Poate ajuta cineva un incepator?
Am observat un comportament ciudat in reprezentarea quad-ului din Blackbox Log,se roteste ca naiba in toate directiile.
Poate fi legat de orientarea FC ?
bb log
BB Log
setup:
GPS: UBLOX M8N (mag_align = CW90deg flip- heading values ok when pointing N,S,E,V)
Frame : Jumper 266 (250 class)
FC: Omnibus F3 AIO (orientation 180 deg YAW)
Firmware:INAV
Motors:Emax MT2204
ESC's:Emax nano 20A (flashed with Biheli standard 14.1)
Props:KingKong 5x4.5x3
gyro alignment: default
accel alignment: default
# dump # version # INAV/OMNIBUS 1.7.2 Jul 20 2017 / 11:40:53 (81b85de) # resources # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mix smix reset # feature feature -RX_PPM feature -VBAT feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -TELEMETRY feature -CURRENT_METER feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DASHBOARD feature -BLACKBOX feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -SUPEREXPO feature -VTX feature -RX_SPI feature -SOFTSPI feature -PWM_SERVO_DRIVER feature -PWM_OUTPUT_ENABLE feature -OSD feature VBAT feature RX_SERIAL feature GPS feature TELEMETRY feature CURRENT_METER feature BLACKBOX feature PWM_OUTPUT_ENABLE # beeper beeper RUNTIME_CALIBRATION beeper HW_FAILURE beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACTION_SUCCESS beeper ACTION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper LAUNCH_MODE # map map AETR1234 # name name - # serial serial 20 1 115200 38400 0 115200 serial 0 32 115200 38400 0 115200 serial 1 2 115200 115200 0 115200 serial 2 64 115200 38400 0 115200 # led led 0 0,0::C:0 led 1 0,0::C:0 led 2 0,0::C:0 led 3 0,0::C:0 led 4 0,0::C:0 led 5 0,0::C:0 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 9 mode_color 5 1 11 mode_color 5 2 2 mode_color 5 3 13 mode_color 5 4 10 mode_color 5 5 3 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 # aux aux 0 0 0 900 1200 aux 1 1 1 900 1250 aux 2 2 1 1350 1650 aux 3 20 1 1750 2100 aux 4 3 4 1300 1700 aux 5 9 4 1300 1700 aux 6 8 5 1800 2100 aux 7 11 2 1700 2100 aux 8 17 0 900 1300 aux 9 0 0 900 900 aux 10 0 0 900 900 aux 11 0 0 900 900 aux 12 0 0 900 900 aux 13 0 0 900 900 aux 14 0 0 900 900 aux 15 0 0 900 900 aux 16 0 0 900 900 aux 17 0 0 900 900 aux 18 0 0 900 900 aux 19 0 0 900 900 # adjrange adjrange 0 0 0 900 900 0 0 adjrange 1 0 0 900 900 0 0 adjrange 2 0 0 900 900 0 0 adjrange 3 0 0 900 900 0 0 adjrange 4 0 0 900 900 0 0 adjrange 5 0 0 900 900 0 0 adjrange 6 0 0 900 900 0 0 adjrange 7 0 0 900 900 0 0 adjrange 8 0 0 900 900 0 0 adjrange 9 0 0 900 900 0 0 adjrange 10 0 0 900 900 0 0 adjrange 11 0 0 900 900 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # master set looptime = 1000 set gyro_sync = ON set gyro_sync_denom = 4 set align_gyro = DEFAULT set gyro_hardware_lpf = 256HZ set gyro_lpf_hz = 90 set moron_threshold = 32 set gyro_notch1_hz = 400 set gyro_notch1_cutoff = 300 set gyro_notch2_hz = 200 set gyro_notch2_cutoff = 100 set vbat_adc_channel = 1 set rssi_adc_channel = 3 set current_adc_channel = 2 set airspeed_adc_channel = 0 set acc_notch_hz = 0 set acc_notch_cutoff = 1 set align_acc = DEFAULT set acc_hardware = MPU6000 set acc_lpf_hz = 15 set acczero_x = 141 set acczero_y = -10 set acczero_z = -497 set accgain_x = 4059 set accgain_y = 4089 set accgain_z = 4017 set rangefinder_hardware = NONE set align_mag = CW90FLIP set mag_hardware = HMC5883 set mag_declination = 0 set magzero_x = 59 set magzero_y = -29 set magzero_z = -145 set mag_calibration_time = 30 set baro_hardware = BMP280 set baro_use_median_filter = ON set mid_rc = 1500 set min_check = 1100 set max_check = 1900 set rssi_channel = 16 set rssi_scale = 30 set rssi_invert = OFF set rc_smoothing = ON set serialrx_provider = SBUS set sbus_inversion = ON set spektrum_sat_bind = 0 set rx_min_usec = 885 set rx_max_usec = 2115 set blackbox_rate_num = 1 set blackbox_rate_denom = 2 set blackbox_device = SDCARD set sdcard_detect_inverted = ON set min_throttle = 1064 set max_throttle = 2000 set min_command = 1000 set motor_pwm_rate = 1000 set motor_pwm_protocol = ONESHOT125 set failsafe_delay = 5 set failsafe_recovery_delay = 5 set failsafe_off_delay = 200 set failsafe_throttle = 1000 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set failsafe_stick_threshold = 50 set failsafe_fw_roll_angle = -200 set failsafe_fw_pitch_angle = 100 set failsafe_fw_yaw_rate = -45 set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 1800 set gimbal_mode = NORMAL set battery_capacity = 0 set vbat_scale = 110 set vbat_max_cell_voltage = 43 set vbat_min_cell_voltage = 33 set vbat_warning_cell_voltage = 35 set current_meter_scale = 400 set current_meter_offset = 0 set multiwii_current_meter_output = OFF set current_meter_type = ADC set yaw_motor_direction = 1 set yaw_jump_prevention_limit = 200 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lpf_hz = 20 set flaperon_throw_offset = 200 set tri_unarmed_servo = ON set reboot_character = 82 set imu_dcm_kp = 2500 set imu_dcm_ki = 50 set imu_dcm_kp_mag = 10000 set imu_dcm_ki_mag = 0 set small_angle = 25 set fixed_wing_auto_arm = OFF set disarm_kill_switch = ON set auto_disarm_delay = 5 set gps_provider = UBLOX set gps_sbas_mode = EGNOS set gps_dyn_model = AIR_1G set gps_auto_config = ON set gps_auto_baud = ON set gps_min_sats = 6 set deadband = 5 set yaw_deadband = 5 set pos_hold_deadband = 20 set alt_hold_deadband = 50 set 3d_deadband_throttle = 50 set fw_autotune_overshoot_time = 100 set fw_autotune_undershoot_time = 200 set fw_autotune_threshold = 50 set fw_autotune_ff_to_p_gain = 10 set fw_autotune_ff_to_i_tc = 600 set inav_auto_mag_decl = ON set inav_gravity_cal_tolerance = 5 set inav_use_gps_velned = ON set inav_gps_delay = 200 set inav_reset_altitude = FIRST_ARM set inav_max_surface_altitude = 200 set inav_w_z_surface_p = 3.500 set inav_w_z_surface_v = 6.100 set inav_w_z_baro_p = 0.350 set inav_w_z_gps_p = 0.200 set inav_w_z_gps_v = 0.500 set inav_w_xy_gps_p = 1.000 set inav_w_xy_gps_v = 2.000 set inav_w_z_res_v = 0.500 set inav_w_xy_res_v = 0.500 set inav_w_acc_bias = 0.010 set inav_max_eph_epv = 1000.000 set inav_baro_epv = 100.000 set nav_disarm_on_landing = OFF set nav_use_midthr_for_althold = OFF set nav_extra_arming_safety = ON set nav_user_control_mode = ATTI set nav_position_timeout = 5 set nav_wp_radius = 100 set nav_wp_safe_distance = 10000 set nav_auto_speed = 300 set nav_auto_climb_rate = 500 set nav_manual_speed = 500 set nav_manual_climb_rate = 200 set nav_landing_speed = 200 set nav_land_slowdown_minalt = 500 set nav_land_slowdown_maxalt = 2000 set nav_emerg_landing_speed = 500 set nav_min_rth_distance = 500 set nav_rth_climb_first = ON set nav_rth_climb_ignore_emerg = OFF set nav_rth_tail_first = OFF set nav_rth_allow_landing = ON set nav_rth_alt_mode = AT_LEAST set nav_rth_abort_threshold = 50000 set nav_rth_altitude = 1000 set nav_mc_bank_angle = 30 set nav_mc_hover_thr = 1500 set nav_mc_auto_disarm_delay = 2000 set nav_fw_cruise_thr = 1400 set nav_fw_min_thr = 1200 set nav_fw_max_thr = 1700 set nav_fw_bank_angle = 20 set nav_fw_climb_angle = 20 set nav_fw_dive_angle = 15 set nav_fw_pitch2thr = 10 set nav_fw_loiter_radius = 5000 set nav_fw_land_dive_angle = 2 set nav_fw_launch_velocity = 300 set nav_fw_launch_accel = 1863 set nav_fw_launch_max_angle = 45 set nav_fw_launch_detect_time = 40 set nav_fw_launch_thr = 1700 set nav_fw_launch_idle_thr = 1000 set nav_fw_launch_motor_delay = 500 set nav_fw_launch_spinup_time = 100 set nav_fw_launch_timeout = 5000 set nav_fw_launch_climb_angle = 18 set telemetry_switch = OFF set telemetry_inversion = ON set frsky_default_latitude = 0.000 set frsky_default_longitude = 0.000 set frsky_coordinates_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set frsky_vfas_cell_voltage = OFF set hott_alarm_sound_interval = 5 set smartport_uart_unidir = OFF set ibus_telemetry_type = 0 set ltm_update_rate = NORMAL set ledstrip_visual_beeper = OFF set osd_video_system = 0 set osd_row_shiftdown = 0 set osd_units = METRIC set osd_rssi_alarm = 20 set osd_cap_alarm = 2200 set osd_time_alarm = 10 set osd_alt_alarm = 100 set osd_main_voltage_pos = 2060 set osd_rssi_pos = 2071 set osd_flytimer_pos = 2423 set osd_ontime_pos = 2391 set osd_flymode_pos = 2444 set osd_throttle_pos = 2273 set osd_vtx_channel_pos = 200 set osd_crosshairs = 0 set osd_artificial_horizon = 2248 set osd_current_draw_pos = 2265 set osd_mah_drawn_pos = 2233 set osd_craft_name_pos = 84 set osd_gps_speed_pos = 2113 set osd_gps_sats_pos = 2400 set osd_gps_lon = 2432 set osd_gps_lat = 2464 set osd_home_dir = 2159 set osd_home_dist = 2081 set osd_altitude_pos = 2049 set osd_vario = 182 set osd_vario_num = 247 set osd_pid_roll_pos = 322 set osd_pid_pitch_pos = 354 set osd_pid_yaw_pos = 386 set osd_power_pos = 47 set i2c_overclock = OFF set debug_mode = NONE set acc_task_frequency = 500 set attitude_task_frequency = 100 set async_mode = ALL set throttle_tilt_comp_str = 0 set input_filtering_mode = OFF set mode_range_logic_operator = OR set stats = OFF set stats_total_time = 0 set stats_total_dist = 0 # profile profile 1 set mc_p_pitch = 58 set mc_i_pitch = 50 set mc_d_pitch = 22 set mc_p_roll = 43 set mc_i_roll = 40 set mc_d_roll = 20 set mc_p_yaw = 70 set mc_i_yaw = 45 set mc_d_yaw = 0 set mc_p_level = 20 set mc_i_level = 15 set mc_d_level = 75 set fw_p_pitch = 5 set fw_i_pitch = 7 set fw_ff_pitch = 50 set fw_p_roll = 5 set fw_i_roll = 7 set fw_ff_roll = 50 set fw_p_yaw = 6 set fw_i_yaw = 10 set fw_ff_yaw = 60 set fw_p_level = 20 set fw_i_level = 5 set fw_d_level = 75 set max_angle_inclination_rll = 300 set max_angle_inclination_pit = 300 set dterm_lpf_hz = 80 set yaw_lpf_hz = 30 set dterm_setpoint_weight = 0.000 set fw_iterm_throw_limit = 165 set fw_reference_airspeed = 1000.000 set fw_turn_assist_yaw_gain = 1.000 set dterm_notch_hz = 260 set dterm_notch_cutoff = 160 set pidsum_limit = 500 set yaw_p_limit = 300 set iterm_ignore_threshold = 200 set yaw_iterm_ignore_threshold = 50 set rate_accel_limit_roll_pitch = 0 set rate_accel_limit_yaw = 10000 set heading_hold_rate_limit = 90 set nav_mc_pos_z_p = 50 set nav_mc_pos_z_i = 0 set nav_mc_pos_z_d = 0 set nav_mc_vel_z_p = 100 set nav_mc_vel_z_i = 50 set nav_mc_vel_z_d = 10 set nav_mc_pos_xy_p = 65 set nav_mc_pos_xy_i = 120 set nav_mc_pos_xy_d = 10 set nav_mc_vel_xy_p = 180 set nav_mc_vel_xy_i = 15 set nav_mc_vel_xy_d = 100 set nav_fw_pos_z_p = 50 set nav_fw_pos_z_i = 0 set nav_fw_pos_z_d = 0 set nav_fw_pos_xy_p = 75 set nav_fw_pos_xy_i = 5 set nav_fw_pos_xy_d = 8 set rc_expo = 70 set rc_yaw_expo = 20 set thr_mid = 50 set thr_expo = 0 set roll_rate = 80 set pitch_rate = 80 set yaw_rate = 65 set tpa_rate = 0 set tpa_breakpoint = 1500 #
Multumesc in avans,
Aceasta postare a fost editata de Torke: 17 August 2017 - 01:52 PM
