterizarile cu
ce a patit Romulus cu Sebart-ul lui ( si de Romulus nu poti spune ca nu stie sa piloteze )
La fel se intampla si cu modelele militare scale.
Oricum alegerea se face si cu sufletul ! Bafta !
#10 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 11 February 2009 - 10:30 PM
daca zici tu! B)
ADOR VITEZA!!!
#11 Useril este offline   Rontaila
  • Postari: 324
  • Inregistrat: 29-May 07
  • Interests:Tot ce zboara cu motor sau se scufunda in mare
Postat 12 February 2009 - 08:26 AM
Curajoasa alegere ,saptamana trecuta avea GIRO unul pe stoc. B)
Primul sosit ,ultimul plecat..
#12 Useril este offline   protheus
  • 日本語
  • Postari: 1719
  • Inregistrat: 26-August 07
Postat 12 February 2009 - 09:46 AM
Vezi postareaTUROK, la Feb 11 2009, 12:39 AM, a spus:
poate imi explica si mie cineva ce tip de statie are tipul care piloteaza ..... :blush:
Astept si eu sa zica cineva ce statie e. Piloteaza foarte bine, si la o singura mana.
E super avionul, dar vitezoman nonstop, cam greu cu aterizarile.
Aceasta postare a fost editata de protheus: 12 February 2009 - 09:47 AM
#13 Useril este offline   REAL DESIGN
Postat 12 February 2009 - 10:15 AM
Fratele lui mai mare este si mai tare !
#14 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 12 February 2009 - 10:21 AM
pai da! fratiorul mai mare are urmatoarea specificatie :
# Wing Span:80.5 in (2045mm)
# Overall Length:60.6 in (1539mm)
# Wing Area:933 sq in (60.2 sq dm)
# Flying Weight:12.0-14.0 lb (5.4-6.4 kg)
# Engine Size:26-35cc gas; 1.20-1.80 4-stroke; 1.00-2.10 2-stroke
ADOR VITEZA!!!
#15 Useril este offline   REAL DESIGN
Postat 12 February 2009 - 10:39 AM
Io pe asta pusesem ochii dar m-au linistit baietii care au Katana de la Krill
si care o zboara doar pe Clinceni , pe Chitila au spus ca s-ar putea sa nu ajunga pista
lasand la o parte gropile ( iar ei cand vin la aterizare o aduc langa picior daca vor ) ...
io l-as fi adus langa bunicu poate. ...
Oricum ce e frumos e frumos !
#16 Useril este offline   andreirosca
  • Postari: 271
Postat 12 February 2009 - 01:57 PM
Vezi postareaTUROK, la Feb 11 2009, 01:39 AM, a spus:
in acest filmulet poate imi explica si mie cineva ce tip de statie are tipul care piloteaza ..... :blush:
eu unul nu am gasit nimic dar poate ne lamureste cineva !
#17 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 12 February 2009 - 08:55 PM
se pare ca nu prea stie nimeni ..... :rolleyes:
minutul 2:26 al filmuletului .
Aceasta postare a fost editata de TUROK: 12 February 2009 - 08:58 PM
ADOR VITEZA!!!
#18 Useril este offline   pe3scu
  • Postari: 84
  • Inregistrat: 31-March 08
Postat 12 February 2009 - 09:52 PM
Eu zic ca e manufacturata, ca nu are de loc aspect (design) comercial. E in 2,4GHz, dar pare ca are pe cutie si antena pentru benzile in MHz (antena nu este intinsa). Nu se vede prea bine, ar putea fi si un stick.
Oricum, mosulica poate avea orice in cutia aceea. E derutant cum o tine.
Pareri?
_
#19 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 12 February 2009 - 09:57 PM
pai da , asta ma miram si eu ...dar cum accelereaza doar dintr-o mansa? :rolleyes:
ADOR VITEZA!!!
#20 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 12 February 2009 - 10:01 PM
oricum ..tare ma mananca buzunarul ! ..de unul marisor ...hmmm :rolleyes:
ADOR VITEZA!!!
#21 Useril este offline   pe3scu
  • Postari: 84
Postat 12 February 2009 - 10:31 PM
Vezi postareaTUROK, la Feb 12 2009, 09:57 PM, a spus:
pai da , asta ma miram si eu ...dar cum accelereaza doar dintr-o mansa? :mellow:
Pare ca are o mansa pe care o impinge (sau trage) cu degetul aratator de la mana dreapta.
_
#22 Useril este offline   takeoff
  • Postari: 1029
  • Inregistrat: 25-July 08
Postat 13 February 2009 - 12:50 AM
Pare o statie Futaba remontata in carcasa home made,dar cu multe posibilitati(utilaje) sticul are 5 comenzi,prin rotire actioneaza gazul si cred ca mai are niste comenzi care nu sunt vizibile in film.Oricum e tare!!!!!!!!!!!!!
#23 Useril este offline   andreirosca
  • Postari: 271
Postat 13 February 2009 - 12:44 PM
pare ca ar avea regim motor si probabil si alte comenzi undeva dedesubt pentru mana stanga ...
#24 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 15 July 2009 - 07:32 PM
Next ! ....urmeaza BIG SUNDOWNER ! ...CURATA BIJUTERIE DE VITEZA . :rolleyes: muhahah
ADOR VITEZA!!!
#25 Useril este offline   shogi
  • Postari: 2753
  • Inregistrat: 08-March 06
  • Interests:pussy
Postat 16 July 2009 - 03:40 PM
poze poze poze pooooozzzzzzeeeeeeee :) :)
6 useri citesc topicul
