Modelism - RHC Forum: receptor - Modelism - RHC Forum
receptor
#1 Useril este offline   razvan_rusescu
  • Postari: 75
  • Inregistrat: 27-September 09
Postat 09 August 2016 - 09:33 PM
salut stie cineva pasi de binduire la un receptor GRAUPNER SJ HOTT GR 12 cu telecomanda primul receptor a oxidat si nu mai ia comanda multumesc
  • Pfiu Drace, zboara!!!
  • Postari: 2111
  • Inregistrat: 16-March 13
  • Interests:Aero, 3D
Postat 10 August 2016 - 07:46 AM
Miracolul lui Google
Switch the transmitter and receiver on.
• 	Locate the BIND / RANGE button on the back of the transmitter, and hold it pressed in while you
press and hold the SET button on the receiver. Both LEDs on the back of the transmitter now glow
constantly, and the green LED on the receiver flashes.
•  	If  the  green flashing  LED  on  the  receiver  begins  to  glow  permanently  within  about  ten  seconds,
    	this  indicates  that  the  binding  process  is  complete.  You  can  now  release  both  buttons,  and  your
transmitter / receiver combination is ready for use.
• 	However, if the green LED on the receiver continues to flash for longer than ten seconds, then the
binding process has failed. If this should occur, repeat the whole procedure
Fly it, like you stole it!
#3 Useril este offline   ahmoola
  • Postari: 409
  • Inregistrat: 14-February 13
Postat 10 August 2016 - 10:34 AM
Incredibil!
Ar fi bine sa-i explici si unde se gaseste acest google.ro, nu crezi?
:clapping:
:drinks:
#4 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
  • Inregistrat: 01-December 08
Postat 10 August 2016 - 05:48 PM
Razvan, daca nu ai un CNX , nu ai nimic :))))
facebook
0721 241 744 VODAFONE
0762 028 013 COSMOTE
#5 Useril este offline   stelian
  • NAVOMODELE CNX
  • Postari: 2400
Postat 10 August 2016 - 06:02 PM
Drace , ce ai pus tu acolo nu are nici o legatura cu radiocomanda respectiva !!!
facebook
