Modelism - RHC Forum: Vand motoare DJI 2312 960KV - Modelism - RHC Forum
Vand motoare DJI 2312 960KV Motor DJI 2312 960KV E310
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 07 May 2017 - 06:45 PM
Vand set 6 motoare originale DJI 2312 960KV (3CCW/3CW), testate pe un hex 1-2h, stare impecabila, sunt acelasi motoare ca in setul DJI E310:
-ax otel de 4mm
-acelasi ax se extinde pana in filetul elicei, deci fara filet aluminiu la elice
-rulmenti mai mari de 11mm
-bobinaj impecabil spira langa spira
-eficienta ridicata cu elici 9450
-acelasi motoare ca pe DJI Phantom 2+/3
https://www.sierra.ro/Motor-2312-(CCW)-filet-pe-dreapta-DJI-PHANTOM-3-p7109p.html
Specifications:
2312 & 9450
Recommended Take-off Weight: 300g/axis
Maximum Tension: 800g/axis
Working Temperature: -5 °C ~ 40 °C
Stator Size: 23×12 mm
KV: 960 rpm/V
Motor Weight: 55 g
Diameter/Pitch: 24×11 cm 9.4×4.5 inch
Pret: 450lei / 6buc
Tel: 0749 121 132
Aceasta postare a fost editata de andrewbt: 07 May 2017 - 06:47 PM
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 11 May 2017 - 08:18 AM
Vandute 4buc, mai raman 2 bucati pentu cine are nevoie de rezerva pentru DJI Phantom 2 / 3.
Andrei
