Modelism - RHC Forum: Turnigy Reaktor 300W 20A 6S Balance Charger - Modelism - RHC Forum
Turnigy Reaktor 300W 20A 6S Balance Charger Charge 20A / Discharge 20A
#1 Useril este offline   vvrest
  • Postari: 907
  • Inregistrat: 29-September 09
Postat 19 February 2017 - 09:58 PM
Functioneaza impeacbil, mici defecte optice de la transporturile la care a trebuit sa faca fata dealungul timpului!
A fost purtat dupa mine de backup in permanenta!
Features:
• Microprocessor controlled
• Delta-peak sensitivity (NiMH/NiCd)
• Individual cell balancing charge & discharge
• Li-ion, Li-poly and LiFe capable
• Ni-Cd and NiMH capable
• High-power and high-performance circuit
• Store function, allows safe storage current
• Data storage (Store up to 10 packs in memory)
• Cyclic charging/discharging
Specs:
Input voltage: 11~28V DC
Charge current: 0.1~20A
Discharge current: 0.1~20A
Maximum charge capacity: 300W
Maximum discharge capacity: 20W
Maximum regenerative discharge power capacity: 300W
Current drain for balancing Li-po: 350mAh/cell
Lithium (Li-poly/LiIo/LiFe) battery cell count: 1~6 series
NiCd/NiMH battery cell count: 1~17 series
Pb battery voltage: 2~24V
Battery setup memories: 10
Intelligent temperature control: Yes
Weight: 350g
Dimensions: 140x95x27mm
Poze reale:
https://goo.gl/photo...F9XhevajoGqUgL9
Pret: 225 RON
Contact: Razvan 0721.846.149
#2 Useril este offline   Rivelino
  • Postari: 273
  • Inregistrat: 21-June 09
Postat 19 February 2017 - 11:50 PM
Rezevat pt mine.
3 useri citesc topicul
