Modelism - RHC Forum: Receptoare 2,4 GHz - Modelism - RHC Forum
Receptoare 2,4 GHz Noi
#1 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
  • Inregistrat: 06-October 08
Postat 19 July 2016 - 12:58 PM
1.Rreceptor 2,4GHz Dinam-7 CH -45 lei
2. Receptor 2,4 GHz ASSAN-6CH-X8R6- 75 lei
3.Receptor 2,4 GHz-Turnigy-TGY-IA6-cu telemetrie- 60 lei
Nu au fost folosite.....
Tel. 0722 493 702
ADRIAN - Tel.0787 828 507
Ingerii zboara pentru ca o iau usor .....
#2 Useril este offline   Zeus
  • Postari: 2455
  • Inregistrat: 15-January 09
Postat 19 July 2016 - 11:44 PM
Punctul 3 sigur are telemetrie? Pe site hk scrie altceva.
#3 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 20 July 2016 - 12:24 AM
Vezi postareaZeus, la 19 July 2016 - 11:44 PM, a spus:
Receiver power telemetry feedback is available using the standard i6 receiver. To use telemetry sensors such as the RPM/Speed (TGY-CPD01 magnetic or TGY-CPDO2 Optical), or Temperature (TGY – CTM01) you will need to use the TGY-iA10 receiver or the Turnigy TGY iA6B V2 full range receiver to enable all flight telemetry information functions listed in the Accessories listing below. If you need more channels for larger airplanes, the TGY-CEV01 can help you to expand from one channel to four more channels.
#4 Useril este offline   Zeus
  • Postari: 2455
Postat 20 July 2016 - 10:14 AM
Deci al tau nu are telemetrie,Are tgy ia6B. Tu ai varianta tgy ia6.
Uite asta are telemetrie http://www.hobbyking..._Receiver.html.
Tu pe acesta il ai http://www.hobbyking..._Receiver.html.
Si daca vrei iti ofer 40 ron pe el ca atat face cu tot cu transport, plata in cont inainte si trimiti cu posta romana (2.7 ron)
Aceasta postare a fost editata de Zeus: 20 July 2016 - 10:17 AM
#5 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 20 July 2016 - 05:11 PM
Vezi postareaZeus, la 20 July 2016 - 10:14 AM, a spus:
Pentru tine se poate cu 50 ron si transport inclus PR.
Nu am gasit cu transport inclus....
#6 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 29 July 2016 - 02:05 PM
Valabil....
4 useri citesc topicul
