Modelism - RHC Forum: JET SPORT ODYSSEY - Modelism - RHC Forum
  • 5 Pagini +
  • Ultima ยป
JET SPORT ODYSSEY
#31 Useril este offline   dan 73
  • Postari: 1513
  • Inregistrat: 06-May 10
Postat 17 October 2016 - 01:57 PM
Producatorul ATJ specifica ca filtru sa se monteze intre pompa si rezervor(hoper).
" Fuel pump connection
1.
Use good quality 4mm fuel tube for turbine engines
2.
Install fuel filter between fuel pump and fuel tank (low presser side).
3.
Change fuel tube every year and keep the fuel tube soft no leaking
4.
Always keep the fuel filter clean
5.
Install hand cut off valve between fuel filter and air trap tank. "
http://www.atj.com.t.../download3.html
Si la turbina mea VT-80 BL producatorul Jets Munt specifica acelasi lucru,filtru intre pompa si hoper.
#32 Useril este offline   Iamzoli
  • Postari: 815
  • Inregistrat: 08-January 10
Postat 17 October 2016 - 02:09 PM
Pune-ti unde vreti dar nu are nici o logica sa pui filtru decat dupa pompa ... inainte hoperul functioneaza si ca si filtru.
din manualul jetcat pagina 12
A high quality filter installed in the pump outlet line between the pump and solenoid valve will prevent debris from fuel pump gear wear from entering the solenoid valve, possibly sticking the valve in the open position at shutdown.
A stuck solenoid valve will allow fuel into the engine during fueling, which could start a fire during engine start.
The filter should be mounted in the vertical position to eliminate the possibility of trapping an air bubble in the filter housing.
Should always use a mechanical fuel shut off like the Festo ball valve as a secondary precaution
Eu unul personal folosesc un filtru inainte de a umple rezervorul si atat. nu mai bag dupa pompa ca stresez pompa aiurea, oricum poate trebuie sa adjusezte voltajul la pompa daca foloseste 2 rezervoare
unul primar si unul secundar ....dar prima oara bogdan incearca fara nici o adjustare ....daca acelereaza greu turbina sau chiar moare (nu cred) mai dai voltaj pana simti ca merge ca si cand ti-ai facut testul
Aceasta postare a fost editata de Iamzoli: 17 October 2016 - 02:14 PM
....in Thrust we trust....
Flying Vampires Arad
#33 Useril este offline   bogdan_bacau
  • Postari: 778
  • Inregistrat: 23-March 13
Postat 17 October 2016 - 03:23 PM
Vezi postareaIamzoli, la 17 October 2016 - 02:09 PM, a spus:
merci de raspuns.Pana la urma...de aceia am pus intrebarea asta...sa mai vad cum ati folosit voi.La urma urmei fac cum zice producatorul.Teoretic asa am facut si la primele teste cand am pornit turbina,doar ca nu am avut "hoopher".sau cum so scrie.๐Ÿ™„ pana atunci va voi tine la curent.Cred ca maxim in 7/8 zile il termin.Voi mai reveni cu poze.
#34 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 18 October 2016 - 05:40 PM
Au mai ajuns accesorii.Asa arata trenul cu roata de bot,si hopper-ul
#35 Useril este offline   comnean
  • Jetinson
  • Postari: 886
  • Inregistrat: 31-December 08
  • Interests:WHAT KIND OF MAN WOULD LIVE WHERE THERE IS NO DARING? I DON'T BELIVE IN TAKING FOOLISH CHANCES, BUT NOTHING CAN BE ACCOMPLISHED WITHOUT ANY CHANCE AT ALL.
Postat 18 October 2016 - 08:19 PM
Hoperul tau are element filtrant dar exista hopere care contin doar un pendul (forma elipsoidala sau sferica). La tipul tau de hoper filtrul se monteaza dupa pompa, la hoperele fara filtru sau la rezervoarele fara hoper filtrul trebuie montat intre pompa si hoper. Furtunul intre pompa si hoper trebuie sa fie cat mai scurt posibil, dupa pompa nu mai conteaza. Intre pompa si filtru sau imediat dupa filtru, inainte de servovalve (inainte de racordul T) e foarte indicat sa montezi un robinet Festo pe care sa-l tii inchis atata timp cat alimentezi rezervoarele sau pe timpul transportului. Atfel vei evita "inundarea" accidentala a turbinei la alimentare sau la transport.
MC 24 Graupner ACT 2.4, mpx 3300 PROFI
SERIOUS THINKS THAT CAN FLY + A DREAM UNDERCONSTRUCTION
#36 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 25 October 2016 - 07:48 AM
Am mai lucrat si eu cate putin...Am terminat ampenajele.Am facut echii de carbon..cateva inbunatatiri.Acus sunt gata si aripele doar ca si acolo mai trebui mofificat putin.Sa mai vin cu un adaos de placaj la locasul pt servo.
#37 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2393
  • Inregistrat: 05-August 09
Postat 25 October 2016 - 08:31 AM
Vezi postareabogdan_bacau, la 25 October 2016 - 07:48 AM, a spus:
Foarte frumos lucrat, ca de obicei meticulos. Totusi la cum te cunosc sunt curios cat o sa te tina asta cu jeturile, ca...am vazut ca te plictisesti tare repede.
Olivian Diaconescu
F22 depron
#38 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 25 October 2016 - 08:40 AM
Vezi postareaoachidori, la 25 October 2016 - 08:31 AM, a spus:
Daaaaaa๐Ÿ˜๐Ÿ˜๐Ÿ˜๐Ÿ˜๐Ÿ˜ ideia e...ca pana la urma imi iau unu adevarat si gata.Is miticulos ca nu imi place sa fac treaba dean pu_____ ๐Ÿ™„ si nu prea imi place sa fac improvizatii.Vreau sa fie sigur in aer si sa nu cedeze ceva.De aceea fac unele imbunatari.Ca si acesta...cand o sal vand...clientul sa fie multimit.
#39 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2393
Postat 25 October 2016 - 08:54 AM
Vezi postareabogdan_bacau, la 25 October 2016 - 08:40 AM, a spus:
Nu stiu daca ai avut vreodata vreo reclamatie in acest sens, la cum au aratat avioanele vandute de tine (intretinute si foarte profi finalizate de zbor) vs bani, dar eu ma numar printre cumparatorii foarte multumiti. ;) :good:
Olivian Diaconescu
F22 depron
#40 Useril este offline   dan 73
  • Postari: 1513
Postat 25 October 2016 - 08:58 AM
:good:
#41 Useril este offline   fly
  • Postari: 3415
  • Inregistrat: 09-November 08
  • Interests:Jeturi ,f3j ,f5j
Postat 25 October 2016 - 09:01 AM
Vezi postareaoachidori, la 25 October 2016 - 08:54 AM, a spus:
:good: :drinks:
#42 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 25 October 2016 - 10:33 AM
Stii cum e....Nici eu cand il deafac din cutie nu sunt multumit 100% de model.Pana la urma e facut manual chiar si robotul greseste.Iar cei care au cumparat de la mine au luat la un pret bun si nu vad sa-mi faca reclamatie.๐Ÿ˜Ž
#43 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 26 October 2016 - 04:34 PM
Si iata ca sitemul pt trenul de aterizate prinde contur ๐Ÿค—๐Ÿค—๐Ÿค—๐Ÿค— cateva modifcari a suferit pt o prindere mai buna la btatul rotii.Nici asta nu a scapat sa ajunga la strung si freza.๐Ÿ˜€
https://youtu.be/aj2NWQ9HuRs
#44 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 28 October 2016 - 01:08 PM
Astazi am cromat jantele de pe spate sa fie la fel ca roata de pe fata.๐Ÿ˜Am echipat si trenurile de seara o sa le montez si o sa fac teste.Sunt multumit in sfarsit.Totul functioneaza 100% corect si sigur'
#45 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2393
Postat 28 October 2016 - 01:32 PM
Vezi postareabogdan_bacau, la 28 October 2016 - 01:08 PM, a spus:
Frate esti maniac!! Super tare!! :good: :good:
Olivian Diaconescu
F22 depron
#46 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 30 October 2016 - 12:58 AM
Greu ma mai misc...ca melcul,nu am spor deloc.Primul test cu jamba de pe fata.Si tot nu sunt multumit.O sa mai fac cateva modificari.
https://youtu.be/d4nPLxY9MDQ
#47 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 31 October 2016 - 12:55 AM
Am mai lucrat cate putin la model.Am terminat aripile.Mai am putin cateva reglaje pt roata de fata si apoi trec la electronica.Sper sa il termin saptamana asta.
https://youtu.be/lovc0yYD9gA
#48 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 02 November 2016 - 03:28 PM
Mai am putin si ma apropii de finalizare.L-am pus pe roti.Super fain.Imi place la nebunie.Abia astept sa il vad pe cer.
#49 Useril este offline   fly
  • Postari: 3415
Postat 02 November 2016 - 03:51 PM
Vezi postareabogdan_bacau, la 02 November 2016 - 03:28 PM, a spus:
Baga Bogdan sa il vedem in aer !!! :drinks:
#50 Useril este offline   AdrianDim
  • Postari: 562
  • Inregistrat: 29-April 12
  • Interests:aeromodelism
Postat 02 November 2016 - 04:49 PM
Frumos..........
Adrian Dimitriu
Imagine postata
#51 Useril este offline   Zippo
  • Postari: 1077
Postat 03 November 2016 - 09:59 AM
Impecabil realizat, imi place la nebunie cat de curat si perfect este ansamblat :)
Putini sunt asa meticulosi ca tine, felicitari !
Succes la zbor !
Aceasta postare a fost editata de Zippo: 03 November 2016 - 10:00 AM
#52 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 03 November 2016 - 07:46 PM
Vezi postareaZippo, la 03 November 2016 - 09:59 AM, a spus:
Succes la zbor !
Merci !!! ๐Ÿค—
#53 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 20 November 2016 - 12:08 PM
Dupa nulte ore de munca si mult stres am reusit sa termin noul tren de aterizare conceput de la 0.๐Ÿ˜ฉ Insa de data aceasta a iesit bine.Si sunt multumit.Cele vechi erau firave si nu amortizau decat "NIMIC" ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
#54 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 21 November 2016 - 06:55 PM
Astazi am terminat de facut si bucsa pt butucul rotii.Am facut un sistem de blocare pentru frana sa nu se roteasca butucul cu tot cu fire ca rupe tot.Chinezii astia nu au treaba pana la capat.Ori cum sunt eficiente si isi fac treaba.
#55 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 23 November 2016 - 08:27 PM
Gata.Astazi am finalizat noile brate de la trenul de aterizare.Le-am si lustruit de au iesit cromate.Nici cele originale nu arata atat de bine ca ale mele.๐Ÿค—
#56 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 24 November 2016 - 02:26 PM
Astazi am facut si sistemul de prindere pentru capacele de la roti pe bratele de la trenul de aterizare.๐Ÿค—
Vezi postareabogdan_bacau, la 24 November 2016 - 02:26 PM, a spus:
#57 Useril este offline   dan 73
  • Postari: 1513
Postat 24 November 2016 - 09:02 PM
Vezi postareabogdan_bacau, la 23 November 2016 - 08:27 PM, a spus:
Ar arata mai bine cu asa roti.
#58 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 24 November 2016 - 10:09 PM
Vezi postareadan 73, la 24 November 2016 - 09:02 PM, a spus:
misto...ce diametru au?
#59 Useril este offline   dan 73
  • Postari: 1513
Postat 25 November 2016 - 10:50 AM
Vezi postareabogdan_bacau, la 24 November 2016 - 10:09 PM, a spus:
95 mm
#60 Useril este offline   bogdan_bacau
  • Postari: 778
Postat 26 November 2016 - 01:28 AM
Vezi postareadan 73, la 25 November 2016 - 10:50 AM, a spus:
95 mm
au frane ?
  • 5 Pagini +
  • Ultima ยป
loading
