#1081
Postat 15 October 2009 - 09:28 PM
Tel. 0744915775
#1082
Postat 17 October 2009 - 02:36 PM
Quad S500 cu Naza V2
EasyGlider Pro
#1083
Postat 17 October 2009 - 04:56 PM
p_cipri, la Oct 17 2009, 03:36 PM, a spus:
Chiar si la modelul lui Vasia se poate imagina un fel de miner ingropat care zic nu ar strica aspectul ,poate e mai greu cu ramforsarile dar cred ca se poate rezolva .
Tel. 0744915775
#1084
Postat 17 October 2009 - 05:11 PM
#1085
Postat 17 October 2009 - 10:55 PM
#1086
Postat 18 October 2009 - 01:54 PM
#1087
Postat 20 October 2009 - 08:45 PM
#1089
Postat 21 October 2009 - 07:16 AM
#1090
Postat 21 October 2009 - 08:42 AM
Tel. 0744915775
#1091
Postat 21 October 2009 - 08:29 PM
#1092
Postat 21 October 2009 - 09:12 PM
Tel. 0744915775
#1093
Postat 21 October 2009 - 10:09 PM
Pthesla, la Oct 20 2009, 09:45 PM, a spus:
eu am folosit tije de 8 din otel cromat cu rulmenti pe capete, iar ca servo am folosit futaba s3003 si vreau sa zic ca merg super bine am fost tot anul cu barca la pescuit, daca este sa ti se strice ceva la servo ti se strica angrenajul de plastic care se schimba, un angrenaj costa 7,5 lei
#1094
Postat 22 October 2009 - 09:45 AM
eu am folosit tije din aluminiu de 8 mm diametru, goale pe interior, cu rulmenti in capat luate din Hornbach Berceni.
sunt mult mai usoare.
#1096
Postat 22 October 2009 - 01:31 PM
#1097
Postat 22 October 2009 - 02:02 PM
#1098
Postat 22 October 2009 - 02:17 PM
#1099
Postat 22 October 2009 - 03:06 PM
Pthesla, la Oct 22 2009, 03:02 PM, a spus:
Ar fi tubuletul la toata cutia, dar normal trebuie sa prepari cam o lingurita de chit la care pui cam o gamalie de chibrit de intaritor,mesteci foarte bine si aplici ,cit mai subtire posibil ,timp de lucru cam 3-5 minute ,intarire cam 30-60min ,dar ca sa smirgheluiesti cu apa zic eu trebuie lasat cam 6-12h.
Tel. 0744915775
#1100
Postat 25 October 2009 - 08:50 PM
#1102
Postat 26 October 2009 - 04:11 PM
amador, la Oct 11 2009, 01:04 PM, a spus:
O elice mai "eficienta" decat cea de 50mm in 3 pale de la moldova poate sugera cineva (55 diametrul e maxim care intra) ? As vrea sa cresc un pic viteza ... :rolleyes:
Aceasta postare a fost editata de georgedr72: 26 October 2009 - 04:12 PM
#1103
Postat 26 October 2009 - 04:58 PM
allen_g30, la Aug 10 2008, 03:30 PM, a spus:
pt ca shark hunter 2 merge f bine, m-am gandit sa mai fac o barca, de data aceasta dupa ce am citit si vazut pe la voi mai multe barcute. deci (ca sa incep cu concluzia) am luat de la fiecare cate o idee... le-am pus cap la cap si a iesit asta:
cote: L=70 cm / l=330 cm / h= 160 cm (h este brut, fara inaltimea cabinei si a cuvelor.)
Accumulator Pb-Acid capsulat 12V / 5A - 1 buc
Motor Electric POWER 755/ 40 - 1 buc
Regulator Rookie Navy - 12V/ 35A - 1 buc
Servo Futaba S3003 Standard - 3 buc
Carma 50 x 36 mm - 1 buc
Cuplaj Super Navy Kardan - 1 buc
Elice Dynamic 3 pale 40 mm stanga - 1 buc
Tub de presiune pentru sisteme de racire + Spira de racire - 1 buc
material: komatex de 2 / 3 / 5 mm
pareri? sfaturi?
le astept de la voi, asa cum ati facut pana acum, si fara de care nu m-as fi descurcat. :rolleyes:
salutare si scuzati-ma daca va deranjez sunt nou pe aici si
vreau si io sa ma apuc de construit acestui navomodel dar nu stiu cu ce sa incep
si daca e cineva dornic sa imi dea niste planuri pe adresa mea gaby_hekaru@yahoo.com
multumesc
#1104
Postat 26 October 2009 - 05:00 PM
barondml, la Oct 26 2009, 04:58 PM, a spus:
multumesc
Uita-te prin primele pagini si vezi ca le-a pus Allen!Stima
#1106
Postat 27 October 2009 - 08:18 AM
#1107
Postat 27 October 2009 - 08:22 AM
#1108
Postat 27 October 2009 - 08:24 AM
#1109
Postat 27 October 2009 - 08:26 AM
Tel. 0744915775
#1110
Postat 27 October 2009 - 08:31 AM
