Modelism - RHC Forum: Telecomanda 6 canale nou Turnigy TGY i6 - Modelism - RHC Forum
#1 Useril este offline   Sergiumaxim
  • Postari: 17
  • Inregistrat: 10-March 19
Postat 26 April 2023 - 02:39 AM
Telecomanda NOUA, LA CUTIE, cu Telemetrie Turnigy i6 TGY-i6 + receptor cu 2 antene inclus.
Telecomanda Profi 6ch pentru navomodele, drone si aeromodele cu telemetrie, soft, memorii,display
Distanta de operare 500 m pe apa, 800m in aer
Specificatii:
• Entry level 6 channel 2.4gHz radio with telemetry capability
• Dual Rate/Trims/Gear/Flap/Gyro Gain Adjust/Flight Mode/Throttle Hold/Hover Pitch Switches
• Easy to use Programming & Navigation Buttons
• Supports Heli/Standard Wing/Elevon/V-Tail
• 20 Model Memory
• 8 Character Model Name
• Trainer and charging ports
• Backlit LCD Screen displays real time transmitter and receiver voltage
• 4 Stick Mode Selectable
• Optional telemetry receivers and sensors available separately
Basic Programming Functions:
Dual Rates
Sub Trim
Travel Adjust
Channel Reverse
Swash Mix
Gyro Sensitivity
Throttle Curve
Monitor
Pitch Curve
Throttle Hold
Model Name
Timer
Turnigy TGY-i6 Transmitter Specs:
Frequency: 2.4GHz ISM Frequency Range
Modulation: GFSK
Spread Spectrum Mode: AFHDS 2A and AFHDS
Band: 142
Number of Frequency Channels: 20
Output Power: =20dbm
https://www.olx.ro/d...i6-IDh8XQB.html
Preț 320 lei
  • Postari: 3555
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 26 April 2023 - 09:51 AM
Asa arata receptorul?
Fisier atasat  HTB1839ebynrK1Rjy1Xcq6yeDVXah.jpg (19.39K)
Barcute intinse!
#3 Useril este offline   Sergiumaxim
  • Postari: 17
Postat 26 April 2023 - 06:54 PM
Da
  • Postari: 3555
  • Interests:Navo
Postat 29 April 2023 - 09:09 AM
Ofer 200 ron fara receptor.
Barcute intinse!
3 useri citesc topicul
