Modelism - RHC Forum: Recomandare imprimanta 3D - Modelism - RHC Forum
  • 58 Pagini +
#91 Useril este offline   gyany_eugen
  • Postari: 977
  • Inregistrat: 17-December 10
  • Interests:Electronica, IT
    Aeromodelism
Postat 01 November 2017 - 06:49 AM
Vezi postareamihaighe, la 31 October 2017 - 10:37 PM, a spus:
Sper ca pruni :drinks:
Pruni 30 :good:, restul meri, peri, ciresi, diverse soiuri, certificate. E prima daca cand plantez, voi vedea cum va merge.
Turnigy 9x -Er9x
#92 Useril este offline   mihaighe
  • Postari: 460
  • Inregistrat: 29-January 10
Postat 01 November 2017 - 08:48 AM
Cinste celui ce planteaza un pom.
#93 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 01 November 2017 - 09:29 AM
Axa Y este putin incrusisata. Am discutat cu cineva din Franta care a cumparat aceeasi imprimanta si are aceeasi problema.
Turnigy 9x -Er9x
#94 Useril este offline   mihaighe
  • Postari: 460
Postat 01 November 2017 - 10:04 AM
Vezi postareagyany_eugen, la 01 November 2017 - 09:29 AM, a spus:
Cum ?,pune o poza sau explica poate gasim o solutie.
#95 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 01 November 2017 - 07:37 PM
Vezi postareamihaighe, la 01 November 2017 - 10:04 AM, a spus:
Am rezolvat. Una dintre tijele axei Y este mai lunga cu 2 mm. Acei 2 mm in plus trebuie lasati sa iasa afara fata de celalalt ax care vine exact la nivelul suportului.
Turnigy 9x -Er9x
#96 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 01 November 2017 - 07:39 PM
Intre timp am terminat si constructia.
  • Imagine atasata: 20171101_191636.jpg
  • Imagine atasata: 20171101_191530.jpg
Turnigy 9x -Er9x
#97 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 01 November 2017 - 07:40 PM
  • Imagine atasata: 20171101_191654.jpg
  • Imagine atasata: 20171101_191604.jpg
Turnigy 9x -Er9x
#98 Useril este offline   CNC_EVOLUTION
  • Postari: 300
  • Inregistrat: 20-March 17
Postat 01 November 2017 - 07:42 PM
Vezi postareagyany_eugen, la 01 November 2017 - 07:39 PM, a spus:
barele filetate par a fi metrice
de care si de cat sunt barele filetete si rulmentii liniari? :good:
#99 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 01 November 2017 - 07:48 PM
Vezi postareaCNC_EVOLUTION, la 01 November 2017 - 07:42 PM, a spus:
8 si 8
Turnigy 9x -Er9x
#100 Useril este offline   bbogdanmircea
  • Postari: 267
  • Inregistrat: 25-October 07
Postat 01 November 2017 - 09:57 PM
Arată bine ?
Așteptăm un filmuleț cu primul print :D
#101 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 01 November 2017 - 10:40 PM
Ehehe... mai e pana la printare.
Axele X si Y functioneaza bine. Problema e cu axa Z: cand dau comanda home axele X, Y ajung in stop end, Y se agata, motoarele se opresc si mornaie.
Maine verific paralelismul axelor Z, precum si perpendicularitatea axei X pe fiecare dintre axele Z. Pe alte forumuri problema e bine cunoscuta si toate imprimantele dupa prima montare au nevoie se aceste verificari si reglaje.
Ar mai trebui masurata tensiunea pe drivere si cautate imperfectiuni in filetul suruburilor.
Daca are cineva si alte solutii, sunt binevenite.
Turnigy 9x -Er9x
#102 Useril este offline   mihaighe
  • Postari: 460
Postat 01 November 2017 - 11:46 PM
Vezi postareagyany_eugen, la 01 November 2017 - 07:40 PM, a spus:
Banditi de chinezi,pe axa z au pus rulmenti scurti.
#103 Useril este offline   mihaighe
  • Postari: 460
Postat 01 November 2017 - 11:59 PM
Vezi postareagyany_eugen, la 01 November 2017 - 10:40 PM, a spus:
Ai nevoie de asa ceva :
https://www.thingive...m/thing:2604728
https://www.thingive...7359fa43f71537a
sau mai cauti ca sant multe variante ,maine pun o poza cu ale mele de pe imprimanta.
Aceasta postare a fost editata de mihaighe: 02 November 2017 - 12:00 AM
#104 Useril este offline   mihaighe
  • Postari: 460
Postat 02 November 2017 - 12:06 AM
Sau verifica setarea de curent la axa z ca acolo ai 2 motoare in paralel si ai nevoie de curent mai mare.
#105 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 02 November 2017 - 10:02 AM
Mda... se pare ca am gasit problema.
Paralelismul axelor Z: sus 359 mm, jos 357 mm, diferenta de 2 mm. Am masurat de 3 ori, credeam ca nu vad bine.
Am slabit suruburile motoarelor, rulmentului si piulitei si nu se mai blocheaza. Incerc sa gasesc o solutie mai tehnica si definitiva.
Turnigy 9x -Er9x
#106 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 02 November 2017 - 05:59 PM
Am reusit sa o fac sa nu se mai blocheze, doar spre final de cursa, spre home, axa Z (axa dreapta) tot mai agata putin cand coboara.
Toate suruburile, inclusiv cele ale frame-ului le-am slabit. Am dat comanda sus-jos de cateva ori, pana la capat de cursa, apoi am inceput sa strang pe rand fiecare surub in parte.
In urma celor de mai sus tijele axelor Y sunt paralele (masurate cu sublerul).
Apoi am urcat suruburile M8 mai sus in cuplajul elastic. La montajul initial am introdus surubul pana aproape de axul motorului, astfel cuplajul elastic nu mai avea niciun rol.
Nu in ultimul rand am reglat tensiunile la 1.0 volti pe toate axele.
Tensiunile masurate initial au fost:
X=0.83 V
Y=0.86 V
Z=0.76 V
E=0.80 V
Am fost la strungar si mi-a facut inca patru bucse, cele din foto. Apareau probleme la tensionarea curelei axei X, cu axele Z. Probabil flambau putin. Maine le voi monta stifturi filetate, azi nu am avut de 4 mm.
E suficient 1.0 V pentru axa Y?
  • Imagine atasata: 20171102_174133.jpg
  • Imagine atasata: 20171102_174121.jpg
  • Imagine atasata: 20171102_154537.jpg
Aceasta postare a fost editata de gyany_eugen: 02 November 2017 - 06:00 PM
Turnigy 9x -Er9x
#107 Useril este offline   dan_mitea
Postat 02 November 2017 - 06:23 PM
As pune un pic de ulei pe ghidaje si suruburi...zic si eu.
#108 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 02 November 2017 - 06:31 PM
Vezi postareadan_mitea, la 02 November 2017 - 06:23 PM, a spus:
Am facut-o deja dar am uitat sa specific :good:
Turnigy 9x -Er9x
#109 Useril este offline   djtaotao
  • Postari: 995
  • Inregistrat: 27-January 11
Postat 02 November 2017 - 06:57 PM
Vezi postareagyany_eugen, la 02 November 2017 - 05:59 PM, a spus:
Poti regla aceeasi limitare de curent pe toate axele. Cresti spre maximum doar daca axa pierde pasi la printare. La homing nu cred ca e cazul.
Vezi la polulu pe site formulele de calcul in functie de driver si curentul motorulului folosit.
#110 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 02 November 2017 - 09:46 PM
Vezi postareamihaighe, la 01 November 2017 - 11:59 PM, a spus:
OK. Am inteles cum functioneaza.
Turnigy 9x -Er9x
#111 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 03 November 2017 - 12:09 PM
Am rezolvat in totalitate. Nu mai agata nicaieri.
Alta problema este ca atunci cand axa Z urca in sus, pe la 100 mm fata de heat bed, extruderul se misca putin fata-spate (de-a lungul axei Y) facand acel efect de clatinare (wobble).
Nu e bine.
Turnigy 9x -Er9x
#112 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 03 November 2017 - 03:57 PM
Banda, glue stick sau fixativ?
Turnigy 9x -Er9x
#113 Useril este offline   djtaotao
  • Postari: 995
Postat 03 November 2017 - 04:35 PM
Le-am folosit pe toate. Cel mai multumit am fost de banda kapton si fixativ, in ordinea asta.
#114 Useril este offline   bbogdanmircea
  • Postari: 267
Postat 03 November 2017 - 05:28 PM
Dacă patul e încălzit, face aderență pe orice mai puțin pe metal gol . Dacă nu e, eu foloseam spray fixativ pe foaie de kapton . Mai nou sunt folii PEI, dar multe sunt fake .
#115 Useril este offline   ALLEN
  • Postari: 3004
  • Inregistrat: 11-May 08
Postat 03 November 2017 - 09:36 PM
pt PLA, stick glue (eu fol de la bic) direct pe sticla (sau pe patul de Al.). eu, printez direct pe pat de Al. si pun un amestec de alcool cu glue, intind cu racleta si iese printul ... super.
pt ABS, juice de filament cu acetona, intins cu racleta.
pt PETG, alcool pe sticla, sau, juice de apa cu sare, sau stick.
ti-as povesti mai multe, dar din pacate ceva probleme nu imi permit sa stau prea mult la calculator.
cand ma linistesc un pic, o sa iti dau detalii si poze.
Aceasta postare a fost editata de ALLEN: 03 November 2017 - 09:38 PM
#116 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 04 November 2017 - 07:06 AM
O solutie mai profi pentru axa Z. Linkul meu
Turnigy 9x -Er9x
#117 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 04 November 2017 - 07:08 AM
Vezi postareaALLEN, la 03 November 2017 - 09:36 PM, a spus:
Nicio problema, cand se poate..
Multa sanatate.
Turnigy 9x -Er9x
#118 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 04 November 2017 - 07:04 PM
Stie cineva un link cu un sistem de racire pentru filament care da rezultate pentru tipul acesta de imprimanta? De preferinta cu un cooler radial.
Turnigy 9x -Er9x
#119 Useril este offline   ALLEN
  • Postari: 3004
Postat 05 November 2017 - 07:32 PM
Vezi postareagyany_eugen, la 04 November 2017 - 07:04 PM, a spus:
https://www.thingive...6659ff4a96d033d
cauta si vezi ce ti se potriveste.
#120 Useril este offline   gyany_eugen
  • Postari: 977
    Aeromodelism
Postat 05 November 2017 - 08:15 PM
Asta e extruderul meu. Am observat ca toate celelalte extrudere, de la acelasi tip de imprimanta, au radiatorul montat invers, cu fantele in lateral. La mine sunt in sus/jos. Poate fi o problema?
Partea de plastic, merita schimbata cu una de aluminiu ca cea din prima poza?
  • Imagine atasata: 1.jpg
  • Imagine atasata: extruder.jpg
Turnigy 9x -Er9x
  • 58 Pagini +
42 useri citesc topicul
0 membri, 42 vizitatori, 0 utilizatori anonimi
