Modelism - RHC Forum: Elicopter Blade 130 X BNF FLYBARLESS - Modelism - RHC Forum
#1 Useril este offline   Zorba
  • Postari: 338
  • Inregistrat: 14-July 19
Postat 13 June 2024 - 01:30 PM
Blade® 130 X BNF este un elicopter radiocomandat flybarless de clasa sub-micro 3D ce poate executa cu usurinta manevre acrobatice (piro flips, tic tocs, hurricanes, funnels si multe altele) cu energia si precizia unui elicopter de cateva ori mai mari. La baza acestor performante incredibile se afla sistemul flybarless de stabilizare electronica AS3X® (Artificial Stabilization – 3aXis). Acest sistem utilizeaza senzori MEMS pe 3 axe si software specializat pentru controlul zborului ce ofera reactiile si stabilitatea cu care v-ati obisnuit la elicopterele mult mai mari. Aceste caracteristici, impreuna cu motorul brushless extrem de puternic si coada actionata cu ax, va permit sa va depasiti limitele, atat in interior cat si in aer liber, oferindu-va totodata control absolut asupra elicopterului.
Key Features
AS3X Flybarless System
Powerful 6730Kv brushless inrunner motor
Shaft-driven, variable-pitch tail rotor
Symmetrical 135mm main rotor blades
Spektrumâ„¢ 2.9 gram linear long-throw cyclic servos
Spektrum 2.9 gram linear performance tail servo
Strong, lightweight airframe
Carbon fiber main shaft and tail boom
Sleek body with sharp 130 X graphics
Includes E-flite® 2S 7.4V450mAh 130C Li-Po battery nano-tech ,5buc.
Includes Celectraâ„¢ 2S 7.4V DC Li-Po Charger with AC adapter
Requires a 6+ channel computer DSM2®/DSMX® transmitter, sold separately
Product Specifications
Type:
Electric flybarless collective-pitch helicopter
Main Rotor Diameter:
325mm
Tail Rotor Diameter:
76mm
Gross Weight:
107 g
Length:
305mm
Kit/ARF/RTF:
BNF
Rotor Blade Length:
135mm
Cu imbunatatiri constructive din dural si piese de rezerva profi.
Pret:550 Lei
Tel:0787828507
#2 Useril este offline   Zorba
  • Postari: 338
Postat 15 June 2024 - 02:04 PM
Pret fix: 450 Lei
Livrare prin OLX { 20 lei }
#3 Useril este offline   Zorba
  • Postari: 338
Postat 18 June 2024 - 11:01 AM
Vezi postareaZorba, la 15 June 2024 - 02:04 PM, a spus:
Pret fix: 450 Lei
Ultima reducere : 400 Lei
#4 Useril este offline   Zorba
  • Postari: 338
Postat 27 June 2024 - 02:47 PM
Mai facem o ultima reducere : 350 lei
  • Postari: 8300
Postat 27 June 2024 - 04:15 PM
Ma tot uit la poze - modelul asta era cu rotor de coada antrenat de motorul principal, cu pas variabil. Modelul tau vad ca e cu motor in coada.
Asa e venit din fabrica sau e custom made ? Daca e custom inseamna ca are si alta electronica pentru motorul din coada. Un model foarte reusit.
#6 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1418
  • Inregistrat: 07-July 11
  • Interests:hely
Postat 27 June 2024 - 06:04 PM
Vezi postareastiganas, la 27 June 2024 - 04:15 PM, a spus:
Stefane ,ce tot zici acolo !!
#7 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1418
  • Interests:hely
Postat 27 June 2024 - 06:11 PM
[quote name='stiganas' timestamp='1719497710' post='939351']
Stefane ,ce motor in coada !!
  • Postari: 8300
Postat 27 June 2024 - 06:44 PM
Ooops, m-au pacalit pozele,
nu are motor in coada. Cred ca are ceva upgradeuri care fac sa arate puitn altfel.
[quote name='mihado_logo' timestamp='1719504712' post='939353']
Aceasta postare a fost editata de stiganas: 27 June 2024 - 06:44 PM
#9 Useril este offline   mihado_logo
  • mihado_logo
  • Postari: 1418
  • Interests:hely
Postat 27 June 2024 - 07:54 PM
Intradevar are case-ul din metal ,original venea pe plastic .
Iar inelul care fixeaza axul de coada si care este in exterior,da impresia unui motoras !
Aceasta postare a fost editata de mihado_logo: 27 June 2024 - 07:55 PM
#10 Useril este offline   Zorba
  • Postari: 338
Postat 28 June 2024 - 09:31 AM
 mihado_logo, la 27 June 2024 - 07:54 PM, a spus:
Poate ajuta....Am si pinioane metalice noi...
Aceasta postare a fost editata de Zorba: 28 June 2024 - 09:32 AM
  • Postari: 8300
Postat 28 June 2024 - 08:28 PM
E un model fenomenal - daca nu aveam doua il cumparam.
#12 Useril este offline   Zorba
  • Postari: 338
Postat 02 July 2024 - 11:05 AM
Se reduce la: 300 lei,valabil o saptamana.
Dupa se pune la pastrare in colectia personala....
#13 Useril este offline   Zorba
  • Postari: 338
Postat 15 July 2024 - 02:51 PM
Pacat sa stea.....Aproape moca...Acumulatorii fac mai mult....
Pret de vara: 200 lei
Aceasta postare a fost editata de Zorba: 15 July 2024 - 02:52 PM
#14 Useril este offline   Zorba
  • Postari: 338
Postat 16 July 2024 - 01:03 AM
A decolat...
