Rotational Speed: 1600 RPM/V
Continuous Current: 45A
Max. Current: 55A
Input Voltage: 8 - 24V
Max. Efficiency: 96%
No Load Current: 1.1A
Internal Resistance: 42m ohm
Motor Dimensions (Diameter x Length): 36.5mm x 52.2mm
Shaft Dimensions (Diameter x Length): 3.97 x 18mm
Input Battery Types: NiCd/ Nimh/ Li-po Battery
Recommend Model: Helicopter / Airplane 85 lei
