Multiplex AcroMaster kit, build, flight log
#61
Postat 20 October 2008 - 09:12 PM
La Acromasterul meu am rupt 2 buc de TinyS pana acum. Se rup si la viraje la sol daca se agata in iarba. Acum am pus HS 82 MG. Sper sa nu mai fie necazuri.
#63
Postat 22 October 2008 - 10:10 AM
Modelele in cauza sunt: Graupner Extra 300S - anvergura 1090mm si Robbe Red Hawk - 1100mm.
#64
Postat 22 October 2008 - 02:07 PM
#65
Postat 06 November 2008 - 12:33 PM
#66
Postat 09 November 2008 - 11:20 AM
Motorizare Torque + ESC Airbos
Elice 12x6
2x HS-65HB, 2x MPX Polo digi4 (cam vechi si uzate)
Flightpower 2170 3s
Vopsea din spray in loc de autocolante
999g!
Dixtractie...
http://www.youtube.c...h?v=OOhPj8iSuWY
RTF
Aceasta postare a fost editata de Red Sky: 09 November 2008 - 11:22 AM
#67
Postat 09 November 2008 - 11:36 AM
I-am facut pe plac :)
Aceasta postare a fost editata de Red Sky: 09 November 2008 - 11:36 AM
#70
Postat 09 November 2008 - 07:58 PM
http://www.mpx.speedkom.net/hp/produkte/images/033264002.jpg
#71
Postat 10 November 2008 - 11:26 AM
Aceasta postare a fost editata de mihaimcg: 10 November 2008 - 11:27 AM
#72
Postat 10 November 2008 - 11:35 AM
#73
Postat 22 January 2009 - 07:56 PM
echipare :
Motor Multiplex Himax C 3516-1130
Regulator Multiplex MULTIcont BL-70 S-BEC
Acumulator Multiplex Li-BATT BX 3 celule 2500mAh 18C
Elice Multiplex APC elektro 11x5.5
Servouri 4x AS-170(mai slabute ca nu vreau sa molestez modelul:) )
Astept pana maine sa imi vina incarcatorul (am luat un Power Peak Ultimate 2) si radiocomanda (Futaba T-6EXP in 2.4) si apoi ii dau drumul la constructie.
#76
Postat 24 January 2009 - 12:46 AM
Cred ca urmeaza cele de la directie si profundor si bechia. In plus pe eleroane am HS-55 si cred ca a venit vremea sa le inlocuiesc cu HS-65 MG ca tot le am pe stoc.
Traiasca Acromaster si cine l-a inventat!
#77
Postat 24 January 2009 - 10:14 AM
#78
Postat 24 January 2009 - 01:37 PM
Motorul si regulatorul vin in bot (regulatorul de-asupra bateriei, lipit pe "tavanul" botului pe interior)
Receptorul in fata gaurii prin care vin firele de la eleroane.
Bateria cat mai adanc in bot.
#79
Postat 24 January 2009 - 09:43 PM
#82
Postat 24 January 2009 - 10:57 PM
E o practica buna totusi dublarea amperajului escului fata de consumul real. Am avut un motor putin mai mare ca ala cu un esc jeti opto de 70A ce a puscat intr-un final. Motorul consuma doar 60A max si era un AXI nu stiu cat gold.
Aceasta postare a fost editata de Kriminel: 24 January 2009 - 10:59 PM
#83
Postat 24 January 2009 - 11:11 PM
#84
Postat 25 January 2009 - 12:11 AM
Romulus, la Jan 24 2009, 09:43 PM, a spus:
APC Electro 11x5,5
Se pare ca mananca cam mult. Schimba elicea cu un 12x6 (si eventual un motor mai bun) si n-o sa consume mai mult de 28A la 3S. O sa ai si o tractiune mai buna.
Eu folosesc un ESC de 35A fara probleme.
La ce greutate l-ai scos? Al meu are ~1Kg.
#85
Postat 25 January 2009 - 12:40 AM
Tot asa are si al meu. Putin peste 1Kg cu tot cu lipo.
#87
Postat 25 January 2009 - 09:08 AM
Aceasta postare a fost editata de Kriminel: 25 January 2009 - 09:09 AM
#88
Postat 26 January 2009 - 04:32 PM
