Automodelul are 15-20 minute rulaj doar pe suprafete fara obstacole ,aproape nou(se poate vedea starea automodelului din poze.
Modificari facute(up-grade)
-s-a schimbat motorul original Carson 550 cu varianta Kyosho model 3605 Le Mans.
-amortizoarele golite si umplute cu ulei .
-mentenanta automodelului a fost facuta de un bun amic care este specializat in automodelism(adica a inspectat,uns,gresat ,inlocuit motor,tot ce trebuie)
Intrebari,poze in privat doar pe WhatsApp sau telefon.
Multumesc
Caracteristici principale:
All-wheel drive (4WD)
Fully ball bearing mounted
Aluminium motor mount
12 mm aluminum driver, hex
Heavy duty adjustable aluminum oil filled shocks (knurled nut)
High Grip Wheels Race-bonded
Stabilizer, front / rear
Fall h v / adjustable
Adjustable front track
central aluminum main shaft
Hexagon socket set screws
Length 410 mm
Width 235 mm
Height 155 mm
270 mm Wheelbase
Ground clearance 35 mm
12 mm hex hub
Weight about 1450 g
WhatsApp Image 2022-01-19 at 12.06.29.jpeg (311.88K)
Aceasta postare a fost editata de danny_39: 19 January 2022 - 02:00 PM
