Modelism - RHC Forum: Noi tipuri de baterii la Graupner - Modelism - RHC Forum
#1 Useril este offline   renatoa
Postat 25 September 2008 - 02:23 PM
In buletinul informativ de azi prin email Graupner anunta un nou sortiment de baterii disponibile, si anume nanophosphate, la noi cunoscute mai mult ca LiFe sau A123.
http://www.graupner.de/fileadmin/newsweb/N...creen__gb__.pdf
Discharge: 30C continuous current and 60C peak current possible.
Discharge up to 2V per cell possible.
Durability:
The cells are protected by the metal case.
Up to 1000 cycles are possible thanks to the nanotechnology.
(NiMH 50-300 cycles at comparable load)
Fast charge by use of LiFe charging mode:
Fast charge up to 100% full load in 15 min possible
(only with ULTRAMAT 17, ULTRA DUO PLUS 50, also suitable for ULTRAMAT 16)
Charge:
Charging procedure continuous current/ continuous voltage
(CC/CV) Max. charge voltage 3.6 V/cell LiFe charge mode
Security:
The special Lilo-Nanophosphate ® technology is surcharge-proof up to 4,2 V and prevents dangerous thermal runaway typical for LiPo
Balancer connector:
All battery packs with Graupner balancer connector
Gama merge de la o celula singura 3.3V 1100mAh AA size 40gr 12Eur pana la 4cell 2s2p 6.6V 4600mAh 80A 332gr 86Eur
