Se vinde cauza inutilizare - prea sofisticata :clapping:
Vine cu doua receptoare unul FUTABA iar celelalt compatibil FASST sincronizat cu stabilizator intern de zbor .
Are bateria ei reincarcabila si charger.ul aferent .
Se ofera si valiza de aluminiu in acelasi pret .
Caracteristicile sunt multiple . va atasez cateva .
FASSTest® 2.4GHz Technology
Superior interference immunity by combining the advantages of DSSS and FHSS modulation
Future-proof (already complies with the new EU standard)
Integrated 32-channel telemetry system
Up to 1000m telemetry range
Real-time telemetry display in large display
Voice output via optional headphones with 3.5 mm jack plug
Melody and sound output (optionally via internal beeper or optional headphones)
Vibrate
Data recording of control signals and telemetry data in preparation
74 x 38.5 mm backlit display (128 x 64 dot)
S-BUS technology for fully digital integration of S.BUS servos, S.BUS controllers and S.BUS sensors
Fully equipped 14-channel transmitter with 20 (22) freely programmable controls
Precise control sticks with open-stick action and 12 bit resolution, backlash-free, 2-way ball bearings
Dimensions: 205 x 220 x 55 mm
Transmitting power: 100 mW
Transmission system: FASSTest® 14 channels
Weight approx.: 890 g
Additional specifications: Compatible with all S-FHSS, FASST / RASST and FASSTest® flight receivers.
Functions: 14/32
Power supply: LiPo 2S 3400mAh / 7.4 Volt
More Product Details:Transmission:
14 channels
The FASSTest® technology (Futaba Advanced Spread Spectrum Technology). Special hybrid technology combines the advantages of DSSS and FHSS modulation. Extreme channel spread (spread factor 11) through DSSS spreading combined with optimized FHSS frequency hopping result in superior interference immunity and ultra-fast response times for a precise, direct control feel.
100 mW transmit power
Real-Time Response – Real-time control. The response time (from the press of the control stick to the servo response) of the FASSTest® / FASST system is significantly faster than other 2.4 GHz systems.
Very long range >3000m
Ultra-fast, direct, end-to-end digital modulation for the shortest response times
Switchable FASSTest® high-speed mode for ultra-fast control of digital servos with 6.3 ms (12-channel, reduced telemetry functions)
Easy Link - extremely simple, fast binding process between sender and receiver
Extremely fast and safe automatic re-binding even under difficult conditions
Intelligent servo timing for smooth servo drive and prevention of servo propagation time differences
Dual Antenna Diversity – lightning-fast switching between two receiving antennas for optimal receive signal quality (depending on the receiver)
Pre-Vision – FASST / FASSTest® receivers permanently scan the input signal and apply intelligent Futaba error correction.
No loss of reaction speed, even when the frequency band is heavily occupied
Built-in range test function to check range before launch
Modulation type switchable to FASST or FHSS for backward compatibility with existing Futaba components
Telemetry:
Synchronized, two-way communication between transmitter and receiver with high telemetry data rate (up to 9 times per second)
32 telemetry channels
Real-time display of telemetry data on integrated display
Voice output control via freely assignable switches
Vibrate
Data recording of control signals (stick movements) and telemetry data on SD card in preparation
PC evaluation software for recorded telemetry and GPS data as well as control signals in preparation
Receiver signal strength indicator to monitor range
Distance warning system (with optional GPS sensor) for safe flights at the line of sight
Receiver undervoltage warning system to monitor the receiver battery
Freely configurable output of telemetry data via display, sound, voice and vibration
Pretul pe piata actual este peste 500 de euro .
Pret 1500 de lei
rel. suplimentare la telef.0744203712
