Modelism - RHC Forum: Charger Dual Robbe Power Peak I4 EQ-BID - Modelism - RHC Forum
Charger Dual Robbe Power Peak I4 EQ-BID Charge 10A / Discharge 5A
#1 Useril este offline   vvrest
  • Postari: 907
  • Inregistrat: 29-September 09
Postat 19 February 2017 - 10:10 PM
Impecabil, cu folia de protectie inca nedeslipita!
Touch sensor!
Technical data:
Output Out 1:
Cell count:
1 ... 30 cells NiCad / NiMH
1 ... 12 cells LiFe, LiIo, LiPo
1 ... 6 and 12 cell lead-acid
Ladestrom 0,1 ... 10 A (max. 210W)
discharge current: 0,1 ... 5 A (max. 50W)
Equalizer connection for 1-12 cells LiFe, LiIo, LiPo, Equalizer current approx.. 250 mA
Discharge voltage:
0,1 ... 1,1 V per cell (NiCad- / NiMH-batteries)
2,5 ... 3,7 V per cell (LiPo-packs)
1,8 V per cell (lead-acid)
Trickle charge: 0 ... 500 mA, adjustable in 50 mA steps for NiCad- / NiMH- packs, C/20 with BID Chip
Cut Off:
NiCad-packs: automatic, digital-Delta-Peak-System, Cut off sensitivity: 5 ... 25 mV per cell
NiMH-packs: automatic, digital-Delta-Peak-System, Cut off sensitivity: 5 ... 15 mV per cell and ZEROpeak.
Lithium / lead-acid: automatic, acoording to CC-CV method
Temperature switch: 10 ... 65°C, adjustable in 1°C steps
Capacity monitoring: 10 ... 150 %, adjustable (NiCad- / NiMH-packs) 10 ... 120 % (Lithium / laed acid packs)
Output OUT 2:
Cell count charging:
1 - 8 cells NiCad / NiMH
1 - 3 Zellen, LiFe, LiIo, LiPo
chareg current: 0,1 - 5,0 A (max. 50W)
Equalizer connection for 1-3 cells LiFe, LiIo, LiPo
Equalizer current ca. 100 mA
Se vinde cu manual, cheita BID si senzorul de temperatura.
Poze reale:
https://goo.gl/photo...uzaqyLvzQ8u3Qv9
Pret: 550 RON
Contact Razvan 0721.846.149
