Modelism - RHC Forum: Jurnal de zbor Braila-Galati - Modelism - RHC Forum
  • 283 Pagini +
  • 252
  • 253
  • 254
  • 255
  • 256
Jurnal de zbor Braila-Galati sau Galati-Braila...
#7591 Useril este offline   tantar
  • Postari: 2745
  • Inregistrat: 01-November 08
Postat 18 March 2016 - 08:17 PM
Vezi postareaGigiGL, la 18 March 2016 - 07:42 PM, a spus:
Si eu as vrea, dar maine se anunta frig si vant, nu ca astazi...
Deci alea fara flapsuri aterizeaza mai bine.
Trex 700 V BAR
FMS P-51 D MUSTANG 1700 mm
JU- 87 STUKA 1920 mm
A-10 Freewing 1700 mm EDF
FMS F 4U CORSAIR 1700 mm
FW 190 HYPE
Futaba T-8FG x 2
#7592 Useril este offline   hype
  • Postari: 1280
  • Inregistrat: 05-February 11
Postat 18 March 2016 - 08:38 PM
La multi ani Victor,sa ai parte de tot ce-ti doresti si la cat mai multe zboruri,cu aterizari line!
#7593 Useril este offline   incepatoru
  • Postari: 2863
  • Inregistrat: 30-May 09
  • Interests:aero
Postat 18 March 2016 - 09:23 PM
Vezi postareahype, la 18 March 2016 - 08:38 PM, a spus:
da da daaaa La multi ani..nene Victorio..
#7594 Useril este offline   Ainshtain
  • Postari: 537
  • Inregistrat: 20-February 14
  • Interests:Aero, navo
Postat 19 March 2016 - 03:07 PM
Furtunul de fum, trebuie sa fie din neopren neaparat? Nu poate fi si din silicon ca la nitro, ca si ala sta lipit de toba si nu are nimic......?
Stamatin Radu
#7595 Useril este offline   Ainshtain
  • Postari: 537
Postat 19 March 2016 - 07:19 PM
http://youtu.be/HBe2YAWY3kU
Prima pornire pe fuselaj..... In curand va fi in aer.... 2-3 saptamani!
Partea proasta... Estimarea mea la greutate se adevereste... 7900-8000 grame
Aceasta postare a fost editata de Ainshtain: 19 March 2016 - 07:22 PM
Stamatin Radu
#7596 Useril este offline   tantar
  • Postari: 2745
Postat 19 March 2016 - 09:33 PM
Mâine se iese?
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7597 Useril este offline   victorio
  • Postari: 359
  • Inregistrat: 02-February 10
  • Interests:Aero
Postat 20 March 2016 - 07:29 AM
Un V.A. ceva
#7598 Useril este offline   victorio
  • Postari: 359
  • Interests:Aero
Postat 20 March 2016 - 07:31 AM
Nu este frig,bate vantul,este inorat.
#7599 Useril este offline   Maveriick
  • Postari: 204
  • Inregistrat: 08-November 07
Postat 20 March 2016 - 07:41 AM
Pe la 11 cica se inoureaza ! Acu dim bate vantu cu 20km/h
Incarcam ceva baterii ???
Danger is real -> Fear is a choice!
#7600 Useril este offline   tantar
  • Postari: 2745
Postat 20 March 2016 - 08:27 AM
Vezi postareaMaveriick, la 20 March 2016 - 07:41 AM, a spus:
Propun pe la 11-12 . Voi ?
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7601 Useril este offline   GigiGL
  • Postari: 2107
  • Inregistrat: 10-March 11
  • Interests:Aero
Postat 20 March 2016 - 10:27 AM
Eu si Edy suntem pe camp. Bate vantul tare. Momebtan nu zburam.
Gigi Sterian
Rascal 1940mm fs.61 nitro
Rascal 120 DLE 30
U Can Do .46 nitro .52, 2T
Beaver 1520
Maule 1500
Helios 2545
#7602 Useril este offline   Ainshtain
  • Postari: 537
Postat 20 March 2016 - 07:26 PM
.... Si a mai facut Radu o prostie....
http://youtu.be/v9GLc7WlJwM
Stamatin Radu
#7603 Useril este offline   GigiGL
  • Postari: 2107
  • Interests:Aero
Postat 20 March 2016 - 08:57 PM
Gigi Sterian
Rascal 120 DLE 30
Beaver 1520
Maule 1500
Helios 2545
#7604 Useril este offline   incepatoru
  • Postari: 2863
  • Interests:aero
Postat 21 March 2016 - 09:07 AM
[quote name='Ainshtain' timestamp='1458494765' post='847369']
..bun asa.. pompa ,esc,rezervor inca 400grame da-i bice sa-l vedem la camp..
#7605 Useril este offline   Ainshtain
  • Postari: 537
Postat 21 March 2016 - 09:36 AM
Gata gata ... nu mai adauga greutate ca deja sunt luate in calcul :drinks:
Aceasta postare a fost editata de Ainshtain: 21 March 2016 - 09:39 AM
Stamatin Radu
#7606 Useril este offline   bogdan_bacau
  • Postari: 778
  • Inregistrat: 23-March 13
Postat 21 March 2016 - 10:32 PM
Vezi postareaAinshtain, la 20 March 2016 - 07:26 PM, a spus:
Salutare !!! Intrebare ..de unde ai cumparat lichid de fum?mai e prin tara ? Si eu am instalatie de fum..dar sa cam golit bidonu.😃 super fain.Tineo tot asa.
#7607 Useril este offline   Ainshtain
  • Postari: 537
Postat 21 March 2016 - 10:39 PM
Citeste descrierea de la filmulet, ulei Johnson si motorina amestec 1/1 mai vreau sa incerc ceva dar nu spun ce, nu am vazut inca folosit pe undeva dar nu spun ce, e un secret, hihihi.... Ori cum trebuie sa mai reglez pompa care o am sau sa cumpar una cu role pentru uz medical care imi da debit de max 200ml/min, asta care o am imi da 2 l/min la full, de aia o tin de abea porneste motorasu si ma opresc, fumul din filmulet e dintr-o 100 ml de amestec, si dupa cum se vede 20 de secunde si s-a dus.... Cred ca mai mult am dat pe jos....
Stamatin Radu
#7608 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 22 March 2016 - 09:28 AM
Vezi postareaAinshtain, la 21 March 2016 - 10:39 PM, a spus:
😂😂😂😂 frumos ori cum.eu luasem de la kelemen ultimul bidon de smoke oil blue.Prin tara nu se mai gasesete.Ce e doar prin afara.O sa incerc si eu reteta asta.Poate sa dus pe jos..din cauza ca nu era turat..zic si eu.Eu am sbach 300 cu DLA 32cc.Iar toba nu a foat prevazuta cu stut.Am facuto eu...si la mine dupa aterizare..gasesc modelul plin de ulei..ceva nu e in regula.Si un rezervor de 190ml tine cam un minut.
#7609 Useril este offline   Ainshtain
  • Postari: 537
Postat 22 March 2016 - 09:49 AM
E debitul mare.... Ce am citit debitul trebuie sa fie intre 60 si 180 ml/min
ce am filmat este al 2-lea test, la primul test mi-a tinut cam un minut jumate cu o cantitate de 100 - 120 mililitri in rezervor...
uite mai jos un tabel cu volumul rezervorului si debitul de fluid din care rezulta un timp estimat de functionare....
debit
rezervor 2oz./min 4oz./min 6oz./min
2oz. 1 min 0.5 min 20 sec
4oz . 2 min 1min 40 sec
6oz. 3 min 1.5 min 1min
8oz. 4 min 2min 1.33 min
10oz. 5 min 2.5 min 1.66 min
12oz. 6 min 3.0 min 2min
14oz 7 min 3.5 min 2.33 min
16oz. 8 min 4.0 min 2.66 min
18oz. 9 min 4.5 min 3min
20oz. 10min 5.0 min 3.33 min
22oz. 11min 5.5 min 3.66 min
24oz. 12min 6.0 min 4 min.
Stamatin Radu
#7610 Useril este offline   incepatoru
  • Postari: 2863
  • Interests:aero
Postat 22 March 2016 - 10:32 AM
Vezi postareabogdan_bacau, la 21 March 2016 - 10:32 PM, a spus:
iote colea"...Link
#7611 Useril este offline   mihaiagu
  • Postari: 1357
  • Inregistrat: 07-December 09
Postat 22 March 2016 - 03:58 PM
VEZI AICI http://aerobertics.b...E&search=Search
AERO
SBACH 2.2m - PilotRC/DLE55RA - functional
Sbach 2.2m - PilotRC,Kit - neechipat +DLE55RA - in lucru
EDGE 1.85m - Pilot RC + DLE30, +servouri SAVOX 1272SG - noi in cutie, urmeaza echipare, cand, nu stiu...
RX / TX
HITEC AURORA 9
HITEC AURORA 9X
#7612 Useril este offline   tantar
  • Postari: 2745
Postat 26 March 2016 - 08:20 PM
Mâine?
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7613 Useril este offline   tantar
  • Postari: 2745
Postat 27 March 2016 - 08:25 AM
Vezi postareatantar, la 26 March 2016 - 08:20 PM, a spus:
Mâine?
Azi ?
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7614 Useril este offline   Glider 1
  • Postari: 150
  • Inregistrat: 09-November 15
  • Interests:aero/automodele
Mâine?
am fost ieri si este cam moale asfaltul
sunt inca baltoace , iar unde este uscat sunt musuroaie de cartite
Radio: Taranis X9D Plus
Aero: CX5 & Stark DLG / NineEagles Sky Climber / Voltigeur MK II 3d aerobatic plane 1220mm / S800 Sky Shadow FPV Flying Wing
Auto: LOSI8ight Gas Engine
#7615 Useril este offline   lipitorul
  • Postari: 381
  • Inregistrat: 29-December 07
  • Interests:Playing cards
Postat 27 March 2016 - 09:11 AM
Vezi postareatantar, la 27 March 2016 - 08:25 AM, a spus:
Azi ?
La ANL-uri?
#7616 Useril este offline   tantar
  • Postari: 2745
Postat 27 March 2016 - 09:32 AM
Nu , încerc la VA mai târziu
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7617 Useril este offline   tantar
  • Postari: 2745
Postat 27 March 2016 - 11:09 AM
Eu acu' plec.
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7618 Useril este offline   jymmy05
  • Postari: 1171
  • Inregistrat: 14-June 10
Postat 27 March 2016 - 03:47 PM
Ainshtain din ce este compus sistemul de fum?
Un rezervor o pompa electrica cu un esc care pompeaza lichidul in toba? Asta este tot?
#7619 Useril este offline   incepatoru
  • Postari: 2863
  • Interests:aero
Postat 27 March 2016 - 06:32 PM
Vezi postareajymmy05, la 27 March 2016 - 03:47 PM, a spus:
...cam asta ar fi ...dar injectorul care intra in toba ale-a e misteru" acolo e arta daca ai lichid di" firma merge si-o tevusca infipta daca mergi pe" home made smoke oil"..trebuie gadilata problema..
#7620 Useril este offline   Ainshtain
  • Postari: 537
Postat 27 March 2016 - 06:37 PM
Da, asa e, tocmai am facut disectie la un atomizor si am sa incerc sa il reproduc... Daca iese treaba sunt tare, partea proasta e ca va trebui o gaurica ceva mai mare in toba... Gen fi 5.5 sau poate si mai mare.... Gasesc eu o solutie pana la urma......
Aceasta postare a fost editata de Ainshtain: 27 March 2016 - 06:41 PM
Stamatin Radu
  • 283 Pagini +
  • 252
  • 253
  • 254
  • 255
  • 256
49 useri citesc topicul
0 membri, 49 vizitatori, 0 utilizatori anonimi
