  • 57 Pagini +
  • 54
  • 55
  • 56
  • 57
#1651 Useril este offline   nid1975
  • Postari: 403
  • Inregistrat: 13-August 11
  • Interests:navomodelism,pescuit
Postat 15 October 2018 - 08:39 PM
Vezi postareatelu2017, la 13 October 2018 - 09:03 PM, a spus:
echer 35 grade
Cred cacw bine tesitura mai in lung...vad acolo cam 25 de grade..pare a fi ok
echer 20 grade
Tel 0728777780
#1652 Useril este offline   telu2017
  • Postari: 37
  • Inregistrat: 26-December 17
Postat 18 October 2018 - 06:57 PM
Evazare cirma
  • Fisier atasat  4.jpg (371.69K)
#1653 Useril este offline   telu2017
  • Postari: 37
Postat 18 October 2018 - 06:59 PM
evazare cirma
  • Fisier atasat  5.jpg (450.99K)
#1654 Useril este offline   telu2017
  • Postari: 37
Postat 18 October 2018 - 07:00 PM
evazare cirma
  • Fisier atasat  6.jpg (449.75K)
#1655 Useril este offline   telu2017
  • Postari: 37
Postat 18 October 2018 - 07:02 PM
evazare cirma
evazare cirma
  • Fisier atasat  2.jpg (296.41K)
  • Fisier atasat  3.jpg (324.34K)
#1656 Useril este offline   manolo
  • Postari: 3555
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 18 October 2018 - 07:23 PM
Asa da ,este ok.
Barcute intinse!
Tel. 0744915775
#1657 Useril este offline   telu2017
  • Postari: 37
Postat 19 October 2018 - 02:28 PM
multumesc
#1658 Useril este offline   SCNeagu
  • Postari: 6
  • Inregistrat: 01-February 19
Postat 06 February 2019 - 06:23 AM
Buna ziua si salutare tuturor,
Sunt posesor de xbox, dar acest mod de petrecere al timpului liber nu mai pare atractiv.
Am citit in special acest topic al forumului, pentru ca este foarte detaliat si au fost foarte multi care au executat planurile. Inainte de ma apuca de lucru insa, am nevoie de piese, pentru ca imi voi da seama exact cum functioneaza una, alta, cand le voi avea in mana.
Lista:
- ESC brushed de 320A, ventilat, BEC integrat de 5V, 2A;
- 2 motoare 755/40;
- HK6S;
- doua carme de 52;
- 3 servo futaba 3003 (doua cuve+directie);
- Far 3W;
- Set 6 LED;
- Voltmetru digital;
- 2 x ax cuve;
- 2 x tub pupa 260mm;
- doua elici stanga/dreapta 40mm, 3 pale;
- baterie Pb-acid 12V, 9A;
- Incarcator.
Vreau sa folosesc servourile + LED + Far pe receiver direct. Nu gasesc niciunde curentul luat de un servo la actionare in moment relativ maxim.
Barca va fi actionata de cele doua motoare, in dreptul elicelor voi avea cele doua carme actionate de acelasi servo.
Proiectul va fi adaptat prin latirea cocii, astfel incat cele doua tuburi pupa sa incapa unul langa altul
Avand in vedere ESC-ul de 320A si ventilat, consider ca nu trebuie racit suplimentar. Motoarele, fiind doua si cu elice mica, credeti ca se vor incalzi fara racire cu apa?
Sunt incepator.
Background:
- bunic tamplar, langa care am stat destul de mult si faceam jucarii impreuna
- 3 vacante lucrate in santier cu echipa de dulgheri
- inginer mecanic de profesie acum
- inlocuire parchet in casa, mobila facuta de mine, instalatie electrica sub indrumarea unui inginer electric, schimbat gresie si faianta, etc.
Va rog sa imi spuneti ce va suna urat ceva din lista de piese, pentru ca doresc sa incep achizitia si apoi proiectul de coca.
Va multumesc!
Aceasta postare a fost editata de SCNeagu: 06 February 2019 - 06:25 AM
#1659 Useril este offline   navigator
Postat 06 February 2019 - 08:19 AM
Doar servourile pentru cuve trebuiesc schimbate cu altele mai puternice, in rest lista e buna. Iar cu acel CV prezentat nu cred ca iti va fi dificil sa realizezi barca si sa treci peste eventualele probleme care or sa se iveasca.
Asa ca bine ai venit si spor la lucru!
#1660 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 06 February 2019 - 08:27 AM
De ce doua motoare?! vei avea probleme majore ,HK6S nu se mai fabrica ,consum servo de cuve in functie de model 1,5-3A ,exclus Futaba 3003 ,daca gasesti original made in Taiwan merge pe cirma ,daca nu altveva.
Adica cum leduri+lanterna direct pe receptor?
Aceasta postare a fost editata de manolo: 06 February 2019 - 08:28 AM
Barcute intinse!
Tel. 0744915775
#1661 Useril este offline   Adistul
  • Postari: 1490
Postat 06 February 2019 - 08:41 AM
Daca vrei cu 2 motoare poti incerca alt model.
Deasemenea iti trebuie 2 ESC, renunti la carme si faci guvernarea barcii din telecomanda.
Pe o telecomanda FlySky FS-6IX poti face mix intre 2 canale si e ok.
Servo-urile Futaba 3003 se pot pune in varianta cuvarii cu arc fara revenire, altfel nu rezista multa vreme.
Pentru carma ok Futaba 3003
Aceasta postare a fost editata de Adistul: 06 February 2019 - 08:43 AM
La fel e si cand esti prost.
tel: 0771 088 207
adistul@yahoo.com
#1662 Useril este offline   SCNeagu
  • Postari: 6
Postat 06 February 2019 - 06:49 PM
Considerentele pentru care vreau sa pun doua motoare:
- mi-e frica sa nu rămân cu bărcuța in mijlocul apei. De asta doua motoare pe un canal, cu doua carme in dreptul fiecăruia.
- am găsit esc-ul brushed de 320a super ieftin și ventilat. Nu cred că va fi o problema sa leg motoarele pe un y din el fără să se încingă. Apropo de asta... Pot folosi caramele, ciocolată, rigleta la ramificații?
- punând două motoare pe bărcuță, sper eu sa scadă încărcarea pe ele, astfel curentul, temperatura. Altfel, ipoteza asta poate fi bazată pe un fals raționament, viteza de deplasare e de așteptat să crească și motoarele sa rămână încărcate la un 80% din încărcarea unuia care împinge de unul singur o bărcuță.
Referitor la servouri, din păcate nu știu dacă pot alege, din cunoștințele de până acum, unul original. Dacă aveți un site pe care îl puteți recomanda că având produse originale și din Ro, va rog să îmi spuneți. Totodată va rog să îmi spuneți de la cate kgf in sus să mă uit pentru cuve.
Am întrebat de curent pentru că am văzut pe YouTube filmulețe servo ținute cu mana la comandă și nu săreau de 1.5a.
Ledurile despre care spuneam sunt doar de impresie, sa fie frumoase. Vreau sa le alimentez din receiver, de pe unul din canale. La fel și farul de 3w.
Toate astea către întrebarea finală daca pot evita achiziția unui bec separat de cel al esc-ului. Gândindu-ma că servo trage curent în scurt de pe receiver, nu știu dacă îl va arde. E cam greu sa am comenzi simultane de servo.
Telecomanda nu știu dacă e de rău că nu se mai fabrică, dar poate reprezenta o altă săptămâna ocupată în viitor, căutând piese pentru ea. (De curând mi s-a ars trafu la sistemul audio și soția era surprinsă că mă bucuram.... Acum aștept să vina trafu nou să lipesc, înșurubez, deșurubez. In sistem am schimbat condensatori, tranzistori, etc)
Mulțumesc pentru răspunsuri tuturor.
#1663 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 06 February 2019 - 09:49 PM
Nu prea am auzit sa ramii pe girla din cauza motorului ,daca vrei sa vezi barca cu 2 motoare care merge ca ochiul mortului vezi un Carponizer ,e greu sa scoti o forma hidrodinamica pentru 2 motoare.
Barcute intinse!
Tel. 0744915775
#1664 Useril este offline   Adistul
  • Postari: 1490
Postat 07 February 2019 - 11:41 AM
Vezi postareaSCNeagu, la 06 February 2019 - 06:49 PM, a spus:
Nu am inteles exact ce doresti... daca vrei ajutor... fii mai explicit.
tel: 0771 088 207
adistul@yahoo.com
#1665 Useril este offline   DigitAll
  • Postari: 769
  • Inregistrat: 23-January 09
Postat 07 February 2019 - 05:50 PM
Regulatorul ala de 320A are defapt ~ 20 A . Daca intra fir la elice si se blocheaza axul, in cateva secunde ai sanse sa il vezi ars.
Daca alimentezi 2 motoare pe iesirea regulatorului, unul va trebui alimentat invers fata de celalalt . Motorul care este alimentat invers va avea o turatie mai mica . Mersul in linie dreapta se poate face DOAR daca reduci viteza de pe motorul mai turat ( in aceasta configuratie nu ai cum ) sau prin carma ( nu imi dau seama cum se va comporta pe apa ) .
Ti-as recomanda sa folosesti 1 motor + 1 carma , iar daca coca nu permite, atunci pune 2 motoare dar fara carma/carme, dar foloseste regulator de turatie dublu cu functia de programare la mers in linie dreapta. Daca folosesti 2 regulatoare separat si mixer din telecomanda sau mixer uzual extern, vei avea aceeasi problema : barca nu se va deplasa drept !
Tel : 0768080180
#1666 Useril este offline   metrix4you
  • Postari: 306
  • Inregistrat: 04-May 10
  • Interests:calculatoare , electronica si mai nou navomodelism
Postat 04 January 2020 - 01:26 PM
salut ,
din 2013 am cam lipsit pe aici asa ca m-am intors cu o mica jucarie.
am modificat putin coca , am mai inserat inca o laterala , asa ca coca a iesit putin mai rotunjoara
Toate filmuletele mele despre barcute:
http://www.youtube.c...ou?feature=mhee
#1667 Useril este offline   metrix4you
  • Postari: 306
Postat 04 January 2020 - 01:27 PM
test pe apa. pestii nu au fost chiar fericiti ca le-am stricat linistea :)
#1668 Useril este offline   metrix4you
  • Postari: 306
Postat 17 January 2020 - 03:25 PM
am mai prograsat putin ...
#1669 Useril este offline   metrix4you
  • Postari: 306
Postat 21 January 2020 - 02:26 PM
gata si vopseaua. sper sa gasesesc un marker rosu sa ii trasez si linia de plutire
#1670 Useril este offline   Adistul
  • Postari: 1490
Postat 03 February 2020 - 09:14 PM
Salut.
Nu se prea vede daca ai facut degajarea in spate pentru carma: planurile initiale nu au aceasta modificare.
Am vazut ulterior: se mai plangea lumea ca face carmirea in lung.
Oricum... frumos si ingrijit lucrata! Spor!
Aceasta postare a fost editata de Adistul: 03 February 2020 - 09:16 PM
tel: 0771 088 207
adistul@yahoo.com
#1671 Useril este offline   gorg
  • Postari: 39
  • Inregistrat: 14-April 11
  • Interests:auto-navo
Postat 22 March 2020 - 08:56 PM
Salutare!
Cu vreo 5 ani in urma am construit si eu acest navomodel dupa niste planuri pe care le am primit de la un membru de aici.
Acum, din cauza carantinei care se institue p aici(uk) as vrea sa ma apuc din nou de el.
Pe unde se mai gasesc planurile?
Poate sa mi le trimita si mie cineva, va rog sau sa mi spuna unde le gasesc?
mariusparaschivg@gmail.com
Multumesc!
#1672 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 24 March 2020 - 10:02 AM
La pagina 33 gasesti ce doresti.
Barcute intinse!
Tel. 0744915775
#1673 Useril este offline   Ady xl
  • Postari: 5
  • Inregistrat: 05-May 15
Postat 09 April 2020 - 07:56 AM
Buna.As vrea si eu planurile pentru barcuta .Va multumesc
#1674 Useril este offline   Ady xl
  • Postari: 5
Postat 09 April 2020 - 08:10 AM
Nu le gasesc ca sa le pot imprima la imprimanta trimitetimile pe mail la bercseni_82@yahoo.com.Multumesc
#1675 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 09 April 2020 - 09:05 AM
Am trimis.
Barcute intinse!
Tel. 0744915775
#1676 Useril este offline   manolo
  • Postari: 3555
  • Interests:Navo
Postat 09 April 2020 - 11:15 AM
Vezi postareamanolo, la 09 April 2020 - 09:05 AM, a spus:
Am trimis.
Ups! am primit un mesaj ca adresa de mail nu a fost gasita.
Barcute intinse!
Tel. 0744915775
#1677 Useril este offline   Ady xl
  • Postari: 5
Postat 09 April 2020 - 11:58 AM
A scuze adresa este berceni_82@yahoo.com.Mersi
#1678 Useril este offline   Ady xl
  • Postari: 5
Postat 09 April 2020 - 12:04 PM
Am scris eu gresit.Multumesc
#1679 Useril este offline   Ady xl
  • Postari: 5
Postat 09 April 2020 - 01:05 PM
Am primit multumesc mult.Ma pun pe treaba:)))
#1680 Useril este offline   blitz
  • Postari: 29
  • Inregistrat: 19-March 09
Postat 15 September 2020 - 04:57 PM
Va salut cu respect. Am cam lipsit un pic de pe aici ....Acum mai bine de 10 poate chiar 12 ani mi-am construit si eu aceasta barcuta pe cere am folosit-o cu placere un an sau doi in Romania . Cam de 10 ani am plecat din tara si pe aici prin strainatatea asta este destul de greu sa folosesti barcuta de plantat, asa ca barcuta mea nu a mai fost folosita de 10 ani. As dorii sa stiu daca intre timp a facut cineva dintre voi modificari semnificative la ea si ma refer la schimabarea bateriei cu LiPo ,motor neperiat etc etc . Daca da m-as buacura nespus sa i-mi recomandati ce ati schimbat si cu ce ! Deoarece in acesti multi ani tehnologia a explodat pur si simplu posibilitatile din ziua de azi sunt aptroape nelimitate ! Dar dupa cum spuneam m-as bucura daca cineva a facut ceva schimbari si a testat in acelasi timp componenetele ....
Va multumesc anticipat!
Eugen Vilt
Ps primesc cu placere raspunsuri si pe e-mail eugenvilt@gmail.com
ms ms
  • 57 Pagini +
  • 54
  • 55
  • 56
  • 57
12 useri citesc topicul
