Modelism - RHC Forum: Bracuta Galbenuta <3 - Modelism - RHC Forum
Bracuta Galbenuta <3 Prima barcuta pentru nadit construita
#1 Useril este offline   bogdan bogdan
  • Postari: 22
  • Inregistrat: 15-March 16
  Postat 19 April 2017 - 08:22 PM
Salutare colegi! http://www.rhcforum.ro/public/style_emoticons/default/yahoo.gif
Daca imi dati voie, va prezint si eu prima barcuta pentru nadit. Am terminat-o acum cateva zile. Astept si eu cateva pareri.. unde am gresit, ce nu am facut ok, unde era loc de mai bine...etc :)
Componente principale folosite:
Coca Range 3 (Multumesc mult @nid1975 pentru coca si pentru sfaturi)
Servo carma: JX Servo (4.8V) 5.56 kg / cm (6V) 6,21 kg / cm
Servo cuve: Power HD 1501 MG 4.8V - 15,5 kg / cm ~ 6.0V -17.0 kg / cm
Motor 755/40
Cuplaj fix
Ax portelice cu rulmenti 150/4 mm
Elice D42/D45 2 pale dreapta
Carma din alama 50 x 36 mm
Telecomanda: HobbyKing HK6S 2.4Ghz FHSS 6Ch
Acumulator VRLA ULTRACELL 12 V 7.2Ah
Cateva poze:
Fisier atasat  20170329_212143.jpg (32.45K)
Fisier atasat  20170402_163505.jpg (36.54K)
Fisier atasat  20170403_210235.jpg (69.06K)
Fisier atasat  20170410_141442.jpg (48.3K)
Fisier atasat  20170410_143022.jpg (56.93K)
Fisier atasat  20170414_160021.jpg (44.23K)
Fisier atasat  20170415_085542.jpg (52.79K)
Fisier atasat  20170415_085605.jpg (57.17K)
Fisier atasat  20170415_085657.jpg (53.27K)
#2 Useril este offline   bogdan bogdan
  • Postari: 22
Postat 19 April 2017 - 08:23 PM
Fisier atasat  20170415_085720.jpg (55.56K)
Fisier atasat  20170415_085727.jpg (42.87K)
Fisier atasat  20170415_113723.jpg (50.68K)
Fisier atasat  20170415_183745.jpg (33.17K)
Fisier atasat  20170418_141427.jpg (50.05K)
Fisier atasat  20170418_141436.jpg (44.18K)
Fisier atasat  IMG-20170417-WA0007.jpg (68.14K)
Fisier atasat  IMG-20170417-WA0008.jpg (50.06K)
#3 Useril este offline   DigitAll
  • Postari: 769
  • Inregistrat: 23-January 09
Postat 19 April 2017 - 08:52 PM
Este lucrata ingrijit cu atentie la detalii.
Observatie: distanta firelor intre BATERIE-PLACA, respectiv PLACA-MOTOR este mare, din poza o estimez cam 1,5-1,6m (fir de fi 1,5mm) , vei avea ceva caderi de tensiune pe fire; motorul va avea turatie mai mica iar voltmetrul va afisa eronat.
Rezistorul de limitare pt far nu isi are rostul, electronica e prevazuta cu conectare directa a farului.
Tel : 0768080180
#4 Useril este offline   ahmoola
  • Postari: 409
  • Inregistrat: 14-February 13
Postat 19 April 2017 - 08:55 PM
Bravo
#5 Useril este offline   bogdan bogdan
  • Postari: 22
Postat 20 April 2017 - 08:27 AM
Vezi postareaDigitAll, la 19 April 2017 - 08:52 PM, a spus:
Multumesc pentru sfat. O sa tin cont de asta si o sa reduc cat pot de mult lumnginea acestor cabluri. Intre baterie-placa, placa-motor am pus cablu litat de 2mm din cupru ..mie mi se pare cam gros. Las asa sau merge sa pun si de 1.5 mm?
Am pus acea rezistenta pentru ca farul este de 20w iar in manualul electronicii scrie ca trebuie far de maxim 3W.
#6 Useril este offline   DigitAll
  • Postari: 769
Postat 20 April 2017 - 09:07 AM
Rezistenta poate sa ramana acolo, nu incurca cu nimic, dar cred ca farul are 1W sau 1,5W reali.
Cu cat firele sunt mai groase , cu atat mai bine, dar singurul incovenient este ca se lucreaza mai greu cu ele.
Tel : 0768080180
#7 Useril este offline   manolo
  • Postari: 3555
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 20 April 2017 - 10:00 AM
Daca lanterna provine din una alimentata cu baterii nu are 20w ,ai masurat consumul? ar trebui sa consume cam 4A cea ce nu cred ,av vazut ca ai folost glue gun ,nu stiu ce ai lipit cu el ,dar nu va rezista in timp ,fibra si acel "smac" au coeficenti de dilatare diferiti ,e bine ca axul cirmei sa-l intaresti in barca .Daca vrei sa folosesti fire mai subtiri ,poti folosi cablu siliconic 14AWG.
Barcute intinse!
#8 Useril este offline   bogdan bogdan
  • Postari: 22
Postat 20 April 2017 - 11:32 AM
Vezi postareamanolo, la 20 April 2017 - 10:00 AM, a spus:
Multumesc pentru sfaturi.
Pe lanterna scria Police 20W si avea locas pentru 3 baterii normale. O sa scot rezistenta.
Cu glue gun am lipit firele de coca..la prima vedere pare sa se fi lipit destul de bine..vad in timp cum se prezinta sa stiu daca mai folosesc sau nu pe viitor.
Ce recomanzi pentru intarirea axului carmei? E de ajuns chit cu fibra sau sa pun un suport bagat prin ax si sa-l prind cu chit de coca?
Aceasta postare a fost editata de bogdan bogdan: 20 April 2017 - 11:34 AM
  • Postari: 3555
  • Interests:Navo
Postat 20 April 2017 - 12:17 PM
E clar cu lanterna,scoate rezistenta ,cu firele ,se vor desprinde dupa un sezon ,fixeazele cu acel ceva cu ce ai lipit axul port elice.
Cu cirma ,ia un marker din ala mai gros si taie o bucata cam3/4 din inaltimea cirmei si baga in interior ceva epoxi,silicon ,dupa ce in prealabil baza ai fixat-o cu ceva "smac" poate cel folosit la axul port elice (ce este?)
Barcute intinse!
#10 Useril este offline   bogdan bogdan
  • Postari: 22
Postat 20 April 2017 - 12:21 PM
La axul port elice am folosit chit cu fibra si peste am dat cu silicon negru.
#11 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
  • Inregistrat: 01-December 08
Postat 20 April 2017 - 06:29 PM
Bravo , foarte curat ai lucrat , felicitari !!!
facebook
0721 241 744 VODAFONE
0762 028 013 COSMOTE
4 useri citesc topicul
